{"product_id":"super-b-epsilon-12v100ah-lithium-traction-battery","title":"Batería de tracción de litio Super B Epsilon 12V100Ah","description":"\u003cstyle\u003e\n  .test{\n    background:none !important;\n  }\n  .test img{\n     margin-block:0 \n  }\n  .mb-2{\n    margin-block:0;\n  }\n  .LandingPage-CatTitle {\n        font-size: 24px;margin-block;\n        text-align: center;\n      font-weight:600;\n    }\n  .LandingPage-CatSubTitle {\n        font-size: 22px;\n        text-align: center;\n      margin:0;\n      font-weight:600;\n    }\n    .TextBoxes {\n        font-size: 20px;\n        line-height: 32px;\n        text-align: center;\n    }\n  hr {\n    border: none;\n    height: 0.1rem;\n    background-color: rgba(var(--color-foreground), 0.2);\n    display: block;\n    margin: 5rem 0;\n}\n  .section-dark-bg {\n    padding: 0px 20px!important;\n  }\n  .performance-box {\n    background-color: #999;\n    padding: 20px;\n    display: flex;\n    flex-direction: column;\n    justify-content: center;\n    align-items: center;\n    width: 150px;\n    max-width: 150px;\n    color: white;\n    text-align: center;\n  }\n  .performance-box p {\n    margin-bottom: 0;\n    font-size: 15px;\n    line-height: 19px;\n  }\n  .box-container {\n    display: flex;\n    gap: 20px;\n    flex-wrap: wrap;\n    justify-content: center;\n  }\n  .features-container {\n    margin-top: 50px;\n    display: flex;\n    gap: 20px;\n    flex-wrap: wrap;\n    display: flex;\n    gap: 20px;\n    flex-wrap: wrap;\n    align-items: center;\n    justify-content: center;\n  }\n\n  .container {\n    display: flex;\n    flex-wrap: wrap;\n    justify-content: space-between;\n    margin-top: 50px;\n  }\n\n  .superb-section {\n    flex-basis: calc(\n      50% - 20px\n    ); \/* Adjust the 20px to control the gap between sections *\/\n    box-sizing: border-box;\n    margin-bottom: 20px; \/* Space between sections vertically *\/\n    padding: 20px;\n    border: 1px solid #cbcbcb;\n    border-radius: 0.75rem;\n  }\n  .superb-row {\n    display: flex;\n    margin-bottom: 5px; \/* Space between rows *\/\n  }\n\n  .superb-title,\n  .superb-spec {\n    flex: 1;\n    font-size: 14px;\n  }\n  .superb-spec {\n    color: #999;\n  }\n.certs-container{\n    margin-top: 50px;\n    display:flex;\n    gap:10px;\n  flex-wrap:wrap;\n      justify-content: center;\n}\n  .certs-container img {\n    opacity: 0.4;\n  }\n  .sq-cont {\n    display: flex;\n    flex-direction: column;\n    align-items: center;\n  }\n  .downloads-container {\n    margin-top: 50px;\n    display: flex;\n    justify-content: space-around;\n    flex-wrap: wrap;\n    gap: 20px;\n    width: 100%;\n  }\n  .download-item {\n    display: flex;\n    flex-direction: column;\n    align-items: center;\n  }\n  \/* Responsive design for mobile *\/\n  @media (max-width: 768px) {\n    .superb-section {\n      flex-basis: 100%;\n    }\n    .LandingPage-CatTitle {\n            font-size: 22px;\n        }\n    .LandingPage-CatSubTitle {\n            font-size: 20px;\n        }\n        .TextBoxes {\n            font-size: 18px;\n            line-height: 32px;\n        }\n  }\n\u003c\/style\u003e  \u003cdiv style=\"display: flex; justify-content: center;\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/superbLogo.png?v=1710418318\" width=\"392\" height=\"167\" alt=\"Super B lithium batteries\"\u003e\u003c\/div\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003eSuper B Epsilon: Potencia para un rendimiento óptimo.\u003c\/h2\u003e  \u003cp class=\"TextBoxes\"\u003eLa batería de fosfato de hierro y litio Super B Epsilon de 12 V y 100 Ah ofrece la mayor capacidad de potencia disponible actualmente en una carcasa de tamaño estándar. Diseñada específicamente para aplicaciones exigentes en deportes de motor, náutica, vehículos recreativos y sistemas de energía aislados, estas baterías ligeras proporcionan un rendimiento superior gracias a su sistema de gestión de batería (BMS) integrado, calentamiento automático y monitorización Bluetooth.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003eDiseñado por \u003ca href=\"https:\/\/www.aimshop.com\/collections\/super-b-energy-motorsport-lithium-batteries\" title=\"Super B Energy Batteries\"\u003eEnergía Super B\u003c\/a\u003e,  La batería Epsilon proporciona energía de litio fiable con funciones avanzadas de seguridad, monitorización y rendimiento térmico, lo que la convierte en la opción preferida tanto para equipos de automovilismo como para aventureros en constante movimiento.\u003c\/p\u003e  \u003chr\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003eUso previsto de la batería Super B Epsilon 12V100Ah\u003c\/h2\u003e  \u003cp class=\"TextBoxes\"\u003eLa batería de tracción de litio Super B Epsilon de 12 V y 100 Ah ofrece un rendimiento óptimo para entornos de competición. Su alta corriente de descarga y su diseño robusto la hacen ideal para equipos de automovilismo que exigen una potencia constante bajo presión.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003eMás allá del automovilismo, esta batería destaca en vehículos recreativos, vehículos comerciales, embarcaciones de recreo, buques comerciales y aplicaciones estacionarias donde el espacio, el peso y la fiabilidad son cruciales. Puede utilizarse para el suministro de energía fuera de la red, el suministro de energía marina o como medio para el almacenamiento de energía (renovable). Su tamaño compacto y su carga rápida la convierten en la solución ideal para reemplazar los voluminosos sistemas AGM o de plomo-ácido.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003e\u003cstrong\u003eTenga en cuenta:\u003c\/strong\u003e No se puede utilizar como batería de arranque. Nunca instale varias baterías Epsilon de iones de litio en serie. Se pueden conectar hasta 8 baterías en paralelo para aumentar la capacidad total hasta 800 Ah en el caso de la variante Epsilon de 12 V y 100 Ah.\u003c\/p\u003e  \u003chr\u003e  \u003cstyle\u003e\n  .features_container {\n  max-width: 1200px;\n      margin: 0 auto;\n      padding-bottom: 20px !important;\n}\n\n.features_title {\n  font-size: 32px;\n  font-weight: 700;\n  text-align: center;\n  margin-bottom: 40px;\n  color: #333;\n  text-transform: uppercase;\n  letter-spacing: 1px;\n}\n\n.features_grid {\n  display: grid;\n  grid-template-columns: repeat(2, 1fr);\n  gap: 20px;\n  background-color: #f9f9f9;\n  padding: 30px;\n  border-radius: 8px;\n  box-shadow: 0 2px 10px rgba(0, 0, 0, 0.05);\n}\n\n.features_item {\n  font-size: 16px;\n  color: #555;\n  text-align: center;\n  padding: 15px;\n  background-color: #fff;\n  border: 1px solid #eee;\n  border-radius: 4px;\n  transition: transform 0.2s ease, box-shadow 0.2s ease;\n}\n\n\/* Mobile adjustments *\/\n@media (max-width: 600px) {\n  .features_grid {\n    grid-template-columns: 1fr; \/* Single column on mobile *\/\n    padding: 20px;\n  }\n\n  .features_title {\n    font-size: 24px;\n    margin-bottom: 30px;\n  }\n\n  .features_item {\n    font-size: 14px;\n    padding: 12px;\n  }\n}\n\u003c\/style\u003e  \u003cdiv class=\"features_container\"\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003e¿Por qué elegir Super B Epsilon 12V100Ah?\u003c\/h2\u003e  \u003cdiv class=\"features_grid\"\u003e  \u003cdiv class=\"features_item\" style=\"display: flex; align-items: center;\"\u003eUtiliza celdas prismáticas de fosfato de hierro y litio (LiFePO4) de primera calidad para mayor seguridad, durabilidad y larga vida útil.\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eEl sistema integrado de gestión de la batería (BMS) proporciona protección en tiempo real contra sobrecarga, sobrecalentamiento, cortocircuito y desequilibrio, lo que garantiza la máxima durabilidad y rendimiento en cada carga.\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eEl calentamiento interno automático permite la carga a temperaturas bajo cero, lo que lo hace ideal para entornos hostiles.\u003c\/div\u003e  \u003cdiv class=\"features_item\" style=\"display: flex; align-items: center; justify-content: center;\"\u003eCarcasa robusta fabricada con materiales respetuosos con el medio ambiente (totalmente reciclable).\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eMonitorización de la batería\/almacenamiento del historial\u003c\/div\u003e  \u003cdiv class=\"features_item\" style=\"display: flex; align-items: center; justify-content: center;\"\u003eEquilibrio celular adaptativo\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eEntradas\/salidas configurables de uso general para controlar dispositivos externos como cargadores.\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eConexión de salida de alimentación independiente para alimentar accesorios. Salida analógica SoC.\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eTerminales de aluminio revestidos con capacidad de conexión múltiple, que incluyen sensores de temperatura para protección.\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eTamaños LN3\/DIN H6 y LN5\/DIN H8 disponibles en diferentes capacidades (100 Ah y \u003ca title=\"Super B Epsilon 12V150Ah\" href=\"https:\/\/www.aimshop.com\/products\/super-b-epsilon-12v150ah-lithium-traction-battery\"\u003e150 Ah\u003c\/a\u003e)\u003c\/div\u003e  \u003cdiv class=\"features_item\" style=\"display: flex; align-items: center;\"\u003eLímite de descarga integrado y configurable (apagado en función del estado de carga).\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eLa conectividad CAN bus (cableada), LIN bus (cableada) y Bluetooth (inalámbrica) te permite monitorizar la batería en tiempo real mediante la aplicación gratuita Be In Charge.\u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cp class=\"TextBoxes\"\u003eEn comparación con las baterías tradicionales, la batería de tracción de litio Super B Epsilon de 12 V y 100 Ah ofrece tiempos de carga más rápidos, una vida útil significativamente mayor y más energía útil por ciclo. Con más de 5000 ciclos de descarga completa y una eficiencia energética superior al 96 %, representa una inversión en rendimiento a largo plazo y tranquilidad.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003eSu baja autodescarga (menos del 3 % al mes) garantiza que la batería conserve su carga, incluso cuando no está en uso, lo que resulta ideal para aplicaciones estacionales como carreras, navegación o viajes por tierra.\u003c\/p\u003e  \u003chr\u003e  \u003cdiv class=\"section-dark-bg\"\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003eActuación\u003c\/h2\u003e  \u003cdiv class=\"box-container\"\u003e  \u003cdiv class=\"performance-box rte\"\u003e  \u003cimg class=\"mb-2\" src=\"https:\/\/s3.eu-central-1.amazonaws.com\/superb-com\/sulu\/uploads\/cache\/64x64\/08\/364-Low_maintenance_white.png?v=1-0\" alt=\"Low maintenance\" width=\"32\"\u003e  \u003cp class=\"carousel__text text-center\"\u003eBajo mantenimiento\u003c\/p\u003e  \u003c\/div\u003e  \u003cdiv class=\"performance-box rte\"\u003e  \u003cimg class=\"mb-2\" src=\"https:\/\/s3.eu-central-1.amazonaws.com\/superb-com\/sulu\/uploads\/cache\/64x64\/10\/322-Fast_charging_white.png?v=1-0\" alt=\"Fast charging\" width=\"32\"\u003e  \u003cp class=\"carousel__text text-center\"\u003eCarga rápida\u003c\/p\u003e  \u003c\/div\u003e  \u003cdiv class=\"performance-box rte\"\u003e  \u003cimg class=\"mb-2\" src=\"https:\/\/s3.eu-central-1.amazonaws.com\/superb-com\/sulu\/uploads\/cache\/64x64\/03\/349-LiFePO4_white.png?v=1-0\" alt=\"Safest lithium technology\" width=\"32\"\u003e  \u003cp class=\"carousel__text text-center\"\u003eLa tecnología de litio más segura\u003c\/p\u003e  \u003c\/div\u003e  \u003cdiv class=\"performance-box rte\"\u003e  \u003cimg class=\"mb-2\" src=\"https:\/\/s3.eu-central-1.amazonaws.com\/superb-com\/sulu\/uploads\/cache\/64x64\/02\/334-High_discharge_currents_white.png?v=1-0\" alt=\"High discharge currents\" width=\"32\"\u003e  \u003cp class=\"carousel__text text-center\"\u003eAltas corrientes de descarga\u003c\/p\u003e  \u003c\/div\u003e  \u003cdiv class=\"performance-box rte\"\u003e  \u003cimg class=\"mb-2\" src=\"https:\/\/s3.eu-central-1.amazonaws.com\/superb-com\/sulu\/uploads\/cache\/64x64\/03\/328-High_capacity_white.png?v=1-0\" alt=\"High capacity\" width=\"32\"\u003e  \u003cp class=\"carousel__text text-center\"\u003eAlta capacidad\u003c\/p\u003e  \u003c\/div\u003e  \u003cdiv class=\"performance-box rte\"\u003e  \u003cimg class=\"mb-2\" src=\"https:\/\/s3.eu-central-1.amazonaws.com\/superb-com\/sulu\/uploads\/cache\/64x64\/05\/355-Lightweight_white.png?v=1-0\" alt=\"Low weight\" width=\"32\"\u003e  \u003cp class=\"carousel__text text-center\"\u003ePeso ligero\u003c\/p\u003e  \u003c\/div\u003e  \u003cdiv class=\"performance-box rte\"\u003e  \u003cimg class=\"mb-2\" src=\"https:\/\/s3.eu-central-1.amazonaws.com\/superb-com\/sulu\/uploads\/cache\/64x64\/01\/361-Long_service_life_white.png?v=1-0\" alt=\"High cycle count\" width=\"32\"\u003e  \u003cp class=\"carousel__text text-center\"\u003eRecuento de ciclos elevado\u003c\/p\u003e  \u003c\/div\u003e  \u003cdiv class=\"performance-box rte\"\u003e  \u003cimg class=\"mb-2\" src=\"https:\/\/s3.eu-central-1.amazonaws.com\/superb-com\/sulu\/uploads\/cache\/64x64\/09\/370-Low_self_discharge_white.png?v=1-0\" alt=\"Low self-discharge\" width=\"32\"\u003e  \u003cp class=\"carousel__text text-center\"\u003eBaja autodescarga\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003chr style=\"margin-bottom: 10px;\"\u003e  \u003cdiv style=\"margin: 0 auto; width: fit-content;\"\u003e\u003cimg alt=\"Super B Epsilon 12V100Ah Lithium Traction Battery\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/3276-Epsilon_12V100Ah_1120x1300px_v1.jpg\"\u003e\u003c\/div\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003e¿Es el LiFePO4 mejor que el ion litio?\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eLas baterías Super B utilizan LiFePO4, que supera al ion de litio en seguridad, ofreciendo una vida útil más larga y una mayor estabilidad térmica, lo que las hace ideales para un uso prolongado. Si bien el ion de litio puede ser inicialmente más económico y requerir menos mantenimiento, su susceptibilidad al sobrecalentamiento plantea riesgos.\u003c\/p\u003e  \u003chr\u003e  \u003ch2 style=\"margin: 0; margin-bottom: 20px; margin-top: 50px; margin-left: 20px;\" class=\"LandingPage-CatTitle\"\u003eSolución de problemas de Bluetooth de Epsilon\u003c\/h2\u003e  \u003cdiv style=\"overflow: hidden; border: 1px solid grey; border-radius: 1.25rem; max-width: 1000px; margin: 0 auto;\"\u003e\u003cvideo poster=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Shop_Youtube_Product_Videos_Enable.png?v=1590787838\" class=\"video embed-responsive-item\" width=\"100%\" height=\"100%\" controls=\"controls\"\u003e        \u003csource src=\"https:\/\/player.vimeo.com\/external\/451787804.hd.mp4?s=27140cf7dcfe98958249cc76fd514d6262b631e2\u0026amp;profile_id=175\" type=\"video\/mp4\"\u003e\u003c\/video\u003e\u003c\/div\u003e  \u003chr\u003e  \u003ch2 style=\"margin: 0; margin-bottom: 20px; margin-top: 50px; margin-left: 20px;\" class=\"LandingPage-CatTitle\"\u003eConectores de terminales automotrices Epsilon\u003c\/h2\u003e  \u003cdiv style=\"overflow: hidden; border: 1px solid grey; border-radius: 1.25rem; max-width: 1000px; margin: 0 auto;\"\u003e\u003cvideo poster=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Shop_Youtube_Product_Videos_Enable.png?v=1590787838\" class=\"video embed-responsive-item\" width=\"100%\" height=\"100%\" controls=\"controls\"\u003e        \u003csource src=\"https:\/\/player.vimeo.com\/external\/425480523.hd.mp4?s=f7ab4ed8be62783db0f57cd29e9459cc790342d2\u0026amp;profile_id=175\" type=\"video\/mp4\"\u003e\u003c\/video\u003e\u003c\/div\u003e  \u003chr\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003e¿Por qué elegir las pilas Super B?\u003c\/h2\u003e  \u003cp class=\"TextBoxes\"\u003eLas baterías Super B Energy son líderes en tecnología avanzada de baterías de litio, con un enfoque en soluciones energéticas de alto rendimiento y larga duración para sistemas móviles y aislados de la red eléctrica. La batería de tracción de litio Super B Epsilon 12V100Ah refleja esta trayectoria: diseñada para una mayor resistencia, pensada para profesionales y respaldada por campeones.\u003c\/p\u003e  \u003chr\u003e  \u003ch3 style=\"margin: 0; margin-bottom: 20px; margin-top: 50px; margin-left: 20px;\" class=\"LandingPage-CatSubTitle\"\u003eCertificaciones\u003c\/h3\u003e  \u003cdiv class=\"certs-container\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/2284-R10.jpg?v=1710418889\" alt=\"UN ECE\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/388-CE.jpg?v=1710418890\" alt=\"CE\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/385-FCC.jpg?v=1710418888\" alt=\"FCC\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/1409-UL_Certified.jpg?v=1710418888\" alt=\"UL Certified\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/391-UN38.3.jpg?v=1710418888\" alt=\"UN38.3\"\u003e  \u003c\/div\u003e  \u003chr\u003e  \u003cdiv style=\"display: flex; align-items: center; gap: 10px; flex-direction: column; margin-top: 50px;\"\u003e  \u003ch3 style=\"margin: 0; margin-bottom: 20px;\" class=\"LandingPage-CatSubTitle\"\u003eGarantía de 3 años\u003c\/h3\u003e  \u003cp style=\"margin: 0 auto; max-width: 600px;\" class=\"TextBoxes\"\u003eLa batería de tracción de litio Super B Epsilon 12V100Ah viene con una garantía del fabricante de 3 años y \u003ca href=\"https:\/\/www.aimshop.com\/pages\/support-home\" title=\"Aim Support\"\u003eapoyo\u003c\/a\u003e de \u003ctc\u003eAim\u003c\/tc\u003e El experimentado equipo técnico de Super B está a su disposición para su tranquilidad. Tanto si está diseñando una configuración energética personalizada como si está actualizando el sistema de alimentación de su vehículo de competición, Super B ofrece baterías diseñadas y probadas en los entornos más exigentes para garantizar un alto rendimiento durante muchos años.\u003c\/p\u003e  \u003cimg style=\"margin-top: 20px;\" alt=\"Super B Epsilon 3 year warranty\" height=\"124\" width=\"195\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Super_B_3_Year_Warranty.png?v=1612176333\"\u003e  \u003c\/div\u003e  \u003chr\u003e  \u003cstyle\u003e\n        .testCont{\n            margin:0;\n            padding:0;\n            display:flex;\n            flex-direction:column;\n            align-items:center;\n        }\n        .testContainer{\n            display:Flex;\n            flex-wrap:wrap;\n            gap:30px;\n            flex-shrink: 1;\n            justify-content: center;\n        } \n        .test{\n            max-width: 600px;\n            display:flex;\n            gap: 30px;\n            transition:all 1s ease;\n            border: 1px solid transparent;\n            overflow:hidden;\n        }\n        .testImage{\n            object-fit: cover;\n            height:100%;\n        }\n        .testCont{\n            display:flex;\n            justify-content:center;\n            padding-right:30px;\n            color:black;\n            \n        }\n        .testCont p {\n            text-decoration:none !important\n        }\n        .test{\n            cursor:pointer;\n            border-radius: 1.75rem;\n            box-shadow: 0 10px 15px -3px rgb(0 0 0 \/ 0.1), 0 4px 6px -4px rgb(0 0 0 \/ 0.1);\n\n\n        }\n        .test p span{\n            color:blue;\n        }\n        @media screen and (max-width: 600px) {\n            .test{\n                flex-direction:column;\n                align-items:center;\n            }\n            .testCont p{\n                text-align:center;  \n            }\n          .testCont{\n            padding-left: 30px;\n          }\n          .testImage{\n            width:100%;\n          }\n          .outerCont{\n            padding:0;\n          }\n        }\n  a:link { \n  text-decoration: none; \n} \na:visited { \n  text-decoration: none; \n} \na:hover { \n  text-decoration: none; \n} \na:active { \n  text-decoration: none; \n}\n    \u003c\/style\u003e  \u003cdiv class=\"testCont outerCont\"\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eTestimonios\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eLas baterías Super B Energy, en las que confían equipos de competición, aventureros y navegantes de todo el mundo, son reconocidas por su fiabilidad, tamaño compacto y perfecta integración con los sistemas modernos. Echa un vistazo a algunos testimonios de personas que han utilizado Super B en sus propios proyectos.\u003c\/p\u003e  \u003cdiv class=\"testContainer\"\u003e  \u003ca class=\"test\" href=\"https:\/\/www.aimshop.com\/pages\/feel-the-breeze\"\u003e\u003cimg alt=\"\" height=\"200\" width=\"300\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/3022-Feel_the_breeze_1.jpg?v=1721300887\" class=\"testImage\"\u003e  \u003cdiv class=\"testCont\"\u003e  \u003cp style=\"text-align: left;\" class=\"TextBoxes\"\u003e\u0026quot;Estas baterías son revolucionarias para vivir sin conexión a la red eléctrica y sabemos, por lo que nos han contado otros navegantes, que no somos los únicos que nos estamos pasando al litio. Super B es la mejor marca del mercado. Mientras continuamos nuestro viaje alrededor del mundo, nos sentimos seguros sabiendo que estas podrían ser las últimas baterías que necesitemos instalar.\u0026quot; -Sailing Fair Isle \u003cspan\u003e.  ..Más\u003c\/span\u003e\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/a\u003e\u003ca class=\"test\" href=\"https:\/\/www.aimshop.com\/pages\/stepsover-world-tour\"\u003e\u003cimg alt=\"\" height=\"200\" width=\"300\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/4097-header_stepsover.jpg?v=1721304666\" class=\"testImage\"\u003e  \u003cdiv class=\"testCont\"\u003e  \u003cp style=\"text-align: left;\" class=\"TextBoxes\"\u003e\u0026quot;Nuestro yate de vela cuenta con 8 baterías de fosfato de hierro y litio (LiFePO4), una mejora sustancial respecto a las antiguas de plomo-ácido. Su facilidad de instalación, calidad y durabilidad hicieron que la decisión fuera obvia.\u0026quot; -Feel the Breeze \u003cspan\u003e.  ..Más\u003c\/span\u003e\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/a\u003e\u003ca class=\"test\" href=\"https:\/\/www.aimshop.com\/pages\/sailing-fair-isle\"\u003e\u003cimg alt=\"\" height=\"200\" width=\"300\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/4190-Hero_Sailing_Fair_Isle.jpg?v=1721304908\" class=\"testImage\"\u003e  \u003cdiv class=\"testCont\"\u003e  \u003cp style=\"text-align: left;\" class=\"TextBoxes\"\u003e\u0026quot;Estas baterías son revolucionarias para vivir sin conexión a la red eléctrica y sabemos, por lo que nos han contado otros navegantes, que no somos los únicos que nos estamos pasando al litio. Super B es la mejor marca del mercado. Mientras continuamos nuestro viaje alrededor del mundo, nos sentimos seguros sabiendo que estas podrían ser las últimas baterías que necesitemos instalar.\u0026quot; -Sailing Fair Isle \u003cspan\u003e.  ...Más\u003c\/span\u003e\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/a\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003ch5\u003ePresupuesto\u003c\/h5\u003e  \u003cdiv class=\"container\"\u003e  \u003cdiv class=\"superb-section\"\u003e  \u003ch2 style=\"text-align: left; color: #999;\" class=\"LandingPage-CatTitle\"\u003eESPECIFICACIONES ELÉCTRICAS\u003c\/h2\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eCapacidad nominal\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e100 Ah\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eVoltaje de circuito abierto\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e13,2 V\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eautodescarga\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e\u0026lt;3% mensual\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eCiclo de vida\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e\u0026gt;5000 ciclos (al 100% del Departamento de Defensa)\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eVoltaje\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e12 voltios\u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-section\"\u003e  \u003ch2 style=\"text-align: left; color: #999;\" class=\"LandingPage-CatTitle\"\u003eESPECIFICACIONES MECÁNICAS\u003c\/h2\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eDimensiones (largo x ancho x alto)\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e278 x 175 x 190 mm\/11” x 6,9” x 7,5” (=DIN H6\/LN3)\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003ePeso\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e10,7 kg\/23,6 libras\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eMaterial del caso\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003ePC\/ABS\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eProtección contra la entrada de polvo y agua\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003eIP56\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eTipo de célula\/Química\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003ePrismático - LiFePO4\u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-section\"\u003e  \u003ch2 style=\"text-align: left; color: #999;\" class=\"LandingPage-CatTitle\"\u003eCARGAR \u0026amp; ESPECIFICACIONES DE DESCARGA\u003c\/h2\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eMétodo de cobro\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003eCCCV\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eVoltaje de carga\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e14,3 V - 14,6 V\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eCorriente de carga máxima\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e90A\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eVoltaje de fin de descarga\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e8V\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eCorriente de descarga continua\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e190A\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eCorriente de pulso de descarga\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e300A\u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-section\"\u003e  \u003ch2 style=\"text-align: left; color: #999;\" class=\"LandingPage-CatTitle\"\u003eESPECIFICACIONES DE TEMPERATURA\u003c\/h2\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eTemperatura de carga\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e-30 °C a 45 °C\/-22 °F a 113 °F\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eTemperatura de descarga\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e-20 °C a 60 °C\/-4 °F a 140 °F\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eTemperatura de almacenamiento\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e-20 °C a 45 °C\/-4 °F a 113 °F\u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-section\"\u003e  \u003ch2 style=\"text-align: left; color: #999;\" class=\"LandingPage-CatTitle\"\u003eESPECIFICACIONES DE CUMPLIMIENTO\u003c\/h2\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eCertificaciones\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003eCE, FCC, ONU 38.3, ONU ECE R10.06, UL 1642 (Celdas)\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eClasificación de envío\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003eONU 3480\u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-section\"\u003e  \u003ch2 style=\"text-align: left; color: #999;\" class=\"LandingPage-CatTitle\"\u003eESPECIFICACIONES GENERALES\u003c\/h2\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003eEAN-13\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003e8718531362208\u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"superb-row\"\u003e  \u003cdiv class=\"superb-title\"\u003edesignación de la batería\u003c\/div\u003e  \u003cdiv class=\"superb-spec\"\u003eIFpP\/27\/148\/135[2p4s] M\/-20+60\/95\u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003ch5\u003eGuía de inicio rápido\u003c\/h5\u003e  \u003cdiv class=\"sq-cont\"\u003e  \u003ch2 style=\"color: #999; margin: 0; margin-top: 50px; margin-bottom: 20px;\" class=\"LandingPage-CatTitle\"\u003eDisponible para descargar \u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/super-b-epsilon-12v100ah-150ah-qsg-v1-1-web.pdf?v=1710422150\" rel=\"’noopener’\" download=\"\" target=\"_blank\"\u003eAquí\u003c\/a\u003e  \u003c\/h2\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/qs1.png?v=1710421856\" width=\"623\" height=\"742\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/qs2.png?v=1710421856\" width=\"620\" height=\"880\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/qs3.png?v=1710421856\" width=\"624\" height=\"884\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/qs4.png?v=1710421856\" width=\"629\" height=\"755\"\u003e  \u003c\/div\u003e  \u003ch5\u003eAplicación móvil\u003c\/h5\u003e  \u003cdiv style=\"margin-top: 50px;\"\u003e  \u003ch2 style=\"color: #999; margin: 0;\" class=\"LandingPage-CatTitle\"\u003eToma el control: software y aplicaciones.\u003c\/h2\u003e  \u003cp class=\"TextBoxes\"\u003eSuper B proporciona el software Be In Charge, que permite leer el sistema BMS interno. Este software utiliza un convertidor CAN a USB para conectarse a la interfaz de comunicación. Permite leer el estado actual de la batería, como el voltaje y la temperatura de las celdas, así como información estadística. El software Be In Charge también se puede usar para actualizar el firmware de la batería de iones de litio. El software y el hardware de Be In Charge no están incluidos en el suministro de la batería de iones de litio. Super B también ofrece la aplicación Be In Charge para dispositivos móviles Android y Apple. La aplicación está disponible en Google Play Store y en la App Store de Apple.\u003c\/p\u003e  \u003cdiv style=\"margin: 0 auto; width: fit-content;\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/codescan.png?v=1710425607\" width=\"137\" height=\"150\" alt=\"superb app\"\u003e\u003c\/div\u003e  \u003c\/div\u003e  \u003ch5\u003eDescargas\u003c\/h5\u003e  \u003cdiv class=\"downloads-container\"\u003e  \u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/manual_epsilon_12v100ah_12v150ah_v1-8_en.pdf?v=1710425813\"\u003e  \u003cdiv class=\"download-item\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/User_Guide_AiM_iCON_2289456f-97fa-4d13-84ea-3ede554821e9_100x100.png?v=1590766826\"\u003e Manual de usuario\u003c\/div\u003e  \u003c\/a\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/super-b-epsilon-12v100ah-150ah-qsg-v1-1-web.pdf?v=1710422150\"\u003e  \u003cdiv class=\"download-item\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/User_Guide_AiM_iCON_2289456f-97fa-4d13-84ea-3ede554821e9_100x100.png?v=1590766826\"\u003e Guía de inicio rápido\u003c\/div\u003e  \u003c\/a\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/charging_manual_sb_energy_batteries_v1-2_en.pdf?v=1710424901\"\u003e  \u003cdiv class=\"download-item\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/User_Guide_AiM_iCON_2289456f-97fa-4d13-84ea-3ede554821e9_100x100.png?v=1590766826\"\u003e Manual de carga\u003c\/div\u003e  \u003c\/a\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/datasheet-epsilon_12v100ah_v2-0_en.pdf?v=1710426059\"\u003e  \u003cdiv class=\"download-item\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e Ficha de datos\u003c\/div\u003e  \u003c\/a\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/msds_epsilon_12v100ah-1.pdf?v=1710425259\"\u003e  \u003cdiv class=\"download-item\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e Hoja de datos de seguridad\u003c\/div\u003e  \u003c\/a\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Epsilon_100Ah_InclBracket_2023-05-04.zip?v=1710509897\" download=\"\"\u003e  \u003cdiv class=\"download-item\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e Archivo CAD\u003c\/div\u003e  \u003c\/a\u003e  \u003c\/div\u003e","brand":"Super B","offers":[{"title":"Default Title","offer_id":31995732918374,"sku":"SB-E-100","price":1040.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_Super_B_Epsilon_12V100Ah_Lithium_Traction_Battery_29936df3-7dfe-4993-b081-94019772175d.webp?v=1776067895","url":"https:\/\/www.aimshop.com\/es\/products\/bateria-de-traccion-de-litio-super-b-epsilon-12v100ah","provider":"AimShop.com","version":"1.0","type":"link"}
