AiM SmartyCam GP HD Bullet Cam U Bolt Mount 2.1 & 2.2 Motorcycle
SKU: SM-UB-GP-MC
- €95,95 EUR
- €95,95 EUR
The SmartyCam GP HD 2.1 & 2.2 (Bullet Camera) U bolt mount has been designed to hold and position the bullet camera.
Suitable for 0.5 to 1.2" bar | For SmartyCam GP HD 2.1 & 2.2 |
The AiM SmartyCam GP HD U bolt mount is for mounting a SmartyCam GP HD 2.1 & 2.2 to your vehicle. The mount has been designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2".
The U bolt clamp has a unique ball and socket system which has been designed to cope with the rigours of motorsport.
U Bolt Mount
Securely attaches to any rollbar, railing or tube with a diameter of 0.5 to 1.2"
- 60mm (2.36inches) arm
- U bolt
- 60mm arm
- Ball head
- Bullet cam bracket
The SmartyCam GP HD 2.1 & 2.2 (Bullet Camera) U bolt mount has been designed to hold and position the bullet camera.Key Features :
The AiM SmartyCam GP HD U bolt mount is for mounting a SmartyCam GP HD 2.1 & 2.2 to your vehicle. The mount has been designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2". The U bolt clamp has a unique ball and socket system which has been designed to cope with the rigours of motorsport.U Bolt Mount
Includes a rubber insert and lock nuts for a secure fit.A solid ball and socket system for optimum positioning.
- U bolt
- 60mm arm
- Ball head
