{"product_id":"aim-lcu2-lambda-controller","title":"Aim LCU2 Lambda Controller","description":"\u003cdiv id=\"shopify-section-template--19946567630950__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eFull Control Of Your Engine\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe brand-new Aim LCU2 Lambda Controller has been developed to give drivers, tuners, and race teams complete control over engine carburetion and air\/fuel performance. Designed for precision tuning across motorsport and performance applications, the LCU2 delivers highly accurate Lambda readings while introducing dual sensor capability for even greater monitoring and control.\u003c\/p\u003e\n\u003cp\u003eWhether you're optimising power, improving drivability, or protecting engine reliability, the LCU2 provides the data you need to keep your engine performing at its best.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--19946567630950__video_with_text_7Gk3xi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"image-with-text lg:flex lg:gap-8 lg:flex-row-reverse overflow-hidden\"\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 relative\"\u003e\n\u003cdiv class=\"image-with-text__media h-full\"\u003e\n\u003ch2 class=\"media media--height block w-full h-full relative overflow-hidden\"\u003e\u003cstrong\u003eWhy Choose the Aim LCU2 Lambda Controller\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 align-self-center\"\u003e\n\u003cdiv class=\"rich-text lg:text-left text-left relative z-1\"\u003e\n\u003cdiv class=\"rte body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe Aim LCU2 accurately measures Lambda values, offering the precision required for serious engine tuning and calibration.\u003c\/p\u003e\n\u003cp\u003eBy analysing residual oxygen levels in the exhaust gases, the LCU2 identifies rich or lean carburetion conditions, helping you fine-tune fuelling for maximum efficiency.\u003c\/p\u003e\n\u003cp\u003eWith dual Lambda sensor support, proven Bosch wideband technology, CAN integration, and motorsport-grade reliability, the Aim LCU2 is the next evolution in air\/fuel monitoring and engine tuning.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--19946567630950__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eNew Dual Lambda Sensor Capability\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eA major upgrade for the new LCU2 is the ability to connect two Lambda probes simultaneously.\u003c\/p\u003e\n\u003cp\u003eThis allows:\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003eMonitoring of dual-bank or V-engine exhaust systems\u003c\/li\u003e\n\u003cli\u003eComparison between left and right cylinder banks\u003c\/li\u003e\n\u003cli\u003eGreater fuelling accuracy across multiple exhaust outlets\u003c\/li\u003e\n\u003cli\u003eEnhanced diagnostics and engine balancing\u003c\/li\u003e\n\u003cli\u003eMore precise tuning for high-performance applications\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eFor race engineers and tuners, dual-sensor support delivers a significant advantage in both setup accuracy and engine safety.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--19946567630950__image_with_text_bQqm6D\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"image-with-text lg:flex  lg:flex-row-reverse overflow-hidden\"\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 align-self-center\"\u003e\n\u003cdiv class=\"rich-text lg:text-left text-left relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-sm\"\u003e\u003cstrong\u003eBosch LSU 4.9 Wideband Sensor Technology\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe LCU2 uses the trusted Bosch LSU 4.9 wideband sensor, selected for its long-term precision and stable calibration retention throughout the sensor’s service life.\u003c\/p\u003e\n\u003cp\u003eEngineered for durability, the Bosch LSU 4.9 probe is designed to last for over 100,000 km under standard operating conditions, giving you dependable performance session after session.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--19946567630950__rich_text_aRqVAB\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003ePrecision, Reliability \u0026amp; Fuel Flexibility\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe configurable stoichiometric ratio allows the LCU2 to be used across a wide range of fuel types, including petrol, diesel, ethanol blends as well as alternative performance fuels.\u003c\/p\u003e\n\u003cp\u003eThis flexibility is what makes the LCU2 suitable for road, race, track day, karting, motorcycle, and specialist engine applications.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--19946567630950__rich_text_37Vr4z\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eSeamless Aim Integration\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe LCU2 integrates directly with Aim data logging and dashboard systems via CAN bus, allowing Lambda data to be viewed live, logged during sessions, and analysed afterwards alongside other critical engine parameters.\u003c\/p\u003e\n\u003cp\u003eThis enables deeper insight into:\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003eFuel mixture behaviour\u003c\/li\u003e\n\u003cli\u003eRPM and throttle relationship\u003c\/li\u003e\n\u003cli\u003eGear-based fuelling trends\u003c\/li\u003e\n\u003cli\u003eTemperature and pressure correlation\u003c\/li\u003e\n\u003cli\u003ePerformance consistency lap after lap\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--19946567630950__image_with_text_kEcDrX\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"image-with-text lg:flex  lg:flex-row-reverse overflow-hidden\"\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 align-self-center\"\u003e\n\u003cdiv class=\"rich-text lg:text-left text-left relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-sm\"\u003e\u003cstrong\u003eExpand Your System\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte body subtext-md leading-normal\"\u003e\n\u003cp\u003eBuilt for demanding environments, the LCU2 features a compact and durable design suitable for installation in:\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003eRace cars\u003c\/li\u003e\n\u003cli\u003eRally cars\u003c\/li\u003e\n\u003cli\u003eMotorcycles\u003c\/li\u003e\n\u003cli\u003eMotocross bikes\u003c\/li\u003e\n\u003cli\u003eKarting applications\u003c\/li\u003e\n\u003cli\u003eCustom performance builds\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e","brand":"Aim Sensors","offers":[{"title":"Default Title","offer_id":45534651842662,"sku":"LCU2","price":375.95,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_lcu2_00_1.5x.webp?v=1776940225","url":"https:\/\/www.aimshop.com\/en-pt\/products\/aim-lcu2-lambda-controller","provider":"AimShop.com","version":"1.0","type":"link"}
