GT-32 Steering Wheel 320mm With Paddle Shift
SKU: GT32
- Normal pris
- £1,350.00
- Normal pris
- Udsalgspris
- £1,350.00
- Pris per stk
- om
+ moms (kun Storbritannien)
GT32 Steering Wheel
Here is our new GT32 Steering Wheel!
GT32 transmits in a freely configurable CAN connection the status of the 10 pushbuttons (while 2 of them feature free contacts connections), 3 rotary switches and paddles
Completely configurable pushbuttons:
Momentary, Toggle, Multistatus |
Custom backlighting
RGB LEDs can be managed through math channels according to the status of the
pushbuttons and/or the feedback coming from external devices.
They can be solid or blinking at a desired frequency and at the preferred light
level. Finally, paddle shifts feature free contacts on a dedicated pin of the
Autosport connector too.
Available as an AiM expansion or as a completely standalone device.
Pushbuttons configuration
The RGB LEDs behind all 10 pushbuttons plus back-lit multi-position switches are designed to instantly find the right input in the heat of competition.
Every single LED can be fully programmed via Race Studio 3; they can work as momentary, toggle or multistatus and each option can be configured depending on the length of time the button is pressed or on other conditions according to specific needs.
CAN Output
The data stream of each button can be managed in the CAN output.
Through this function you can customize once more your own configuration setting up each detail: the number of bytes allocated, the data length code, byte order and the frequency from 1Hz to 100Hz.
With Race Studio 3, you can also analyse all data recorded and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.
Technical specifications
- Diameter: 320mm
- CAN connections: 1
- Body: Anodized Aluminium
- Pushbuttons: 10 pushbuttons with RGB backlights
- Rotary switches: 3 rotary switches with RGB backlights
- Connectors: 1 AUtosport 22 pins male connector
- Dimensions: 320 x 176 x 43 mm
- Weight: 2,600g
- Power consumption: 500mA
- Car side Harness
- 2x Shift Paddles
GT32 Steering Wheel
GT32 transmits in a freely configurable CAN connection the status of the 10 pushbuttons (while 2 of them feature free contacts connections), 3 rotary switches and paddlesCompletely configurable pushbuttons:
Custom backlighting
RGB LEDs can be managed through math channels according to the status of thepushbuttons and/or the feedback coming from external devices.
The RGB LEDs behind all 10 pushbuttons plus back-lit multi-position switches are designed to instantly find the right input in the heat of competition.Every single LED can be fully programmed via Race Studio 3; they can work as momentary, toggle or multistatus and each option can be configured depending on the length of time the button is pressed or on other conditions according to specific needs.
CAN Output
The data stream of each button can be managed in the CAN output.Through this function you can customize once more your own configuration setting up each detail: the number of bytes allocated, the data length code, byte order and the frequency from 1Hz to 100Hz.
With Race Studio 3, you can also analyse all data recorded and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.Technical
- Diameter: 320mm
- Weight: 2,600g
- Car side Harness
- 2x Shift Paddles
