Aim SmartyCam Bullet Cam Roll Cage Mount
SKU: SM-VB-GP
€94,95 EUR€113,94INC VAT - UK only
- €94,95 EUR
Aim SmartyCam Roll Cage Mount 2.1 & 2.2 & 3
The SmartyCam GP & Dual 2.1 & 2.2 & 3 (bullet camera) roll cage mount has been designed to hold and position the bullet camera.
Fits the SmartyCam bullet camera | Ball & socket adjustment system |
Clamp to a wide range of diameter tubing | For SmartyCam GP & Dual 2.1 & 2.2 & 3 |
The Aim SmartyCam roll cage mount has been designed to securely mount the SmartyCam GP & Dual 2.1 & 2.2 & 3 bullet camera.
Roll Cage Mount
With Race Studio 3, you can also analyse all data recorded and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.
- For use with SmartyCam GP & Dual 2.1 & 2.2 & 3 bullet cameras
- Handlebar bracket
- 60mm arm
- Ball head
- Bullet cam bracket
Technical sheet | Race Studio 3 |
The SmartyCam GP & Dual 2.1 & 2.2 & 3 (bullet camera) roll cage mount has been designed to hold and position the bullet camera.Key Features :
The Aim SmartyCam roll cage mount has been designed to securely mount the SmartyCam GP & Dual 2.1 & 2.2 & 3 bullet camera. The roll cage bracket (v-bracket) adjusts using a ball and socket system for optimum positioning and simply clamps to roll bars of a wide range of diameters. The 44mm & 55mm tube clamps enable you to attach the mount to different sized roll bars.Roll Cage Mount
Includes a handlebar bracket, and a rubber lining to prevent slipping and vibrations.Also, the bullet cam bracket can be positioned for your required viewing.
With Race Studio 3, you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps by watching the video recorded by SmartyCam HD cameras.Analysis
With Race Studio 3, you can also analyse all data recorded and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances. ![]() |
- Handlebar bracket
- 60mm arm
- Ball head
