{"product_id":"aim-cylinder-head-thermocouple-cht-type-k","title":"Aim Termoelement af typen K til topstykke","description":"\u003cstyle\u003e\n    .LandingPage-CatTitle {\n        font-size: 24px;\n        text-align: center;\n      font-weight:600;\n    }\n    .LandingPage-CatSubTitle {\n        font-size: 22px;\n        text-align: center;\n      margin:0;\n      font-weight:600;\n    }\n    .TextBoxes {\n        font-size: 20px;\n        line-height: 32px;\n        text-align: center;\n    }\n  .features_container {\n  max-width: 1200px;\n      margin: 0 auto;\n padding-top: 20px !important;\n      padding-bottom: 20px !important;\n}\n\n.features_title {\n  font-size: 32px;\n  font-weight: 700;\n  text-align: center;\n  margin-bottom: 40px;\n  color: #333;\n  text-transform: uppercase;\n  letter-spacing: 1px;\n}\n\n.features_grid {\n  display: grid;\n  grid-template-columns: repeat(2, 1fr);\n  gap: 20px;\n  background-color: #f9f9f9;\n  padding: 30px;\n  border-radius: 8px;\n  box-shadow: 0 2px 10px rgba(0, 0, 0, 0.05);\n}\n\n.features_item {\n  font-size: 16px;\n  color: #555;\n  text-align: center;\n  padding: 15px;\n  background-color: #fff;\n  border: 1px solid #eee;\n  border-radius: 4px;\n  transition: transform 0.2s ease, box-shadow 0.2s ease;\n}\n    @media (max-width: 768px) {\n        .LandingPage-CatTitle {\n            font-size: 22px;\n        }\n        .LandingPage-CatSubTitle {\n            font-size: 20px;\n        }\n        .TextBoxes {\n            font-size: 18px;\n            line-height: 32px;\n        }\n    }\n\n\/* Mobile adjustments *\/\n@media (max-width: 600px) {\n  .features_grid {\n    grid-template-columns: 1fr; \/* Single column on mobile *\/\n    padding: 20px;\n  }\n\n  .features_title {\n    font-size: 24px;\n    margin-bottom: 30px;\n  }\n\n  .features_item {\n    font-size: 14px;\n    padding: 12px;\n  }\n}\n    \u003c\/style\u003e\n\u003ch2 class=\"LandingPage-CatTitle\"\u003eHigh-Quality Motorsport K Type Thermocouple Temperature Sensor\u003c\/h2\u003e\n\u003cp class=\"TextBoxes\"\u003eThe Aim cylinder head thermocouple (CHT) motorsport sensor allows you to measure cylinder head temperature when the sensor is placed between the spark plug and cylinder head.\u003c\/p\u003e\n\u003cdiv class=\"features_container\"\u003e\n\u003ch2 class=\"LandingPage-CatTitle\"\u003eCHT Sensor Key Features\u003c\/h2\u003e\n\u003cdiv class=\"features_grid\"\u003e\n\u003cdiv class=\"features_item\"\u003eMeasure cylinder head temperature\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003eThermocouple male fitting\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003eWide temperature range\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003e2 pin, K Type\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003eTemperature range: 0-300°C\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003eSensor cable length: 400mm\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003eDesigned for motorsport environments\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003eProfessional quality for accurate readings\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003cstyle\u003e\n  .custom_thermocouple_img {\n    max-width: 100%;\n    width: 100%;\n    height: auto;\n  }\n  @media (min-width: 768px) {\n    .custom_thermocouple_img {\n      max-width: 1140px;\n      margin: 0 auto;\n      display: block;\n    }\n  }\n\u003c\/style\u003e\n\u003cdiv\u003e\u003cimg class=\"custom_thermocouple_img\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Cylinder_Head_Thermocouple_14mm_K_Type_Motorcycle_Main_Image.png?v=1624873228\" style=\"width: 100%;\"\u003e\u003c\/div\u003e\n\u003ch2 class=\"LandingPage-CatTitle\"\u003eConnections\u003c\/h2\u003e\n\u003cp class=\"TextBoxes\"\u003eTo use the sensors with EVO4 and EVO4S data loggers, you will need a TC yellow 712 4 pin patch lead (metal binder plug). To use them with an Aim TC Hub, you will need a TC yellow 712 3 pin patch lead (metal binder plug).\u003c\/p\u003e\n\u003cp class=\"TextBoxes\"\u003eMXS, MXG, MXP and EVO5 will require a TC - TC yellow patch lead. To connect the thermocouples to these Aim dash\/loggers, you need to use the dedicated harness supplied with your device.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch2 class=\"LandingPage-CatTitle\"\u003eInstallation\u003c\/h2\u003e\n\u003cp class=\"TextBoxes\"\u003eThe Aim Cylinder Head 14mm thermocouple features a turn in its lower part for an easier installation\/uninstallation; it has to fit between the spark plug and the cylinder head.\u003c\/p\u003e\n\u003cp class=\"TextBoxes\"\u003eTo keep the sensor in contact with the cylinder head, remove the washer from the plug when installing the thermocouple.\u003c\/p\u003e\n\u003cp\u003eWhile running the thermocouple cable along with the chassis, keep it as far as possible from other lines (like RPM or lap receiver ones) to minimise cable interferences.\u003c\/p\u003e\n\u003cp class=\"TextBoxes\"\u003e\u003cstrong\u003ePlease note:\u003c\/strong\u003e Before screwing the spark plug cable back ensure that the sensor is firmly fixed to the cylinder head. While screwing it, minimise the thermocouple movements to avoid damage to the sensor.\u003c\/p\u003e\n\u003chr\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\" alt=\"Visit Aim Academy\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\" alt=\"Visit Aim Tech Support\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\" alt=\"Download Race Studio Software\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003ch3\u003eAim Cylinder Head Thermocouple 14mm K Type\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eTemperature working range: 0-300°C\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eCable sensor length: 400mm\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eCable Type: Compensated\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eTwo pins male thermocouple connection\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eK Type thermocouple\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Cylinder_Head_Thermocouple_14mm_K_Type_Motorcycle_1.png?v=1624872525\"\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAim Cylinder Head Thermocouple 14mm K Type\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eAim Cylinder Head 14mm Thermocouple Temperature Sensor\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca rel=\"noopener\" title=\"Aim Cylinder Head Thermocouple Data Sheet\" href=\"https:\/\/support.aimshop.com\/downloads\/sensors\/Datasheet_TCCHT_104_eng.pdf\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca rel=\"noopener\" href=\"https:\/\/support.aimshop.com\/downloads\/sensors\/Datasheet_TCCHT_104_eng.pdf\" title=\"AiM Cylinder Head Thermocouple Data Sheet\" target=\"_blank\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Aim Sensors","offers":[{"title":"Default Title","offer_id":29240263082086,"sku":"S-T-CHT","price":70.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_underSparkPlugTemperatureSensor_04_1.5x.webp?v=1762254711","url":"https:\/\/www.aimshop.com\/da\/products\/sigte-cylinder-hoved-termoelement-cht-type-k","provider":"AimShop.com","version":"1.0","type":"link"}
