    €0,00 EUR
    Aim 37 Pin Deutsch Harness For MX Series - AimShop.com
    H37-V02573010
    In stock, ready to ship
    €448,95 EUR
    €448,95 EUR
    The Aim 37 pin Deutsch Harness is the standard harness supplied with our MX Series Dash Loggers.
    Suitable for MXS, MXP, MXG & MXm Standard harness
     37 pin harness
    37 Pin Harness for the MX Series
    The Aim 37 pins harness is the standard harness that comes with the MX Series Dash Loggers - MXS, MXP, MXG & MXm.
    The Aim 37 pins Deutsch harness functions are listed below:
    Digital wheel speed channel 1
    CAN expansion
    Power+
    Ground-
    CAN ECU connection
    K-Line connection
    Please Note: If you wish to add extra race data, then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.
    Also available is our 37 pins Deutsch harness with a thermocouple connector. These are available with 1 or 2 thermocouple connectors and will enable you to connect thermocouple sensors.
    These are some of the items that can be added to your car to improve performance and data.
    • 7 non-ended cables - See table in Downloads Tab
    • 37 pin Deutsch Harness
    37 Pin Deutsch Harness Technical Sheet
    RS3 Software
    Technical sheet Race Studio 3
