Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    Bosch LSU 4.9 Probe - AimShop.com
    LCU-RS
    Bosch LSU 4.9 Probe
    På lager, klar til afsendelse
    £125.00
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    Bosch LSU 4.9 Probe
    £125.00
    Bosch LSU 4.9 Probe
    Bosch LSU 4.9 Probe
    The wideband lambda sensor LSU 4.9 is a planar ZrO2 dual cell limiting current sensor with an integrated heater. Its monotonic output signal in the range of lambda 0.65 to air makes the LSU 4.9 capable of being used as a universal sensor for lambda one measurement and other lambda ranges. The connector module contains a trimming resistor, which defines the characteristic of the sensor.
    Installation
    Bosch LSU 4.9 Probe
    • Application: Lambda 0.65
    • Hexagon temperature: <600°C
    • Thread: M18 x 1.5
    • Weight: 120g
    Bosch LSU 4.9 Probe
    • Bosch LSU 4.9 Probe
    Technical sheet Race Studio 3
    • Opdater siden
    • Åbn i et nyt vindue
