{"product_id":"aim-mxs-5-tft-powerboat-dash-display-logger","title":"Aim MXS 1.3 5\" TFT Powerboat Dash Display Logger","description":"\u003ch3\u003eAim MXS 1.3 TFT Digital Display and Data Logger\u003c\/h3\u003e\n\u003cp\u003eThe MXS 1.3 dash logger has a 5\" TFT display which has been designed to acquire and display data coming from the ECU.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e5\" compact TFT display\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eGPS Module\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eCAN output\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e6 configurable RGB LEDs\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eTwo digital outputs\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eWi-Fi connectivity\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eIntegrated shift array\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e1,000+ industry-leading ECUs\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_MXS_1.2_TFT_Digital_Display_and_Data_Logger_main_description.png?v=1615292937\"\u003e\u003c\/p\u003e\n\u003ch3\u003eAim MXS 1.3 TFT Digital Display and Data Logger\u003c\/h3\u003e\n\u003cp\u003eThe MXS 1.3 5\" TFT compact Dash Logger is fully configurable and suitable for many different motorsports. It has been designed to acquire and display data coming from the ECU. Analogue\/digital inputs and predefined math channels. Performance and data acquired can also be incremented by adding up to eight expansion modules. The MXS 1.3 is a great choice for compact cockpit installations where space is at a premium.\u003c\/p\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eEasy Connection\u003c\/strong\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eConnecting the MXS 1.3 dash to your ECU is simple. You can sample dozens of channels straight from the vehicles ECU. This is usually the quickest and easiest setup, needing only a cable connection to the ECU instead of multiple connections and analogue sensors. The sampled data will depend on your actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, lambda value (air\/fuel ratio). The list of available ECU drivers is constantly updated and upgraded and includes approximately 1000+ different  ECUs.\u003c\/p\u003e\n\u003ch4\u003e\u003cstrong\u003eTwo Digital Outputs\u003c\/strong\u003e\u003c\/h4\u003e\n\u003cp\u003eMXS 1.3 features two digital outputs. Each of them can give an output of 1 amp at 12 volts. They can be configured to be turned on\/off depending on the value of the analogue or digital inputs. They permit automatic running of external systems such as switching on\/off additional lights, activating\/deactivating a cooling fan or circulation pumps when a certain event happens.\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eDisplay\u003c\/h3\u003e\n\u003cp\u003eWith a high contrast 5\" TFT display which is fully configurable. You can create and customise pages\/displays to suit your requirements. Swapping pages can be managed by pushing on or two push buttons.\u003c\/p\u003e\n\u003cp\u003eTwo analogue camera inputs are available, to switch your display into a mirror camera, through a push button command or event management. The camera is sold separately.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eFlexible Alarms\u003c\/h3\u003e\n\u003cp\u003eThe MXS has six configurable RGB LEDs. You can choose the conditions and colours. Select a solid alarm or flashing one and the flashing frequency, you can choose to have an accompanying text message and set the alarm priorities.\u003c\/p\u003e\n\u003cp\u003eWith integrated shift lights, you can choose from a host of advanced multi-coloured RGB shift light patterns that can be customised to suit your requirements, and for each unique gear when required.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eCAN output\u003c\/h3\u003e\n\u003cp\u003eWith the CAN Output, you can send messages directly to an existing CAN network to improve the range of vehicle control possibilities.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eGPS Module\u003c\/h3\u003e\n\u003cp\u003eThe GPS Module connected via CAN to the MXS makes lap time calculation and track position analysis easy. With 4000+ worldwide tracks already stored with the start and finish line coordinates you will have no problem when you're on the track. As soon as the MXS is turned on the GPS Module will locate its position, identify track line coordinates and start immediately sampling lap and split time. If the track is not on the database, you can easily add the start\/finish line coordinates to the MXS via a PC before you go to the track using our Race Studio 3 software.\u003c\/p\u003e\n\u003cp\u003eThe GPS Module is available in 0.50m, 1.3m, 2m, 4m, or a roof version in 2m, 4m length cables.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_MXG_1.2_7_TFT_Dash_Display_Logger_Pin_Harness.png?v=1615284254\"\u003e\u003c\/p\u003e\n\u003ch3\u003ePin Harness\u003c\/h3\u003e\n\u003cp\u003eThe 37 pin harness comes standard in the kit, should you need more data you can add our 22 pin harness as an optional extra.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003cp\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_MXS_1.2_TFT_Digital_Display_and_Data_Logger_Expand_you_system.png?v=1615292646\"\u003e\u003c\/p\u003e\n\u003ch3\u003eExpand Your System\u003c\/h3\u003e\n\u003cp\u003eThese are only some of the items that can be added to our MXS 1.3 for incrementing the performance and the data acquired.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Free_Download.png?v=1629297377\" style=\"width: 100%;\"\u003e\u003c\/a\u003e\u003c\/p\u003e\n\u003ch3\u003eConfigure \u0026amp; Analyse with Race Studio 3\u003c\/h3\u003e\n\u003ch4\u003eConfiguration\u003c\/h4\u003e\n\u003cp\u003eWith Race Studio 3, you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps by watching the video recorded by SmartyCam HD cameras.\u003c\/p\u003e\n\u003ch4\u003eAnalysis\u003c\/h4\u003e\n\u003cp\u003eWith Race Studio 3, you can also analyse all data recorded by MXS 1.3 and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Academy\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Tech Support\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg alt=\"Download Race Studio Software\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003ch3\u003eAim MXS 1.3 TFT Digital Display and Data Logger\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eDisplay:\u003c\/strong\u003e 5\" Display\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eResolution:\u003c\/strong\u003e 800 x 480 pixels\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eContrast:\u003c\/strong\u003e 600:1\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eBrightness\u003c\/strong\u003e: \u003cspan data-mce-fragment=\"1\"\u003e700cd\/m2 - 1,100 Lumen\u003c\/span\u003e\n\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eAmbient Light Sensor:\u003c\/strong\u003e Yes\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eAlarm LEDs:\u003c\/strong\u003e 6 RGB freely configurable\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eShift Lights:\u003c\/strong\u003e 10 integrated freely configurable RGB LEDs\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eCAN connections:\u003c\/strong\u003e 3\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eECU connections:\u003c\/strong\u003e CAN, RS232 or K-Line\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eECU compatibility:\u003c\/strong\u003e + 1,000 industry leading ECUs\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eExpansion CAN connection:\u003c\/strong\u003e GPS, Channel Expansion, Thermocouple Expansions, Lambda Controller, SmartyCam HD\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eAnalogue Inputs:\u003c\/strong\u003e 8 fully configurable, max 1,000Hz each\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eDigital Inputs:\u003c\/strong\u003e 4 Speed inputs, lap signal, coil RPM input\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eDigital Outputs:\u003c\/strong\u003e 2 (1A max each)\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eSecond CAN:\u003c\/strong\u003e Yes\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eWi-Fi connection:\u003c\/strong\u003e Yes\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eInternal Memory:\u003c\/strong\u003e 4GB\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eBody:\u003c\/strong\u003e Anodised Aluminium\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003ePush Buttons:\u003c\/strong\u003e Metallic\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eConnectors:\u003c\/strong\u003e 2 Motorsport connectors + 1 Binder connector\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cb\u003ePower Consumption: \u003c\/b\u003e400mA\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eDimensions:\u003c\/strong\u003e 169.4 X 97 X 23mm\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eWeight:\u003c\/strong\u003e 530g\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eWaterproof:\u003c\/strong\u003e IP65\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_MXS_1.2_TFT_Digital_Display_and_Data_Logger_tech_specs.png?v=1615293272\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAiM MXS 1.3 TFT Digital Display and Data Logger\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eMXS 1.3 Dash Logger\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e37 Pin standard harness\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eGPS Module with cable\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eUSB Cable\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eAiM Sticker\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/MXG1.2_MXP_MXS1.2_user_guide_100_eng-2.pdf?v=1594373159\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/User_Guide_AiM_iCON_2289456f-97fa-4d13-84ea-3ede554821e9_100x100.png?v=1590766826\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/aim_mxs_1.3_100.pdf?v=1656423242\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/aim-software\/\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/MXG1.2_MXP_MXS1.2_user_guide_100_eng-2.pdf?v=1594373159\" target=\"_blank\"\u003eUser Guide\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/aim_mxs_1.3_100.pdf?v=1656423242\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/aim-software\/\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"AiM Powerboat","offers":[{"title":"Default Title","offer_id":31968041009254,"sku":"MXS-","price":2483.95,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_mxs_00_eb241902-41b8-4a66-bce3-2e6a09b667fc.webp?v=1757594681","url":"https:\/\/www.aimshop.com\/en-pt\/products\/aim-mxs-5-tft-powerboat-dash-display-logger","provider":"AimShop.com","version":"1.0","type":"link"}
