{"product_id":"aim-non-contact-laser-ride-height-sensor","title":"Aim Non-Contact Laser Ride Height Sensor","description":"\u003ch3\u003eNon-Contact Laser Ride Height Sensor\u003c\/h3\u003e\n\u003cp\u003eThe non-contact Laser Ride Height Sensor can withstand the harsh environments of motorsport.\u003cbr\u003eThe miniature sensor has a small visible laser that reflects off the tracks surface to a precision CCD detector, determining the height from the ground.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eSuitable for all vehicles\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e60-260mm range\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e0°C to 95°C temperature range\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eStrong aluminium casing\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003cp\u003eNon-Contact Laser Ride Height Sensor\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eThe non-contact Laser Ride Height Sensor can withstand the harsh environments of motorsport.\u003cbr\u003eThe miniature sensor has a small visible laser that reflects off the tracks surface to a precision CCD detector, determining the height from the ground.\u003cbr\u003e\u003cbr\u003eLaser sensors measure distances without contact using laser radiation. It is ideal for measuring distances between moving objects.\u003cbr\u003eWith a 60 - 260mm measurement range, the sensor is ideal for use on all types of vehicles. A measurement rate of 1KHz and linearity of 0.1% ensures a fast and accurate recording of your real-time car data.\u003cbr\u003eThe ride height sensor is made with a robust aluminium casing and will protect against high vibration and temperature.\u003cbr\u003eIn the event of any damage, you can replace the plastic lens.\u003cbr\u003e\u003cbr\u003eThe lasers are classified for Laser Class 2, and the Laser operation is indicated by LED state.\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eConnections\u003c\/h3\u003e\n\u003cp\u003eMXS \/ MXP \/ MXG \/ MXL (Strada and Pista) \/ MXL2 \/ EVO5 \/ MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display\/logger and the analogue sensor, please use the 719-719 patch lead, which is available in various lengths from 0.5 - 3 metres. For most installations, you will need one of these leads.\u003cbr\u003e\u003cbr\u003eEVO4 \/ EVO4S logger \/ Channel Expansion are fitted with 712 connections and require a 712-719 patch lead to connect these sensors.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\" data-mce-style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Academy\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Tech Support\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg alt=\"Download Race Studio Software\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003ch3\u003eNon-Contact Laser Ride Height Sensor\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eMeasurement Rate: 1KHz\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eRanges: 60-260mm\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eLinearity: 0.1% of full scale\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eProtection Class: IP65\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eTemperature Range: 0°C-95°C\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eOperation Temperature: 0°C - 50°C\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eResolution: 0.02mm\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eMiniature size\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eAnalogue input: Can be swapped to CAN with CH-4 CAN device\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eVoltage Input Range: 11-16V\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Laser_Ride_Height_Engineering_Drawing.png?v=1655890110\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Laser_Ride_Height.jpg?v=1643013682\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eNon-Contact Laser Ride Height Sensor\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e1 x Non-Contact Laser Ride Height Sensor\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cbr\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"AiM Accessories","offers":[{"title":"Default Title","offer_id":31922388435046,"sku":"S-LRH","price":1230.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_nonContactLaserRideHeightSensor_00_1.5x.webp?v=1761831379","url":"https:\/\/www.aimshop.com\/de\/products\/aim-non-contact-laser-ride-height-sensor","provider":"AimShop.com","version":"1.0","type":"link"}
