1 de 5
Kawasaki AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
SKU: SM-CAM-GP-2-SOLO2-K-KAW-SM-GPC
Precio regular
£2,210.00
Precio regular
Precio de venta
£2,210.00
The Kawasaki plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP gives you the ultimate track day experience.
Database with more than 4,000 tracks worldwide Kawasaki ECU connection cable
This ultimate track day kit has been specifically designed for Kawasaki bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Kawasaki ECU will give you all the engine performance information you need to help improve your driving performance.
SmartyCam 3 GP Features:
The plug & play cable currently fits the following Kawasaki bike models:
Kawasaki Ninja ZX-10R MY2011 - 2001-2015 Kawasaki Ninja ZX-10R MY2011 Racing Kit - 2011-2015
Kawasaki Ninja ZX-10R MY2016 - From 2016 Kawasaki Ninja ZX-10R MY2016 Racing Kit - From 2016
Please Note: The bracket fits Kawasaki models from 2016.
Powerful Combination
The Kawasaki ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
SmartyCam 3 GP
Automatic Start/Stop
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
  • SmartyCam 3 GP
  • Video format: H.264 1920x1080 pixels @ 60 FPSDisplay resolution: 2.4" 240 x 320 pixels
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Waterproof: IP65
Below is the pinout drawing for the Kawasaki plug & Play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • SmartyCam 3 GP - Bullet Cam
  • External CAN cable 2m
  • External power cable
  • Kawasaki Plug & Play connection cable
  • Bracket
  • 2 toothed washers
  • 2 Allen screws M6 x 12mm
SmartyCam 3 GP
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • SmartyCam 3 GP
  • Video Out: 3G-SDI
  • Waterproof: IP65
  • Solo 2 DL
  • Bracket
  • 2 toothed washers
