    €0,00 EUR
    Potentiometer Replacement Rose End Fitting - AimShop.com
    CASUS-POT-END-RJ
    In stock, ready to ship
    €12,95 EUR
    €12,95 EUR
    Replacement rose end joint fitting for the suspension potentiometer.
    Replacement rose end fitting Spare or replacement parts
    The Potentiometer rose joint fitting is a replacement part to fit the suspension potentiometer used to measure displacement between two points using a sensor.
    Use as a replacement or spare part.
    One Potentiometer Rose End Fitting Replacement Supplied.
    • Replacement Potentiometer Rose End Fitting
    • 1 x Rose End Fitting Potentiometer Replacement Fitting
