{"product_id":"aim-22-pin-deutsch-harness-evo5-evo6","title":"Aim 22-Pin Deutsch Harness for EVO5 \/ EVO6","description":"\u003ch3\u003eAim EVO5 22 Pin Deutsch Harness\u003c\/h3\u003e\n\u003cp\u003eThe Aim EVO5 22 pin Deutsch harness has been designed as an optional harness to add extra data to your device.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eSuitable for EVO5\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eOptional 22 harness\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e 4 analogue channels\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch3\u003e 22 pin Harness for EVO5\u003c\/h3\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eThe Aim 22 pin Deutsch harness for the EVO5 is an optional harness to add extra channels (sensors) and advanced functions to your device.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eSeveral of the advanced functions rely on this harness, which is not included with the 37 pin harness which comes as standard with the EVO5.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eThe Aim 22 pins Deutsch harness functions are listed below:\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eAnalogue sensor channels 5, 6, 7, 8\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eDigital wheel speed sensor inputs 2, 3, 4\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eDigital 12V outputs 1, 2\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eRS232TX\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eThe standard 37 pin harness that comes with the EVO5 allows 4 inputs. If you would like to add more inputs to your race data then add this optional harness.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eAdding analogue sensors greater than 4 - The standard harness will allow 4 analogue channels (sensors) - (1) Water Temperature, (2) Oil Temperature, (3) Oil Pressure, and (4) Brake Pressure.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eUsing the 22 pin harness you can add four more analogue channels (sensors) (5) Steering Angle, (6) Throttle Position, (7) Gear Box, and (8) Differential Temperature.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan data-preserver-spaces=\"true\"\u003ePlease Note:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan data-preserver-spaces=\"true\"\u003e If you wish to add extra race data then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.\u003c\/span\u003e\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/MXL2_Expand_your_system.png?v=1622540800\"\u003e\u003c\/h3\u003e\n\u003ch3\u003eExpand Your System\u003c\/h3\u003e\n\u003cp\u003eThese are some of the items that can be added to your car for incrementing performance and data.\u003c\/p\u003e\n\u003ch4\u003e\u003cbr\u003e\u003c\/h4\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Academy\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Tech Support\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg alt=\"Download Race Studio Software\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical\u003c\/h5\u003e\n\u003ch3\u003eAim EVO5 22 Pin Deutsch Harness\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e22 pin Deutsch Female Flying Connector\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e4 pins Binder 719 Female connector - See table in Downloads Tab\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eNon-ended cables - See table in Downloads Tab\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_EVO5_22_Pin_Deutsch_Harness_Technical_Pinout.png?v=1622624891\" alt=\"\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAim EVO5 22 Pin Deutsch Harness\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eEVO5 22 Pin Deutsch Harness \u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca title=\"22 Pin Deutsch Harness for EVO5 Technical Sheet\" href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Cablaggio_Standard_EVO5_101_eng.pdf?v=1595332455\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"22 Pin Deutsch Harness for EVO5 Technical Sheet\" href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Cablaggio_Standard_EVO5_101_eng.pdf?v=1595332455\" target=\"_blank\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"AiM Accessories","offers":[{"title":"Default Title","offer_id":25223837831,"sku":"EVO5-H22","price":388.95,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_22pinharnessEVO_00_1.5x.webp?v=1760361414","url":"https:\/\/www.aimshop.com\/en-pt\/products\/aim-22-pin-deutsch-harness-evo5-evo6","provider":"AimShop.com","version":"1.0","type":"link"}
