Gå til produktinformation
1 af 4
Ducati Panigale 899, 959, 1199, 1199R, 1299 AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-DUC-1
Normal pris
£710.00
Normal pris
Udsalgspris
£710.00
+ moms (kun Storbritannien)
Alle leveringer er CO₂-neutrale
Drevet af Shopify Planet
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Ducati this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide Ducati Panigale ECU connection cable
This kit has been specifically designed for Ducati Panigale bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Ducati Panigale ECU will give you all the engine performance information you need to help improve your driving performance.
The plug & play cable currently fits the following Ducati Panigale bike models:
899 Panigale - 2013-2015 959 Panigale - From 2016
1199 Panigale - 2012-2014 1199R Panigale - 2015-2017
1299 Panigale - 2015-2019
The Ducati Panigale ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Inertial platform : Internal 3 axis +5G accelerometer + 3 axis gyro +3 axis magnetometer
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the Ducati Panigale 899, 959, 1199, 1199R plug & play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM Ducati Panigale Connection Cable
  • Bracket
  • 1 washer
  • 1 rubber dowel
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
  • Bracket
  • 1 washer
  • 1 rubber dowel
