Skip to product information
1 of 1
AiM VIM Pre Configured Vehicle Interface Module
SKU: VIM
€301,95
€301,95
The Motorcycle VIM Module is manufactured in the UK by AIM Technologies.
The Motorcycle VIM Module (Vehicle Interface Module) is a small compact input device, providing a simple way to input voltage signals to the dash.The module allows for connection of lights, left and right indicators, dipped beam, main beam, hazard warning, in fact up to 14 independent voltage inputs, that are then sent to the display or logger through the CAN II stream, allowing you to turn on the symbols or lights on the display.
The VIM Expansion adds up to 14 freely configurable analogue channels without occupying or modifying any of the existing system channels, leaving them free for anything else. This simply goes next to the fuse box, and picks up the 12v signal to the light to turn the lights on the dash on. It leaves the 4 analogue ones free, if needed in  future Connection Examples
VIM
By using advanced CAN technology, wiring is simplified from four cables into just a single connection, thereby reducing possible and unnecessary points of failure.
Instructions Race Studio Setup
Part 1 – Installing the VIM CAN Protocol
First download and save this file to your desktop
Download Input Switch RS3 Mod ↴
(We recommend the desktop for easier installation, it can be deleted after )
  • Open RS3 Go to the Spanner in the top left
  • Press on import CAN Protocols
  • Find the attached file (saved to desk top)
  • Select open, and you’re finished,
  • You will then see it appear in the dash config under CAN2 Stream
vim install 1
Part 2
  • Whilst in RS3, go to the dash configuration screen of your logger / Display and select CAN 2 stream
  • Then select the Aim Tech Switch Input Module
Here you will see all 14 input channels, for ease we will select channel 1, and use it for the indicators, so simply click on it, and change the name
install pt2
Once selected, go to the alarms page, and create a new alarm for CAN2
You will see all channels here, as named
install pt 2a
Next, choose the Indicators tab, and set up the alarm as below, so every time the VIM sends out a signal to the dash, it turns on the LED
install pt 2b
 Repeat this for every input you want to show on the display or data.
Simply wire up the VIM as follows,
  • CAN2 to the Logger
  • Power and ground
  • Each input takes a single 12v feed
install 4
It’s as simple as that!
By using advanced CAN technology, wiring is simplified from four cables into just a single connection, thereby reducing possible and unnecessary points of failure. Works with most Dash and Data Loggers vim tech 1 vim tech 2
Vim tech 1  VIM tech 2
VIM MXS STRADA
VIM MXS STRADA
VIM
Installation
vim install 1
Part 2
install pt2
install pt 2a
install pt 2b
  • Power and ground
install 4
Technical Specifications
VIM MXS STRADA
VIM MXS STRADA
