AiM Taipan Analog Channels Harness
SKU: C-H-AN
- Precio regular
- £30.00
- Precio regular
- Precio de venta
- £30.00
- Precio unitario
- por
+ IVA (Solo Reino Unido)
The AiM Taipan Analog channels harness is an optional cable to be used with the Taipan ECU.
Analog channels harness | JST connector |
3 flying wires |
AiM Taipan Accessories
The AiM Taipan Analog channels harness is an optional cable that can be used with the Taipan ECU.
The harness has a JST connector that connects to the Taipan ECU. Three flying wires one for GND and two for analogue connections.
UC Bridge - Optional Extra
User License:
A Taipan ECU comes with some basic maps that already give you better performance than the stock maps. Highly professional tuners all over the world offer specific maps that better fit your requirements, managing, for example, different exhaust, two injectors etc.
The UC Bridge is required for two functions:
Tuner License:
*Please Note: For information regarding the UC-Bridge Tuner, Please contact one of our Aim technical team for further information.
Taipan ECU Connections - Optional Extra
The Taipan ECU has 4 connectors:
The Aim Handlebar Switch is the best way for changing the behaviour of your bike; it features 2 pushbuttons, 10 LEDs and manages the following settings:
- JST Connector 08T-JWPF-VSLE-D
- Three flying wires:
- Black Wire - GND
- White Wire - Spare Analog 1
- Blue Wire - Spare Analog 2
- 2500mm - Full Length
- Analog Channels harness - 2500mm full length
The AiM Taipan Analog channels harness is an optional cable to be used with the Taipan ECU.Key Features :
3 flying wires |
The AiM Taipan Analog channels harness is an optional cable that can be used with the Taipan ECU.The harness has a JST connector that connects to the Taipan ECU. Three flying wires one for GND and two for analogue connections.
User License:
Tuner License:
- Black Wire - GND
Video
