Aim LCU-One S OPEN
SKU: LCU1S-O
- Precio regular
£270.00£324.00(inc VAT)
- Precio regular
- Precio de venta
- £270.00
- Precio unitario
- por
Total control of your engine, now available for everyone
LCU-One S Open controller allows you to perfectly tune the carburetion of your engine to keep it at its best and improve the engine's performance. lt uses a wide band Bosch LSU 4.9 sensor, used for its capacity of saving the original calibration for the duration of the sensor's life. In fact, Bosch LSU 4.9 probe has been designed to last for more than 100,000 km on a stock car.
Please note - OPEN devices must be programmed in Race Studio 3 via USB to enable them to transmit data on non-preset CAN ID's
Precision and reliability
LCU-One S Open can detect accurate Lambda value from 0.65 to 1.6, offering an extremely precise measurement, very useful for engine tuning. Through the analysis of the remaining oxygen, LCU-One S Open points out a possible oxygen excess/lack in the carburetion and provides essential information for 2 strokes and 4 strokes engines. The configuration of Stoichiometric ratio allows LCU-One S Open to be used on petrol, diesel and also alternative fuel powered engines.
LCU-One S Open allows you to transmit the data via CAN to every system: configuring the output is very flexible, by setting IDs, messages, baud rate and frequency. Of course, LCU-One S Open can also be used as an Aim Expansion for current production devices only, without any issues or limitations.
Every OPEN device features a 7 pins connector to be connected to a PC via a dedicated USB cable.
With Race Studio 3, you can also analyse all data recorded and download it to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.
Aim LCU One S Lambda Controller
- Sensor Compatibility: Bosch LSU 4.9
- Power supply voltage: 9-15 V
- Power supply current: 50 mA + sensor heater current typical 750 mA up to 2 A on cold sensor
- Materials: Latigloss 57
- Dimensions: 43.4 x 30 x 18.4 mm
- Weight: 70g
Aim LCU One S OPEN Lambda Controller
Optional: Bosch LSU 4.9 Lambda probe + Thread iron ring for installation
Optional: USB Cable for programming
- Weight: 70g
