AiM SmartyCam GP HD Roll Cage Mount for Recording Box 2.1 & 2.2 Motocross
SKU: SM-VB-GP-R - X90KSGPRB
- €96,95
- €96,95
AiM SmartyCam GP HD Roll Cage Mount For Recording Box
The SmartyCam GP HD can be installed using the GP HD roll cage mount. It is suitable for SmartyCam GP HD 2.1 and 2.2 SmartyCams.
Secure mounting for SmartyCam | Ball & socket system |
Complete with fitting kit | For GP HD 2.1 & 2.2 |
The AiM SmartyCam GP HD roll cage mount for the recording box is for mounting the SmartyCam's recording box to a roll bar, railing or tubing.
The roll bar mount has a unique ball and socket system which offers optimum positioning and has been designed to cope with the rigours of motorsport.
The mount will keep the recording box safe and secure and can be placed in a position clear from the driver so it doesn't get in the way.
Roll Cage Mount
Securely attaches to any roll bar, railing or tube.
AiM SmartyCam GP HD Roll Cage Mount For Recording Box 2.1 & 2.2
- For use with SmartyCam 2.1 & 2.2 GP HD
- Handlebar bracket
- 90mm arm
- Clamp base with ball
- Mounting brackets
- Locknut
- Washers and screws
The SmartyCam GP HD can be installed using the GP HD roll cage mount. It is suitable for SmartyCam GP HD 2.1 and 2.2 SmartyCams.Key Features :
The AiM SmartyCam GP HD roll cage mount for the recording box is for mounting the SmartyCam's recording box to a roll bar, railing or tubing.The roll bar mount has a unique ball and socket system which offers optimum positioning and has been designed to cope with the rigours of motorsport.
Roll Cage Mount
Includes a rubber insert and lock nuts for a secure fit.A solid ball and socket type system for optimum positioning.
- Handlebar bracket
- 90mm arm
- Mounting brackets
- Locknut
