Ducati 848, 1098, 1198 AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-DUC-2
- Precio regular
- £717.00
- Precio regular
- Precio de venta
- £717.00
- Precio unitario
- por
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Ducati this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide | Ducati ECU connection cable |
This kit has been specifically designed for Ducati bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Ducati ECU will give you all the engine performance information you need to help improve your driving performance.
The plug & play cable currently fits the following Ducati bike models:
848 Base/EVO/EVO Corse - 2007-2013 | 1098 Base/S/S Tricolore/R - 2007-2009 |
1198 Base/S/S Corse/R Corse/SP - 2009-2011 |
The Ducati ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
Below is the pinout drawing for the Ducati 848, 1098, 1198 plug & play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- User manual
- AiM Ducati Connection Cable
- Bracket
- 2 self-locking nuts
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Ducati this kit will ensure an improvement in your driving performance.Key Features :
This kit has been specifically designed for Ducati bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Ducati ECU will give you all the engine performance information you need to help improve your driving performance.Plug & Play
The Ducati ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike. The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated. Add a SmartyCam HD/GP HD camera to create an even more powerful system to help provide you with great videos that include all the technical information to help improve your performance. Solo 2 DL gives instant speed, timing splits live data and predictive lap times. The Solo 2 DL has a sharp, high contrast display which helps drivers easily identify the data displayed on the screen. The Solo 2 DL also features a selection of 7 different backlight colours which can be selected to suit your requirements. Please Note: For these models/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.Predictive Lap Timer
- GPS: 10 Hz
- Memory: 4 GB
- Solo 2 DL
- User manual
- Bracket
