1 von 5
Yamaha YZF-R1 & YZF-R6 AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
SKU: SOLO2-K-YAM-2-SM-CAM-GP-2-SM-GPC-XB1SGPH22B67L200-V0256919CS-X47SOLO2DL02
Regulärer Preis
£2,210.00
Regulärer Preis
Verkaufspreis
£2,210.00
Database with more than 4,000 tracks worldwide Yamaha ECU connection cable
SmartyCam 3 GP Features:
Yamaha YZF-R1 (YEC included) - 2004-2008 Yamaha YZF-R6 (YEC included) - 2004-2016
Powerful Combination
SmartyCam GP HD 2.2
Automatic Start/Stop
Yamaha YZF-R1
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
  • SmartyCam 3 GP
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Waterproof: IP65
  • Solo 2 DL
  • Power cable with AC adapter
  • SmartyCam 3 GP - Bullet Cam
  • External CAN cable 2m
  • External power cable
  • Yamaha Plug & Play connection cable
  • Bracket
  • 2 spacers
  • 2 self-locking nuts M6
  • 2 washers M6
  • 4 washers M6
  • 2 self-locking nuts M4
  • 2 washers M4
  • 2 Allen screws with rounded head M6 x 60mm
SmartyCam GP HD 2.2
Yamaha YZF-R1
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • SmartyCam 3 GP
  • Video Out: 3G-SDI
  • Waterproof: IP65
  • Solo 2 DL
  • Bracket
  • 2 spacers
  • 2 washers M6
  • 4 washers M6
  • 2 washers M4
