1 de 2
AiM Water/Oil Temperature Sensor Thermo Resistor 1/8th NPT Thread Motocross
SKU: S-T-8TH
Precio regular
£70.00
Precio regular
Precio de venta
£70.00
The AiM 1/8th NPT Thermo resistor temperature sensor is suitable for reading water and oil temperatures.
Suitable for water/oil temperature 4 pins 719 male binder
1/8th NPT
AiM Water Temperature Sensor Thermo Resistor 1/8th NPT Thread
Sensor cable length 25cm
  • Temperature working range: 0-150°C (32-302°F)
  • Cable sensor length: 25cm
  • 1/8th Thermo resistor
  • 4 pins male 719 Binder connection
  • 2kΩ 1% resistor between pins 1 and 4
  • AiM Water Temperature Sensor 1/8th thread Thermo Resistor
1/8th NPT
