K series keypads OPEN - K6 / K8 / K15
SKU: k6-O
- €220,95 EUR
- €220,95 EUR
K6/K8/K15
The CAN-Bus Keypads Series OPEN
Please note - OPEN devices must be programmed in Race Studio 3 via USB to enable them to transmit data on none preset CAN ID's
Compact, Fully customizable, water and dust proof
The K6, K8 and K15, just like GPS09 or ACC 2, are available in "Open Version". These keypads can be easily configurable via USB with Aim software RaceStudio 3 for transmitting the data via CAN to every external device. The devices are water and dust resistant and can be installed both inside and outside the cockpit. They are fully customisable and proposed with a wide range of interchangeable inserts sold seperatly. View Inserts
The "Open Version" can also be used as an Aim Expansion, without any issues or limitations.
The keypads will enable you to have your very own selected buttons at your fingertips. Available in 6, 8 and 15 key keypads.
- Reconfigurable buttons
- Programmable RGB LEDs
- LED backlit rings and icons
- Momentary, toggle and multi-status
- 2 blinking mode
- Wide range of inserts
- CAN-Bus system compatible
- Vertical or horizontal mount
- Status restore option
The Push buttons can be:
MOMENTARY
- The pushbutton status is ON when the pushbutton is pushed.
TOGGLE
- The pushbutton status changes from ON to OFF every time the pushbutton is pushed.
MULTI-STATUS
- The pushbutton value changes from 0 to a MAX value every time the pushbutton is pushed.
Our Featured Videos
CAN MESSAGES CONFIGURATION
The status of the pushbuttons is transmitted at fixed frequency or/and when it changes.
The CAN messages as frequency, IDs, baud rate, endian and contents can be freely configured.
The status of every pushbutton at the power OFF can be hold at the next power ON.
K6/K8/K15 Open Keypads can manage a CAN INPUT protocol, in order to give a feedback, trough the color LEDs, based upon the information received.
RGB LED's
RGB LEDs are the best choice in low visibility conditions. Every pushbutton can be enlightened in 1 of 8 different colors, solid or blinking, according to the configuration defined by the user.
Expansion Features
K Keypads can be connected to the AiM master devices such as dashes, dash loggers and PDMs.
They can be freely configurable as an expansion using the AiM software RaceStudio 3.
Additional Controls
In addition to the primary functionality of the buttons, K6/K8/K15 buttons can be setup for managing the AiM display connected to the devices.
Interchangeable Inserts
It is possible to choose among a wide range of inserts available; with 72 elements easily interchangeable, you'll have the possibility to create different configurations with the same K6/K8/K15 keypad based on any needs. View Inserts
K Keypads | AiM EXPANSION
Connectable to the AiM master devices such as dashes, dash loggers and PDMs through the AiM Expansion CAN Bus (go the the section).
K Keypads OPEN | OPEN VERSION
Freely configurable through USB, using the AiM software RaceStudio 3, they can be connected through CAN to every external device (go to the section).
- K6 PushButtons: 6 programmable Keys
- K8 PushButtons: 8 programmable Keys
- K15 PushButtons: 15 programmable Keys
- Backlight: RGB with dimming option
- Connection: USB CAN 7 pins Binder 712
- K6 Dimensions: 97.4 x 71.4 x 24 mm
- K8 Dimensions: 127.4 x 71.4 x 24 mm
- K15 Dimensions: 157.4 x 71.4 x 24 mm
- K6 Weight: 120g
- K8 Weight: 150g
- K15 Weight: 250g
Remote Button CAN Interface Pro Keypad
- Your choice of Aim CAN Open Expansion Keypad
- Your choice length for the Unterminaited CAN Cable
- USB & Ext Power Cable For Aim Open CAN Keypad
K6/K8/K15
- 2 blinking mode
MOMENTARY
TOGGLE
MULTI-STATUS
Our Featured Videos
The status of the pushbuttons is transmitted at fixed frequency or/and when it changes. The CAN messages as frequency, IDs, baud rate, endian and contents can be freely configured. The status of every pushbutton at the power OFF can be hold at the next power ON. K6/K8/K15 Open Keypads can manage a CAN INPUT protocol, in order to give a feedback, trough the color LEDs, based upon the information received.
RGB LED's
Expansion Features
K Keypads can be connected to the AiM master devices such as dashes, dash loggers and PDMs. They can be freely configurable as an expansion using the AiM software RaceStudio 3.
Additional Controls
With Race Studio 3 you can also analyse all data recorded and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.K Keypads | AiM EXPANSION
Technical Specifications
- K6 Weight: 120g
- K8 Weight: 150g
- K15 Weight: 250g
Whats in The Box
