{"product_id":"aim-mxs-mxp-mxl2-dash-bracket","title":"Aim MXS, MXP \u0026 MXL2 Dash Bracket","description":"\u003ch2 style=\"text-align: center;\"\u003e\u003cstrong\u003eMXS \/ MXP \/ MXL2 Dash Bracket\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cp style=\"text-align: center;\"\u003e\u003cbr\u003eThis bracket has been designed to mount the MXS \/ MXP \/ MXL2 dash.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cbr\u003eKey Features:\u003c\/strong\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\n\u003cul\u003e\n\u003cli\u003eSuitable for MXS, MXP, MXL2 dash\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/td\u003e\n\u003ctd\u003e\n\u003cul\u003e\n\u003cli\u003e2mm stainless steel\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e\n\u003cul\u003e\n\u003cli\u003eFree race studio 3 download\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/td\u003e\n\u003ctd\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch3 style=\"text-align: center;\"\u003e\u003cstrong\u003eMXS, MXP, MXL2 Dash Bracket\u003c\/strong\u003e\u003c\/h3\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cdiv style=\"text-align: start;\"\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cp\u003e \u003c\/p\u003e\nDue to the size of the Dash, this will probably more likely be used with our single mount centre hub on the steering column or our chassis weld-on and bolt-on tabs. Though this will work without steering wheel mounts if you prefer.\u003cbr data-mce-fragment=\"1\"\u003e\u003cbr data-mce-fragment=\"1\"\u003e\u003cstrong\u003eOptional\u003c\/strong\u003e Weld on the tab for your chassis or steering column.\u003cbr data-mce-fragment=\"1\"\u003e\u003cbr data-mce-fragment=\"1\"\u003e2mm thick in Raw Stainless Steel\u003cbr data-mce-fragment=\"1\"\u003e\u003cbr data-mce-fragment=\"1\"\u003eOur Modular Steering Wheel Components are Stainless Steel (raw finish) interchangeable components to facilitate the mounting of displays\/buttons\/dash\/lap timer\/shift lights.\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eAiM Technologies are committed to supplying, professional engineers with quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the marketplace today.\u003c\/span\u003e\u003c\/p\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e\n\u003ch3 style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/h3\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\n\u003ch3\u003e\u003cstrong\u003eUnlock your potential\u003c\/strong\u003e\u003c\/h3\u003e\n\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\n\u003cdiv style=\"text-align: center;\"\u003e\u003ca href=\"#epopup1591936900\"\u003e\u003cimg style=\"width: 100%;\" alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Race_Studio_3_Description_Footer.png?v=1590672627\"\u003e\u003c\/a\u003e\u003c\/div\u003e\n\u003c\/td\u003e\n\u003ctd\u003e\n\u003cdiv style=\"text-align: start;\"\u003e\u003ca href=\"#epopup1590758196\"\u003e\u003cimg style=\"width: 100%;\" alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Academy_Product_Description_Footer.png?v=1590672588\"\u003e\u003c\/a\u003e\u003c\/div\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003eOur mission is to help educate you and enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn.\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cbr\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cul\u003e\u003c\/ul\u003e\n\u003ch5\u003eTechnical  \u003c\/h5\u003e\n\u003cp\u003eAiM MXS, MXP \u0026amp; MXL2 Dash Bracket\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e160mm x 60mm bolt holes for dash\u003c\/li\u003e\n\u003cli\u003e2mm thick in raw stainless steel\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003ch5\u003eWhats In The Box\u003c\/h5\u003e\n\u003cp\u003eAiM MXS, MXP \u0026amp; MXL2 Dash Bracket\u003c\/p\u003e\n\u003cp style=\"text-align: center;\"\u003e \u003c\/p\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003e\u003cimg style=\"display: block; margin-left: auto; margin-right: auto;\" alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\"\u003e\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cspan style=\"color: #2b00ff;\"\u003e\u003ca data-ce-key=\"2049\" title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/support\/software\/Race%20Studio%203-64_33206_048710_009654_20200526_163723.exe\" target=\"_blank\"\u003e\u003cbr\u003e\u003c\/a\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/span\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003cbr\u003e\u003cbr\u003e\u003c\/p\u003e","brand":"AiM Accessories","offers":[{"title":"Default Title","offer_id":32313552928870,"sku":"UP-MXL","price":23.95,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_MXSeriesDashBracket_00_1.5x.webp?v=1762769655","url":"https:\/\/www.aimshop.com\/en-pt\/products\/aim-mxs-mxp-mxl2-dash-bracket","provider":"AimShop.com","version":"1.0","type":"link"}
