{"product_id":"second-life-aim-mxps-suzuki-gsx-r1000-2017-2022-plug-play-dash-logger","title":"Second-Life Aim MXPS Suzuki GSX-R1000 (2017-2022) Plug \u0026 Play Dash Logger","description":"\u003cstyle\u003e\n.product__info-wrapper .price-item--regular .money {\n display: flex;\n}\n\u003c\/style\u003e\n\n\u003cp style=\"text-align: center;\"\u003e\u003cmeta charset=\"utf-8\"\u003e\u003cstrong\u003e\u003cspan style=\"color: rgb(0, 170, 255);\"\u003e\u003cem\u003eThis MXPS Dash comes back to us as a trade-in, fully equipped and ready to take on its second life. The dash is in full working order and has been meticulously checked by our technicians.\u003c\/em\u003e\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003ch2 style=\"text-align: center;\"\u003e Plug \u0026amp; Play Dash Logger for Suzuki GSX-R 1000\u003c\/h2\u003e\n\u003ch2 style=\"text-align: center;\"\u003e(Now Includes GPS09 Module )\u003cbr\u003e\n\u003c\/h2\u003e\n\u003cp style=\"text-align: left;\"\u003ePlug \u0026amp; Play Dash Logger designed explicitly for Suzuki GSX-R 1000 Years 2017-2023 and Suzuki GSX-R 1000 R Years 2017- 2023.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003eYoshimura harness compatible,\u003c\/li\u003e\n\u003cli\u003e6\" TFT high contrast \u003c\/li\u003e\n\u003cli\u003e1,100 Lumen display,\u003c\/li\u003e\n\u003cli\u003e9 alarm LEDs,\u003c\/li\u003e\n\u003cli\u003e10 shift lights LEDs,\u003c\/li\u003e\n\u003cli\u003e2 CAN connections,\u003c\/li\u003e\n\u003cli\u003e4 GB internal memory, anodized aluminium body,\u003c\/li\u003e\n\u003cli\u003e1 32 pins JAE main connector + 4 Binder 712 female connectors,\u003c\/li\u003e\n\u003cli\u003eIP65.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp style=\"text-align: left;\"\u003e\u003cstrong\u003ePlease Note: The MXPS dash can be programmed with your current mileage. Please state your required mileage in miles or kilometres in the notes section on your order.\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg style=\"display: block; margin-left: auto; margin-right: auto;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/MXPS_Features.png?v=1660034777\" alt=\"\"\u003e\u003c\/p\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003ch2 style=\"text-align: left;\"\u003eConfigurable layouts\u003c\/h2\u003e\n\u003cp style=\"text-align: left;\"\u003eMXPS features several configurable layouts in 2 themes both in light and dark mode for your needs in every situation, whether you are on track or riding down the streets.\u003c\/p\u003e\n\u003cp style=\"text-align: center;\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Displays.png?v=1660035192\"\u003e\u003c\/p\u003e\n\u003ch2\u003eConnections and expansions\u003c\/h2\u003e\n\u003cp\u003eGet the best out of your GSX-R 1000.\u003cbr data-mce-fragment=\"1\"\u003eIn addition to the main connection that gives you all the information from the ECU, MXPS provides you also:\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eEXP connection\u003c\/strong\u003e upgrades your bike with some of the best AiM expansions like GPS09 Module, Lambda Controller, Channel Expansion or even a SmartyCam to record your ride.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eUSB or Wi-Fi connection\u003c\/strong\u003e enables you to download data and configure your MXPS.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eCamera connection\u003c\/strong\u003e allows you to install a mirror camera.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eSDS+Analog connection\u003c\/strong\u003e gives you the possibility to read 28 ECU extra channels and 4 user defined analog inputs.\u003c\/p\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Connections.png?v=1660035481\" alt=\"\"\u003e\u003c\/p\u003e\n\u003ch2\u003eConnection Example\u003c\/h2\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/connectionexample.png?v=1660036156\" alt=\"\"\u003e\u003c\/p\u003e\n\u003ch2\u003eEfficient and unfussy user experience\u003c\/h2\u003e\n\u003cp\u003eMXPS benefits from a user-friendly menu created for ease of use on every page. The navigation and configuration of the dash is designed to be simple and clear. Setting up your MXPS it’s just a matter of riding style: choose what perfectly fits your road\/track needs.\u003cbr data-mce-fragment=\"1\"\u003eThe complete menu allows you to easily modify every parameter of your bike: ECU maps, traction control, anti-wheeling, ABS and so on.\u003c\/p\u003e\n\u003cp\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/menu.png?v=1660035820\"\u003e\u003c\/p\u003e\n\u003ch2 id=\"RaceKit\"\u003eRacing kit for Suzuki GSX-R 1000\u003c\/h2\u003e\n\u003cp\u003eThanks to its dedicated RACING KIT, the dash turns into a complete datalogger with every feature you may need on the track.\u003cbr data-mce-fragment=\"1\"\u003eEvery element is designed to extend the huge potential of your bike, recording data to be downloaded and analyzed with our proprietary software, Race Studio Analysis 3.\u003cbr data-mce-fragment=\"1\"\u003eBy adding the GPS09 Module to your MXPS, you may gather your lap times and track data.\u003cbr data-mce-fragment=\"1\"\u003eFeaturing a wide database of tracks, your dash logger will automatically recognize the track you are at, recording all the data coming from your ECU, as well as from the GPS.\u003cbr data-mce-fragment=\"1\"\u003eWith the kit, you can read 28 ECU extra channels and connect up to 4 sensors for precise performance logging.\u003cbr data-mce-fragment=\"1\"\u003eNow you have total control of your GSX-R 1000, with the potential to drastically improve your performance.\u003c\/p\u003e\n\u003cdiv style=\"text-align: center;\"\u003e\u003ca class=\"button button-custom\" href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/aim_mxps_channels_list_100.pdf?v=1660037026\"\u003eAvailable Channels\u003c\/a\u003e\u003c\/div\u003e\n\u003cp style=\"text-align: center;\"\u003e\u003cbr\u003e\u003cimg data-mce-fragment=\"1\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/jlyIbt8A.png?v=1712915275\" alt=\"\" data-mce-src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/jlyIbt8A.png?v=1712915275\"\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e \u003ca href=\"https:\/\/www.youtube.com\/watch?v=PXsob0KHmbc\" target=\"_blank\"\u003e\u003cimg data-mce-fragment=\"1\" alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/installation.jpg?v=1660036476\" data-mce-src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/installation.jpg?v=1660036476\"\u003e\u003c\/a\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Championship.jpg?v=1660036553\" alt=\"\"\u003e\u003c\/p\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003eDisplay: 6\" TFT\u003c\/p\u003e\n\u003cp\u003eResolution: 800x480 pixels\u003c\/p\u003e\n\u003cp\u003eContrast: 600:1\u003c\/p\u003e\n\u003cp\u003eBrightness: 700cd\/m2 - 1,100 Lumen\u003c\/p\u003e\n\u003cp\u003eAmbient light sensor: Yes\u003c\/p\u003e\n\u003cp\u003eAlarm LEDs: 9\u003c\/p\u003e\n\u003cp\u003eShift Light LEDs: 10\u003c\/p\u003e\n\u003cp\u003eCAN connections: 2\u003c\/p\u003e\n\u003cp\u003eECU Connection: Yes\u003c\/p\u003e\n\u003cp\u003eExternal modules: GPS Module, Channel Expansion, Lambda Controller, TC Hub, SmartyCam HD\u003c\/p\u003e\n\u003cp\u003eWi-fi connection: Yes\u003c\/p\u003e\n\u003cp\u003eInternal memory: 4GB\u003c\/p\u003e\n\u003cp\u003eBody: Anodized Aluminium\u003c\/p\u003e\n\u003cp\u003eConnectors: 1 32 pins JAE main connector + 4 Binder 712 female connectors\u003c\/p\u003e\n\u003cp\u003eDimensions: 189.6 x 106.4 x 24.9 mm\u003c\/p\u003e\n\u003cp\u003eWeight: 620g\u003c\/p\u003e\n\u003cp\u003ePower consumption: 400 mA\u003c\/p\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\u003c\/ul\u003e\n\u003cp\u003e Waterproof: IP65\u003cbr\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003cp\u003eMXPS Plug\u0026amp;Play Dash Logger for Suzuki GSX-R 1000\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003eMXPS Plug \u0026amp; Play Dash\u003c\/li\u003e\n\u003cli\u003eFixing\/Installation Kit\u003c\/li\u003e\n\u003cli\u003eGPS09 Module \u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cbr\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cdiv style=\"text-align: left;\"\u003e\u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/mxps\/MXPS_user_guide.pdf\"\u003e\u003cimg style=\"float: none; display: block; margin-left: auto; margin-right: auto;\" alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/User_Guide_AiM_iCON_2289456f-97fa-4d13-84ea-3ede554821e9_100x100.png?v=1613601281\"\u003e\u003c\/a\u003e\u003c\/div\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cdiv style=\"text-align: left;\"\u003e\u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/mxps\/aim_mxps.pdf\"\u003e\u003cimg style=\"float: none; display: block; margin-left: auto; margin-right: auto;\" alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1613601281\"\u003e\u003c\/a\u003e\u003c\/div\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/aim_mxps_channels_list_100.pdf?v=1660037026\" target=\"_blank\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1613601281\" alt=\"\" data-mce-selected=\"1\"\u003e\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/support.aimshop.com\/downloads\/software\/racestudio3\/RaceStudio3-64.exe\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/mxps\/MXPS_user_guide.pdf\"\u003eUser Guide\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/mxps\/aim_mxps.pdf\"\u003eTechnical Sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/aim_mxps_channels_list_100.pdf?v=1660037026\" target=\"_blank\"\u003eAvailable Channels\u003c\/a\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/support.aimshop.com\/downloads\/software\/racestudio3\/RaceStudio3-64.exe\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Second-Life","offers":[{"title":"Default Title","offer_id":42468352458854,"sku":"0500404","price":927.95,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/MXPS_29ef2d77-8e7f-40a7-8d1f-9d6e63942e31.png?v=1779100506","url":"https:\/\/www.aimshop.com\/en-pt\/products\/second-life-aim-mxps-suzuki-gsx-r1000-2017-2022-plug-play-dash-logger","provider":"AimShop.com","version":"1.0","type":"link"}
