AiM MyChron5 Charger Kit UK Plug
SKU: M5-CH-D-UK - X80M5KCBUSB1G
- €96,95
- €96,95
This AiM replacement UK charger for the MyChron5 is the same as the one supplied with the MyChron5, so it is ideal as a replacement or spare unit if required.
Suits MyChron5 | Plugs into 240V supply |
UK 3 pin plug | |
Charges MyChron5 battery.
Plugs into 240v supply.
The battery needs to be removed from the dash to enable the charger to be plugged in.
- Suits MyChron5
- Magnetic Charging Dock
- USB Cable
- UK Plug
- 1 x UK Plug
- USB Cable
This AiM replacement UK charger for the MyChron5 is the same as the one supplied with the MyChron5, so it is ideal as a replacement or spare unit if required.Key Features :
UK 3 pin plug | |
This AiM replacement UK charger for the MyChron5 is the same as the one supplied with the MyChron5, so it is ideal as a replacement or spare unit if required.Charges MyChron5 battery.
- Suits MyChron5
- USB Cable
- UK Plug
- 1 x UK Plug
- USB Cable
