    €0,00 EUR
    Aim Brake Pressure Sensor 0-160 Bar - AimShop.com
    0-160 Bars
    4-Pin 719 Male Binder
    Suitable for Motorsport
    S-P-B-
    In stock, ready to ship
    €221,95 EUR
    0-160 Bars
    €221,95 EUR
    The Aim 0-160 bar pressure sensor is suitable for oil and fuel pressure readings and can read pressures up to 160 bars. This sensor will monitor brake pressure levels for optimum performance accurately.
     0-160 Bar 4 pins 719 male binder
    The Aim 0-160 Bar brake pressure sensors are fitted with male four pins black 719 binder plug connections to suit all Aim loggers and dash display/loggers.
    The sensors can be easily installed in a -3 brake line using a three-way T-piece. It can also use them for measuring other pressures too high for the 0-10 Bar sensor. Available with an M10 or -3 JIC (3/8-24 UNF) thread.
    • Supply: 8-16V
    • Consumption: < 10 mA
    • Sealing: IP66
    • Weight: 30g
    • Cable Length: 400mm
    • Aim Brake Pressure Sensor 0-160 Bar
    Technical sheet Race Studio 3
