AiM Water (Coolant) M10 Temperature Sensor with 712-719 3 pin Patch Lead
SKU: S-T-M10-K-P
- €137,95
- €137,95
AiM Water (Coolant) M10 Temperature Sensor Kart
The AiM M10 water temperature sensor for MyChron can measure and sample water temperature providing accurate readings. This sensor comes with a 712-719 3 pin patch lead.
M10 water temperature sensor | 4 pin 719 male binder connection |
Suitable for all MyChrons | Rotax, X30, OK Engines |
712-719 3 pin patch lead |
The AiM PT100 M10 water (coolant) temperature kart sensor is for use with all MyChron kart dash/data loggers (including the new MyChron5 S and the older generation MyChron4). The sensor can measure and sample water temperature providing the most accurate readings.
The Thermo resistor should be in the cooling system/oil sump. It is recommended to install the sensor away from heat and electromagnetic interference sources like the RPM or Lap Receiver cables.
Temperature range of 0-150°C
Sensor cable length 250mm
The M10 thread is most commonly found on Rotax, X30 and OK engines
Comes with a 712-719 3 pin patch lead
The sensors are sold with a 25cm cable and optional patch leads are available. MyChron 5 will require a 712-719 3 pin patch lead.
The MyChron 5 S 2T, will require the MyChron 2T patch lead TC plug & black 719 TR plug. All patch leads can be found in the accessories tab.
- Temperature working range: 0/150°C
- Cable Sensor Length: 250mm
- M10 thread
- 4 pin male 719 Binder connection
- 712-719 3 pin male Binder connection 1.5m
- AiM Water Temperature Sensor M10 Thermocouple Resister
The AiM M10 water temperature sensor for MyChron can measure and sample water temperature providing accurate readings. This sensor comes with a 712-719 3 pin patch lead.Key Features :
The AiM PT100 M10 water (coolant) temperature kart sensor is for use with all MyChron kart dash/data loggers (including the new MyChron5 S and the older generation MyChron4). The sensor can measure and sample water temperature providing the most accurate readings.The Thermo resistor should be in the cooling system/oil sump. It is recommended to install the sensor away from heat and electromagnetic interference sources like the RPM or Lap Receiver cables.
The sensors are sold with a 25cm cable and optional patch leads are available. MyChron 5 will require a 712-719 3 pin patch lead.The MyChron 5 S 2T, will require the MyChron 2T patch lead TC plug & black 719 TR plug. All patch leads can be found in the accessories tab.
- M10 thread
