{"product_id":"smartycam-4-gpd","title":"SmartyCam 4 GPD","description":"\u003cstyle\u003e\n  .center-image{\n    margin:0 auto\n  }\n\u003c\/style\u003e\n\u003cdiv id=\"shopify-section-template--17807362392166__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eThe Best Motorsport Bullet Camera \u0026amp; More\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe Aim SmartyCam 4 GPD camera system uses a robust and compact bullet camera making it perfect for single seaters, motorcycles, and other applications where cockpit space is limited.\u003cbr\u003e\u003cbr\u003eThe camera is available in three lens versions, each with a choice of a bullet camera length of 1m, 2m, 3m, 4m or a custom cable length and a 2m or 4m CAN expansion cable, making it one of the best motorsport bullet cameras in the industry, with even more advanced features.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003ePlease Note:\u003c\/strong\u003e  The camera MUST be externally powered as the internal battery is only designed for initial configuration, and returns are\u003cspan\u003e \u003c\/span\u003e\u003cstrong\u003enot\u003cspan\u003e \u003c\/span\u003e\u003c\/strong\u003eaccepted for custom cable lengths.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17807362392166__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eWhy Choose the SmartyCam 4 GPD\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe SmartyCam 4 GPD is purpose-built for harsh motorsport environments, eliminating the seasick “wave effect” of standard cameras with its global shutter CMOS sensor that handles engine vibrations at high RPM.\u003cbr\u003e\u003cbr\u003eThe Aim SmartyCam 4 GPD features a coaxial bullet cable with enhanced electromagnetic noise protection, an integrated CAN bus hub with dedicated ports for bullet cam, video output, GPS, and expansion, plus an optional CAN ECU connection for direct access to ECU data via Aim protocols. Designed in machined aluminium and sealed to high waterproof standards, the GPD withstands extreme weather and vibrations, while sound recording can be improved with an external mic. Paired with free Race Studio 3 software, drivers and teams can easily split and compare laps for detailed video analysis and performance review.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17807362392166__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eReal Time Configurable Data Overlays\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eUsing Race Studio 3, you can configure your video overlays in a virtually infinite variety of ways: add your logo and the track map, choose your graphical objects from a list of pre-determined sets or even single objects from different sets.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17807362392166__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eVideo Output\/Streaming\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eSmartyCam 4 GPD features a video output with SD interface. It allows you to send the video\/audio directly to wherever you choose, for example your pit crew, at 30 or 60fps.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17807362392166__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eAll The Data You Need\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eFrom speed, RPM, and lap number, to gear shifts and much more, data can be read from all possible sources. From GPS; track map and vehicle position as well as speed, lap and split times, or from an Aim logger; RPM, throttle, engaged gear, acceleration, temperatures, pressures can be recorded as well.\u003cbr\u003e\u003cbr\u003eContaining a full internal datalogger, all data received from the CAN bus and from the internal sensors are recorded in .mp4 files produced at the end of your test, your SD (or MSD) Card contains all the information you need for a deep data analysis.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17807362392166__rich_text_6LLCj9\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eHigher Storage Capacity\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eOther HD cameras often chase higher pixel counts which leads to huge file sizes without much real benefit. The SmartyCam 4 GPD is different: it uses smart H.264 compression settings that keep the video quality you need while keeping file sizes small. This means you can quickly download and review footage at the track for data analysis, instead of dealing with huge cinematic files that look pretty but slow you down.\u003cbr\u003e\u003cbr\u003eChoose between three file quality levels: One hour recording = 4GB (high quality), 2GB (normal quality) or 1.5GB (lower quality).\u003cbr\u003e\u003cbr\u003eThe SD card housing on the Aim SmartyCam 4 GPD is 100% protected from air and weathering.\u003cbr\u003e\u003ca href=\"https:\/\/www.aimshop.com\/collections\/car-hd-camera-spares\" title=\"https:\/\/www.aimshop.com\/collections\/car-hd-camera-spares\"\u003e\u003cstrong\u003eSD cards\u003c\/strong\u003e\u003c\/a\u003e\u003cstrong\u003e\u003cspan\u003e \u003c\/span\u003esold separately.\u003c\/strong\u003e\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e","brand":"Aim Camera","offers":[{"title":"Default Title","offer_id":45591372988518,"sku":null,"price":3364.95,"currency_code":"EUR","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AdGraphics_2.png?v=1780571403","url":"https:\/\/www.aimshop.com\/en-pt\/products\/smartycam-4-gpd","provider":"AimShop.com","version":"1.0","type":"link"}
