Gå til produktinformation
1 af 1
AiM SmartyCam HD 2.1 & SmartyCam 3 Sport & Corsa Roll Cage Mount
SKU: SM-VB
Normal pris
£60.00
Normal pris
Udsalgspris
£60.00
AiM SmartyCam HD 2.1 & SmartyCam 3 Roll Cage Mount
The SmartyCam can be installed using the roll cage mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3.
Secure mounting for SmartyCam
Ball & socket system
Suitable for 0.5 to 1.2"
SmartyCam HD 2.1 Compatible
SmartyCam 3 Sport Compatible
SmartyCam 3 Corsa Compatible
The AiM SmartyCam roll cage mount allows you to mount your SmartyCam to your car/motorcycle.
The SmartyCam roll cage mount has been designed to securely mount the AiM SmartyCam camera.
The V bracket adjusts by using the ball and socket type system for optimising positioning and simply clamps to roll bars of a wide range of diameters.
Please Note: This bracket is only suitable for the SmartyCam HD 2.1 & SmartyCam 3.
Roll Cage Mount
Securely clamps to a roll bar of a wide range of diameters.
  • For use with SmartyCam HD 2.1 & SmartyCam 3
  • 1 Handlebar bracket and straps
  • 160mm single ball arm
  • 1 ball head
  • 1 washer diameter 17.7mm, thickness 1.5mm, hole 6mm
Technical sheet Race Studio 3
The AiM SmartyCam roll cage mount allows you to mount your SmartyCam to your car/motorcycle. The SmartyCam roll cage mount has been designed to securely mount the AiM SmartyCam camera. The V bracket adjusts by using the ball and socket type system for optimising positioning and simply clamps to roll bars of a wide range of diameters. Please Note: This bracket is only suitable for the SmartyCam HD 2.1 & SmartyCam 3.
Roll Cage Mount
  • 1 ball head
