Aim X Log compact Datalogger
SKU: XLOG
- €562,95 EUR
- €562,95 EUR
X Log
Compact, powerful, reliable
X Log is an extremely powerful and compact datalogger..
- ECU stream CAN: K-line or RS232 connections
- GPS: four constellations (GPS, GLONASS, BeiDou and Galileo), 25 Hz, with less than
half a meter precision.
- internal 6 axis inertial platform
- Expansions:
- ACC 2: Analog inputs
- LCU-One S: Lambda controller
- SmartCam 3 series: Motorsport cameras
Then, it features:
- Integrated Wi-Fi and Bluetooth
- Long lasting Lithium Battery and connection for an external 8-16V battery
- 4 GB internal memory
- Removable USB Type-C key
- Waterproof (IP67)
Then, it features:
- Waterproof (IP67)
Aim X Log Compact Datalogger
- Inertia platform: 100 Hz 6 axis
- GPS: 25 Hz
- Wifi: Built in
- Bluetooth: Built in
- ECU Connections: CAN, RS232 or K-Line to 1,000 + Industry leading ECUs
- RPM Input: 1
- Push Button: 1
- Status LED: 1
- External Power: 0-15 V
- Connectors: 5 pins binder 712, 7 pins binder 712, USB Type-C
- Memory: 4GB internal + removeable USB Type-C key
- Battery: Rechargeable lithium
- Material: PA6 + 30% glass fibre reinforced
- X Log
- Mini USB drive 16gb
- Either CAN/OBDII or CAN/RS232/EXT. Power 2m cable
- USB 2.0 A-Type C-Type 2m cable
X Log
- Expansions:
- Waterproof (IP67)
- Waterproof (IP67)
With Race Studio 3 you can also analyse all data recorded by EVO4S and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performance. ![]() |
- GPS: 25 Hz
- Wifi: Built in
- RPM Input: 1
- Push Button: 1
- Status LED: 1
- X Log
