{"product_id":"aim-fuel-pressure-sensor-0-50-psi","title":"Aim Fuel Pressure Sensor 1\/8 NPT 0-50 PSI","description":"\u003ch3\u003eAim Oil \/ Fuel Pressure Sensor 0-50 PSI\u003c\/h3\u003e\n\u003cp\u003eThe Aim pressure sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 5 bars.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e0-50 PSI\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e4 pins 719 male binder\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch3\u003eAim Oil \/ Fuel Pressure Sensor  0-50 PSI\u003c\/h3\u003e\n\u003cp\u003eThe 0-50 PSI pressure sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 50 PSI.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eThe 0-50 PSI pressure sensor is fitted with a male four pins 719 binder connector to suit our loggers and dash display\/loggers. \u003cbr\u003eMany aspects affect the various engine pressures, so knowing your engine has the correct amount of pressure is paramount to longevity and performance.\u003c\/p\u003e\n\u003cp\u003eThis sensor is also available in 1\/8 NPT thread options.\u003c\/p\u003e\n\u003cdiv class=\"mw-option__value mw-option__value--has-title mw-option__value--base\" data-value-id=\"v_19737223\"\u003e\n\u003cdiv class=\"mw-stack mw-stack--alignment-center\"\u003e\n\u003cdiv class=\"mw-stack__item mw-stack__item--fill\"\u003e\n\u003cdiv class=\"mw-stack mw-stack--alignment-center\"\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eConnections\u003c\/h3\u003e\n\u003cp\u003eMXS, MXG, MXP, MXL (Strada \u0026amp; Pista), MXL2, EVO5, MXm harnesses are fitted with 719 connections. To extend the length between your dash display\/logger and the analogue sensor, you will require our 719-719 patch lead available in various sizes from 0.5m - 4 meters in length. For most installations, you will need one of these patch leads.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eEVO4, EVO4S Data Logger, Channel Expansion are fitted with 712 connections and require a 712-719 patch lead to connect the sensor. This patch lead is available in 0.5m - 4-meter lengths. Patch leads are available in the optional extras.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Academy\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Tech Support\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg alt=\"Download Race Studio Software\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003ch3\u003eAim Oil \/ Fuel Pressure Sensor 0-50 PSI\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cb\u003eSupply: \u003c\/b\u003e8-16V\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eAccuracy:\u003c\/strong\u003e \u0026lt; +\/- 0.5% FS (CLNH – combined non-linearity and hysteresis)\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eCharacterisation:\u003c\/strong\u003e 500 mV\/ 0 bar 4500 mV\/ 5 bar\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eConsumption:\u003c\/strong\u003e \u0026lt; 10 mA\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eTemperature working range:\u003c\/strong\u003e from -20°C to 135°C\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eSealing:\u003c\/strong\u003e IP66\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eHousing:\u003c\/strong\u003e 316 stainless steel\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eWeight:\u003c\/strong\u003e 30g\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eCable Length:\u003c\/strong\u003e 400mm\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Oil_Fuel_Pressure_Sensor_M10_0-5_Bar.png?v=1624351926\" alt=\"\"\u003e\u003c\/p\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAim Oil \/ Fuel Pressure Sensor 0-5 Bar\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eAim 0-5 bar pressure sensor\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Datasheet_Pressure0-5Bar_101_eng_a8bc54e4-158e-4192-bed1-bbe1eb6b7d4a.pdf?v=1624355927\" title=\"AiM Oil \/ Fuel Pressure Sensor M10 0-5 Bar Technical Sheet\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Datasheet_Pressure0-5Bar_101_eng_a8bc54e4-158e-4192-bed1-bbe1eb6b7d4a.pdf?v=1624355927\" title=\"AiM Oil \/ Fuel Pressure Sensor M10 0-5 Bar Technical Sheet\" target=\"_blank\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Aim Sensors","offers":[{"title":"Default Title","offer_id":44246696362086,"sku":"S-P-NPT-50","price":224.95,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/50PSI.png?v=1765877985","url":"https:\/\/www.aimshop.com\/en-pt\/products\/aim-fuel-pressure-sensor-0-50-psi","provider":"AimShop.com","version":"1.0","type":"link"}
