{"product_id":"second-life-otk-kart-non-contact-brake-position-sensor-kit","title":"Second-Life OTK Kart Non-Contact Brake Position Sensor Kit","description":"\u003ch3\u003eComplete OTK Kart Non-Contact Brake Position Sensor Kit\u003c\/h3\u003e\n\u003cp\u003eThe non-contact brake position sensor kit for OTK kart is used to measure the brake pedal travel to see if the driver is pressing the pedal to its total capacity.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eSuitable for OTK Karts\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eCompatible with MyChron4 \u0026amp; MyChron5\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e4 pin 719 male binder connector\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eComplete with brackets \u0026amp; fittings\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch3\u003eComplete OTK Kart Non-Contact Brake Position Sensor Kit\u003c\/h3\u003e\n\u003cp\u003eThe non-contact brake position sensor kit for OTK kart is used to measure the brake pedal travel to see if the driver is pressing the pedal to its total capacity.\u003c\/p\u003e\n\u003cp\u003eThe kit has been designed specifically to fit all OTK karts and comes complete with all the necessary brackets making installation very easy.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eMain Functions\u003c\/h3\u003e\n\u003cp\u003eThe magnet mounts to the pedal and the sensor to the kart, with no messy wires getting in the way.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eIt gives an exact indication of the pedal position, measures its travel and shows all values in percentage in a 0 to 100 range.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eA straightforward way to evaluate a driver's behaviour and improve their performance.\u003c\/p\u003e\n\u003cp\u003eSuitable for use with the AIM MyChron4, MyChron5, MyChron4 2T and MyChron5 2T Kart Dash \/ Data Loggers. The sensor is complete with the patch lead required to connect the sensor to the MyChron Expansion box, connecting it to your system.\u003c\/p\u003e\n\u003cp\u003eFor images on how to fit the sensor please refer to the Technical Tab.\u003c\/p\u003e\n\u003ch2 style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/h2\u003e","brand":"Second-Life","offers":[{"title":"Default Title","offer_id":45631817515110,"sku":"212121","price":128.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/CompleteOTKKartNon-ContactBrakePositionSensorKit.png?v=1779096304","url":"https:\/\/www.aimshop.com\/de\/products\/second-life-otk-kart-non-contact-brake-position-sensor-kit","provider":"AimShop.com","version":"1.0","type":"link"}
