1 de 3
AiM MyChron 14mm Under Spark Plug Temperature Sensor Kart
SKU: S-T-CHT
Precio regular
£70.00
Precio regular
Precio de venta
£70.00
The AiM cylinder head thermocouple sensor allows you to measure cylinder head temperature when the sensor is placed between the spark plug and cylinder head.
Measure cylinder head temperature  Thermocouple male fitting
Wide temperature range 2 pins
The AiM Cylinder Head 14mm thermocouple features a turn in its lower part for an easier installation/uninstallation; it has to fit between the spark plug and the cylinder head.
To keep the sensor in contact with the cylinder head, remove the washer from the plug when installing the thermocouple.
While running the thermocouple cable along with the chassis, keep it as far as possible from other lines (like RPM or lap receiver ones) to minimize cable interferences.
Please note: before screwing the spark plug cable back ensure that the sensor is firmly fixed to the cylinder head. While screwing it, minimize the thermocouple movements to avoid damages to the sensor.
Temperature range of 0-300°c
Sensor cable length 400mm
  • Temperature working range: 0-300°C
  • Cable sensor length: 400mm
  • Cable Type: Compensated
  • K Type thermocouple
  • AiM Cylinder Head 14mm Thermocouple Temperature Sensor
To keep the sensor in contact with the cylinder head, remove the washer from the plug when installing the thermocouple. While running the thermocouple cable along with the chassis, keep it as far as possible from other lines (like RPM or lap receiver ones) to minimize cable interferences.
To use the sensors with EVO4 and EVO4S data loggers, you will need a TC yellow 712 4 pin patch lead (metal binder plug) or to use them with an AIM TC Hub or directly to a MyChron4 or MyChron5 kart lap timer/dash logger, you will need a TC yellow 712 3 pin patch lead (metal binder plug). MXS, MXG, MXP, MXL2 and EVO5 will require a TC - TC yellow patch lead. To connect the thermocouples to these Aim dash/loggers, you need to use the dedicated harness supplied with your device.
