Yamaha YZF-R1/R1M & YZR-R6 AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
SKU: SOLO2-K-YAM-1-SM-CAM-GP-2-SM-GPC-XB1SGPH22B67L200-V0256934CS-X47SOLO2DL02
- €2.670,95 EUR
- €2.670,95 EUR
Yamaha YZF-R1/R1M & YZF-R6 AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
Database with more than 4,000 tracks worldwide | Yamaha ECU connection cable |
SmartyCam 3 GP Features:
Yamaha YZF-R1 - From 2015 | Yamaha YZF-R1M - From 2015 |
Yamaha YZF-R6 - From 2017 |
Powerful Combination
SmartyCam 3 GP
Automatic Start/Stop
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
- SmartyCam 3 GP
- CMOS sensor: Global Shutter
- Video Out: 3G-SDI
- External power: 9-15 Volt
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Body: Anodised Aluminium
- Dimensions: Main Body -154.4x109.6 x 42mm, Bullet Camera - 24diam x 48.2mm
- Solo 2 DL
- Power cable with AC adapter
- SmartyCam 3 GP - Bullet Cam
- External CAN cable 2m
- External power cable
- Yamaha Plug & Play connection cable
- Bracket
- 1 rubber dowel
- 1 Allen screw with flat head M6
- 1 rubber washer
- 2 Allen screws with flat head M4 x 10
The Yamaha plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP gives you the ultimate track day experience.Key Features :
This ultimate track day kit has been specifically designed for Yamaha bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Yamaha ECU will give you all the engine performance information you need to help improve your driving performance.SmartyCam 3 GP Features:
The plug & play cable currently fits the following Yamaha bike models:Yamaha YZF-R1 - From 2015 | Yamaha YZF-R1M - From 2015 |
The Yamaha ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated.
SmartyCam 3 GP
- GPS: 10 Hz
- Memory: 4 GB
- SmartyCam 3 GP
- Video Out: 3G-SDI
- Solo 2 DL
- Bracket
- 1 rubber dowel
- 1 rubber washer
