{"product_id":"link-subaru-wrxlink-v10-wrx107x-plugin-ecu","title":"Link Subaru WRXLink (V10) - WRX107X PlugIn ECU","description":"\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Link_Banner_Description.png?v=1616071775\" style=\"width: 100%;\"\u003e\u003c\/p\u003e\n\u003ch3\u003eLink Subaru WRXLink (V10) - WRX107X PlugIn ECU\u003c\/h3\u003e\n\u003cp\u003eEasy to install. Affordable. Reliable. \u003cbr\u003e\u003cbr\u003eG4X PlugIn ECUs offer the latest in engine management technology, designed to easily maximize the potential of your car. \u003cbr\u003eThis ECU fits inside the factory OEM enclosure. Installation is a breeze, with no alteration of the factory wiring loom required for the models listed below. \u003cbr\u003e\u003cbr\u003eDesigned for the WRX V10 EJ25. These ECUs cover 2.5L from 2004 to 2007. \u003cbr\u003e\u003cbr\u003eThis ECU works for manual transmissions only. \u003cbr\u003eAir temp sensor highly recommended. \u003cbr\u003eMost factory features are supported. \u003cbr\u003e\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eSuitable Applications:\u003c\/h3\u003e\n\u003cp\u003eThe WRX104+mostly covered the 2004-2006 range (listed separately). \u003cbr\u003eThe WRX107+ mostly covers the 2007 model.\u003cbr\u003e \u003cbr\u003eHowever, some 2006 models require the WRX107+ \u003cbr\u003e \u003cbr\u003e*The fastest and most reliable way to tell, is to check whether pins A1-3 are populated. \u003cbr\u003e\u003cbr\u003e*If the pins have wires, you need the WRX104+, if there are no wires, you need the WRX107+ \u003cbr\u003e\u003cbr\u003e*Suits GD or GG chassis with electronic throttle. Not suitable for the GR\/GH\/GE\/GV hatchback or 3rd generation WRX’s\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003ePlugIn Key Features:\u003c\/h3\u003e\n\u003cp\u003eUp to 6D fuel and ignition mapping\u003cbr\u003ePrecision closed loop cam control (four cams, independent control)\u003cbr\u003eSequential fuel delivery\u003cbr\u003eDigital triggering, all OEM patterns\u003cbr\u003eOEM idle hardware supported\u003cbr\u003e5D boost control with three switchable tables\u003cbr\u003eMotorsport features - anti-lag, launch, flat shift\u003cbr\u003eContinuous barometric correction (onboard)\u003cbr\u003eCAN port\u003cbr\u003eQuickTime - automated fuel tuning\u003cbr\u003eIndividual cylinder correction\u003cbr\u003eUSB tuning cable included\u003cbr\u003eStats recording into on-board memory\u003cbr\u003eGear compensations for spark, boost and fuel\u003cbr\u003eReal-time selectable dual fuel, ignition and boost maps\u003cbr\u003eSync and crank sensors can be a combination of Hall effect, variable reluctance or optical\u003cbr\u003eBoost control referenced to gear, speed or throttle position\u003cbr\u003e512 megabytes data logging memory\u003cbr\u003eStaged injection\u003cbr\u003eKnock with \"windowing\"\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eThere are two different options for the expansion connectors, depending on whether your ECU is the 2004-2006 ECU or the 2006-2007 ECU. \u003c\/h3\u003e\n\u003cp\u003e\u003cstrong\u003e2004-2006 ECU\u003c\/strong\u003e \u003cbr\u003eThe following expansion connector inputs\/outputs are provided: \u003cbr\u003eBlank AN Volt 11 \u003cbr\u003eAn Temp 4 Temperature sensor input \u003cbr\u003eBlank No function \u003cbr\u003eBlank AN Volt 12 \u003cbr\u003eBlank No function \u003cbr\u003eBlank No function \u003cbr\u003e+5V Out Low Current +5V Supply \u003cbr\u003eGnd Sensor Ground Only\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e2006-2007 ECU \u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eThe 2006-2007 V10 ECU contains an 8 pin expansion connector. \u003cbr\u003eThe following expansion connector inputs\/outputs are provided: \u003cbr\u003eAux 11 Auxiliary Output \u003cbr\u003eAn Temp 4 Temperature sensor input \u003cbr\u003eAux 12 Auxiliary Output \u003cbr\u003eVolt 11 Analog 0-5V input \u003cbr\u003eAux 13 Auxiliary Output \u003cbr\u003eDI 11 Digital Input \u003cbr\u003e+5V Out Low Current +5V Supply \u003cbr\u003eGnd Sensor Ground Only\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch5\u003eWhat's in The Box\u003cbr\u003e\n\u003c\/h5\u003e\n\u003ch3\u003eLink Subaru WRXLink (V10) - WRX107X PlugIn ECU\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eG4X PlugIn ECU\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eWiring and Installation Instructions\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eStickers\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003cbr\u003e\n\u003c\/h5\u003e\n\u003cbr\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimshop.com\/pages\/pc-link-downloads\" title=\"PC Link Downloads\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/PC_LINK_Downloads.png?v=1616072312\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimshop.com\/pages\/pc-link-downloads\" title=\"PC Link Downloads\" target=\"_blank\"\u003e \u003cspan style=\"color: #088cf7;\"\u003ePC Link Downloads\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Link","offers":[{"title":"Default Title","offer_id":39273028812902,"sku":"WRX107X","price":1743.95,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/products\/LinkSubaruWRXLink_V10_-WRX107XPlugInECU.png?v=1616408052","url":"https:\/\/www.aimshop.com\/en-pt\/products\/link-subaru-wrxlink-v10-wrx107x-plugin-ecu","provider":"AimShop.com","version":"1.0","type":"link"}
