{"product_id":"aim-sw4-280-sim-racing-formula-steering-wheel","title":"\u003ctc\u003eAim\u003c\/tc\u003e SW4 280 Sim Racing Formel Rat","description":"\u003cdiv id=\"shopify-section-template--18120943861862__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eDatalogging Rat\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e 270\/280 Formel rat 4 (SW4) er et af vores mest avancerede simulator-racerrat til dato. Formula-rattet inkluderer en intern datalogger med komplette konfigurationsmuligheder, aftagelige greb, drejeknapper og fleksibel softwareintegration med simuleret telemetri.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eHvorfor vælge 270\/280 Formula-rattet\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e Formula-rat 270\/280 er specielt designet til simulator-racere. Den interne datalogger er fuldt konfigurerbar og er designet til at indsamle og vise telemetridata direkte fra din simulatorsoftware. Med understøttelse af en bred vifte af simulatorer og telemetriprotokoller er det et fremragende valg til kompakte cockpitinstallationer, hvor pladsen er begrænset.\u003c\/p\u003e  \u003cp\u003eVores Formula-rat fås i en række størrelser (270, 280,\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-sw4-gt320-gt350-sim-racing-formula-steering-wheel\" title=\"Aim SW4 GT320\/GT350 Sim Racing Formula Steering Wheel\"\u003eGT320 \u0026amp; GT350\u003c\/a\u003e). Forskellen mellem Formel SW4 270 og 280 er den samlede størrelse på rattet. Formula-rattet 280 er 10 mm større for at imødekomme alle føreres krav.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eNem forbindelse\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eTilslutning af \u003ctc\u003eAim\u003c\/tc\u003e Det er nemt at forbinde 270\/280 Formel-rat til din racersimulator. Telemetri modtages direkte fra simulatorsoftwaren, hvilket betyder, at du kan sample snesevis af kanaler uden at skulle bruge fysiske sensorer.\u003c\/p\u003e  \u003cp\u003eAfhængigt af racersimulatoren omfatter tilgængelige data typisk omdrejninger i minuttet, gashåndtagsposition, bremsetryk, gear, hastighed, brændstofniveau, dækdata, omgangstider og mere. Telemetrikompatibilitet opdateres og udvides løbende med understøttelse af mange af de mest populære racersimulatorer.\u003c\/p\u003e  \u003cp\u003eMed CAN-udgang kan du sende beskeder til andre \u003ctc\u003eAim\u003c\/tc\u003e sim-racerenheder eller udvidelser, der udvider dit cockpits udvalg af telemetri- og kontrolmuligheder.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eVise \u0026amp; Knapper\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003e270\/280 Formelsimulator-racerrattet har en høj kontrast 4.3\" TFT-skærm, der er fuldt konfigurerbar og let at aflæse under alle forhold. Med omgivende lyssensor justerer skærmen automatisk lysstyrken for at forblive klar og behagelig.\u003c\/p\u003e  \u003cp\u003eFormula-rattet har også 10 trykknapper og 3 drejeknapper, alle baggrundsbelyste med RGB-LED'er for forbedret brugervenlighed i din simulatorracerbil.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eFleksible alarmer\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e 270\/280 sim racing Formula-rattet har 8 konfigurerbare RGB-LED'er til gearskifte og 4 konfigurerbare RGB-LED'er til alarm. Du kan vælge betingelser og farver, om de skal lyse konstant eller blinke, blinkfrekvenser og vise meddelelser på skærmen ved siden af.\u003c\/p\u003e  \u003cp\u003eMed integrerede skiftelys kan du vælge mellem en række avancerede flerfarvede RGB-skiftelysmønstre, som du kan tilpasse til dine behov og endda konfigurere dem pr. gear.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_9enpXA\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEkstraudstyr\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDer findes et bredt udvalg af tilbehør, så du kan få mest muligt ud af dit rat:\u003c\/p\u003e  \u003cul\u003e  \u003cli\u003e  \u003cstrong\u003eKoblingspadler\u003c\/strong\u003e:  Vi tilbyder et koblingspaddelsæt med nederste venstre og højre paddles, eller de kan købes separat som enten venstre eller højre. Se mulighederne øverst på siden for at købe din.\u003c\/li\u003e  \u003cli\u003e  \u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-gps09-gps-module\" title=\"Aim GPS09 Module\"\u003e\u003cstrong\u003eGPS-modul\u003c\/strong\u003e\u003c\/a\u003e:  Når GPS-modulet bruges i simulatormiljøer, muliggør det beregning af omgangstid og virtuel analyse af baneposition med en database med tusindvis af baner tilgængelige.\u003c\/li\u003e  \u003c\/ul\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cp\u003e270 mm varenummer: X07SW42700\u003c\/p\u003e  \u003cp\u003e280 mm varenummer: X07SW42800\u003c\/p\u003e","brand":"AiM Sim","offers":[{"title":"Default Title","offer_id":43332277895270,"sku":"FSW4-280","price":2400.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_sw4270_280_03_1.5x_5de7949e-284b-4be0-987d-7b3aa17def08.webp?v=1761207560","url":"https:\/\/www.aimshop.com\/da\/products\/mal-sw4-280-sim-racerformel-rat","provider":"AimShop.com","version":"1.0","type":"link"}
