{"product_id":"out-of-production-aim-sw4-270-formula-steering-wheel","title":"Out of Production Unused Aim SW4 270 Formula Steering Wheel","description":"\u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_bCFQLY\"\u003e\n\u003cdiv class=\"section  section--padding\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eData Logging Steering Wheel\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe Aim Formula Steering Wheel 4 270\/280 is amongst our most advanced motorsport steering wheels to date. It has an internal data logger with complete configuration, removable grips, rotary switches and a long list of fully compatible ECU and CAN connectivity options.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_3kEhi6\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eWhy Choose the Aim 270\/280 Steering Wheel\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe Aim Formula steering wheel 270\/280 has been specifically designed for professional motorsport applications. The internal data logger is fully configurable and has been developed to acquire and display data from the ECU, with over 1,000 fully compatible ECU protocols.\u003c\/p\u003e\n\u003cp\u003eOur Formula wheels come in a range of sizes (270, 280,\u003cspan\u003e \u003c\/span\u003e\u003ca title=\"Aim SW4 GT320\/GT350 Formula Steering Wheel\" href=\"https:\/\/www.aimshop.com\/products\/aim-sw4-gt320-gt350-formula-steering-wheel\"\u003eGT320 \u0026amp; GT350\u003c\/a\u003e). The compact 270 and 280 versions are the ideal choice for single-seaters or sports prototypes where cockpit space is at a premium. The difference between the Formula steering wheel 4 270 and 280 is the overall diameter: the 280 is 10mm larger to suit different driver preferences.\u003c\/p\u003e\n\u003cp\u003eThe Aim SW4 270\/280 Formula steering wheel is also fully compatible with our PDM32 via CAN communication.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_cy4Jzy\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEasy Connection\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eConnecting the Aim 270\/280 Formula steering wheel to your ECU is straightforward. You can sample dozens of channels directly from the ECU using a single connection, rather than installing multiple analogue sensors.\u003c\/p\u003e\n\u003cp\u003eThe data sampled depends on the ECU in use, but typically includes RPM, engine load, throttle position (TPS), oil, air, and water temperatures, oil pressure, battery voltage, speed, gear, and lambda values (air\/fuel ratio). The list of available ECU drivers is constantly updated and upgraded, and includes over 1,000 different ECUs.\u003c\/p\u003e\n\u003cp\u003eWith CAN output, you can send messages directly to an existing CAN network, enabling extended integration with other vehicle systems.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_E8RKHy\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDisplay \u0026amp; Push Buttons\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe Aim Formula steering wheel 4 270\/280 is equipped with a high-contrast 4.3\" TFT display, fully configurable and sunlight viewable. With 8 shift lights, 4 RGB alarm LEDs and an integrated ambient light sensor, the steering wheel delivers clear, precise, and reliable information directly to the driver at all times.\u003c\/p\u003e\n\u003cp\u003eThe Formula steering wheel 4 270\/280 features 10 push buttons and 3 rotary switches, all backlit with RGB LEDs. It also includes removable grips, rotary switches, and a wide range of ECU and CAN connectivity options.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_nAJYLi\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eFlexible Alarms\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe Aim SW4 270\/280 Formula steering wheel offers 8 configurable shift light RGB LEDs and 4 configurable alarm RGB LEDs. You can define conditions, colours, priorities, and flashing frequencies, as well as display accompanying text messages when required.\u003c\/p\u003e\n\u003cp\u003eThe advanced multi-colour RGB shift lights can be fully customised, with the option to define different shift patterns for each gear.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_9enpXA\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eOptional Extras\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThere is a wide selection of accessories available to get the most out of your steering wheel:\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003ca title=\"Aim GPS09 Module\" href=\"https:\/\/www.aimshop.com\/products\/aim-gps09-gps-module\"\u003e\u003cstrong\u003eGPS Module\u003c\/strong\u003e\u003c\/a\u003e: Connected via CAN, the GPS Module makes lap timing and track position analysis easy.\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eClutch Paddles\u003c\/strong\u003e: Left\/right clutch paddles can be added from the accessories at the top of the page to suit your driving style.\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eOther Expansions\u003c\/strong\u003e: Expand your system with a range of additional Aim devices, including the TC Hub, Lambda Controller, SmartyCam 3, RIO, GS-Dash, and more.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cp\u003e270mm Part Number: X07SW42700\u003c\/p\u003e\n\u003cp\u003e280mm Part Number: X07SW42800\u003c\/p\u003e","brand":"Second-Life","offers":[{"title":"Default Title","offer_id":45624512282726,"sku":"SN 8401640 \/ 8401639","price":2583.95,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/SW4270.png?v=1779097526","url":"https:\/\/www.aimshop.com\/en-pt\/products\/out-of-production-aim-sw4-270-formula-steering-wheel","provider":"AimShop.com","version":"1.0","type":"link"}
