{"product_id":"link-3-bar-map-sensor-map3","title":"Link 3 Bar MAP Sensor (MAP3)","description":"\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Link_Banner_Description.png?v=1616071775\" style=\"width: 100%;\"\u003e\u003c\/p\u003e\n\u003ch3\u003eLink 3 Bar MAP Sensor (MAP3)\u003c\/h3\u003e\n\u003cp\u003eThis Link MAP sensor reads up to 3 Bar absolute pressure. This means that it is suitable for turbo or supercharged applications running up to 2.0 Bar (or 29psi) of boost pressure. \u003cbr\u003eThe wiring pinout for this sensor is indicated on the sensor.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003cp\u003eIncludes Deutsch 3-pin connector kit\u003cbr\u003eEasy to mount via 2 bolt holes. Note that the sensor should be mounted higher than the intake manifold port that the hose connects to.\u003cbr\u003eCompact aluminium enclosure\u003cbr\u003eMechanical connection via 4mm hose connector nipple\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eUsing Link G4\/G4+\/G4X ECU’s select the MAP sensor type in PC Link as ‘Link 3 Bar’\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch5\u003eWhat's in The Box\u003cbr\u003e\n\u003c\/h5\u003e\n\u003ch3\u003eLink 3 Bar MAP Sensor (MAP3)\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e3 Bar MAP Sensor\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e3-pin Deutsch DTM connector kit\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cbr\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimshop.com\/pages\/pc-link-downloads\" title=\"PC Link Downloads\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/PC_LINK_Downloads.png?v=1616072312\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimshop.com\/pages\/pc-link-downloads\" title=\"PC Link Downloads\" target=\"_blank\"\u003e \u003cspan style=\"color: #088cf7;\"\u003ePC Link Downloads\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Link","offers":[{"title":"Default Title","offer_id":39292614836326,"sku":"MAP3","price":122.95,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/products\/Link3BarMAPSensor_MAP3.png?v=1617960056","url":"https:\/\/www.aimshop.com\/en-pt\/products\/link-3-bar-map-sensor-map3","provider":"AimShop.com","version":"1.0","type":"link"}
