{"product_id":"aim-sw4-280-formula-steering-wheel","title":"\u003ctc\u003eAim\u003c\/tc\u003e SW4 280 Formel Rat","description":"\u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_bCFQLY\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eDatalogging Rat\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e Formula Steering Wheel 4 270\/280 er blandt vores mest avancerede motorsportsrat til dato. Det har en intern datalogger med komplet konfiguration, aftagelige greb, drejeknapper og en lang liste af fuldt kompatible ECU- og CAN-tilslutningsmuligheder.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_3kEhi6\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eHvorfor vælge \u003ctc\u003eAim\u003c\/tc\u003e 270\/280 Rat\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e Formula-rat 270\/280 er specielt designet til professionelle motorsportsapplikationer. Den interne datalogger er fuldt konfigurerbar og er udviklet til at indsamle og vise data fra ECU'en med over 1.000 fuldt kompatible ECU-protokoller.\u003c\/p\u003e  \u003cp\u003eVores Formula-fælge fås i en række størrelser (270, 280,\u003cspan\u003e  \u003c\/span\u003e\u003ca title=\"Aim SW4 GT320\/GT350 Formula Steering Wheel\" href=\"https:\/\/www.aimshop.com\/products\/aim-sw4-gt320-gt350-formula-steering-wheel\"\u003eGT320 \u0026amp; GT350\u003c\/a\u003eDe kompakte 270- og 280-versioner er det ideelle valg til enkeltsædede biler eller sportsprototyper, hvor pladsen i cockpittet er begrænset. Forskellen mellem Formula-rattet 4 270 og 280 er den samlede diameter: 280 er 10 mm større for at imødekomme forskellige førerpræferencer.\u003c\/p\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e SW4 270\/280 Formula-rattet er også fuldt kompatibelt med vores PDM32 via CAN-kommunikation.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_cy4Jzy\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eNem forbindelse\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eTilslutning af \u003ctc\u003eAim\u003c\/tc\u003e Det er ligetil at forbinde 270\/280 Formula-rat til din ECU. Du kan sample snesevis af kanaler direkte fra ECU'en ved hjælp af en enkelt forbindelse i stedet for at installere flere analoge sensorer.\u003c\/p\u003e  \u003cp\u003eDe indsamlede data afhænger af den anvendte ECU, men omfatter typisk omdrejningstal, motorbelastning, gasspjældsposition (TPS), olie-, luft- og vandtemperaturer, olietryk, batterispænding, hastighed, gear og lambdaværdier (luft\/brændstofforhold). Listen over tilgængelige ECU-drivere opdateres og opgraderes løbende og omfatter over 1.000 forskellige ECU'er.\u003c\/p\u003e  \u003cp\u003eMed CAN-output kan du sende beskeder direkte til et eksisterende CAN-netværk, hvilket muliggør udvidet integration med andre køretøjssystemer.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_E8RKHy\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eVise \u0026amp; Trykknapper\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e Formel-rat 4 270\/280 er udstyret med et højkontrast-display 4.3\" TFT-display, fuldt konfigurerbart og kan aflæses i sollys. Med 8 gearskiftelys, 4 RGB-alarm-LED'er og en integreret omgivende lyssensor leverer rattet altid klare, præcise og pålidelige oplysninger direkte til føreren.\u003c\/p\u003e  \u003cp\u003eFormula-rattet 4 270\/280 har 10 trykknapper og 3 drejeknapper, alle baggrundsbelyste med RGB-LED'er. Det inkluderer også aftagelige greb, drejeknapper og en bred vifte af ECU- og CAN-tilslutningsmuligheder.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_nAJYLi\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eFleksible alarmer\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e SW4 270\/280 Formula-rattet har 8 konfigurerbare RGB-LED'er til gearskifte og 4 konfigurerbare RGB-LED'er til alarm. Du kan definere tilstande, farver, prioriteter og blinkfrekvenser samt vise ledsagende tekstmeddelelser, når det er nødvendigt.\u003c\/p\u003e  \u003cp\u003eDe avancerede flerfarvede RGB-skiftelys kan tilpasses fuldt ud med mulighed for at definere forskellige skiftemønstre for hvert gear.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_9enpXA\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEkstraudstyr\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDer findes et bredt udvalg af tilbehør, så du kan få mest muligt ud af dit rat:\u003c\/p\u003e  \u003cul\u003e  \u003cli\u003e  \u003ca title=\"Aim GPS09 Module\" href=\"https:\/\/www.aimshop.com\/products\/aim-gps09-gps-module\"\u003e\u003cstrong\u003eGPS-modul\u003c\/strong\u003e\u003c\/a\u003e:  GPS-modulet, der er forbundet via CAN, gør det nemt at måle omgangstid og analysere baneposition.\u003c\/li\u003e  \u003cli\u003e  \u003cstrong\u003eKoblingspadler\u003c\/strong\u003e:  Venstre\/højre koblingspaddles kan tilføjes fra tilbehøret øverst på siden, så de passer til din kørestil.\u003c\/li\u003e  \u003cli\u003e  \u003cstrong\u003eAndre udvidelser\u003c\/strong\u003e:  Udvid dit system med en række ekstrafunktioner \u003ctc\u003eAim\u003c\/tc\u003e enheder, herunder TC Hub, Lambda Controller, SmartyCam 3, RIO, GS-Dash og mere.\u003c\/li\u003e  \u003c\/ul\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cp\u003e270 mm varenummer: X07SW42700\u003c\/p\u003e  \u003cp\u003e280 mm varenummer: X07SW42800\u003c\/p\u003e","brand":"AiM Car","offers":[{"title":"Default Title","offer_id":42989426016358,"sku":"FSW4-280","price":2400.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_sw4270_280_03_1.5x.webp?v=1764769945","url":"https:\/\/www.aimshop.com\/da\/products\/mal-sw4-280-formel-rat","provider":"AimShop.com","version":"1.0","type":"link"}
