1 de 1
AiM Exhaust Gas Thermocouple Temperature Sensor M5 K Type Motorcycle
SKU: S-T-EGT-MC
Precio regular
£70.00
Precio regular
Precio de venta
£70.00
The AiM Exhaust Gas Temperature Sensor (EGT) can measure the exhaust gas temperature by being placed in the exhaust header pipe.
Measure exhaust gas temperature Thermocouple male fitting
Wide temperature range
Temperature range of 0-1000°C
Sensor cable length 25cm
  • Temperature working range: 0-1000°C
  • Cable sensor length: 25cm
  • Cable Type: Compensated
  • Two pin male thermocouple connection
  • K Type thermocouple
  • AiM Exhaust Gas Thermocouple M5 Sensor (EGT)
