{"product_id":"aim-solo-2-dl-motocross-track-day-lap-timer-kit","title":"\u003ctc\u003eAim\u003c\/tc\u003e Kit de cronómetro de vueltas para días de pista de motocross Solo 2 DL","description":"\u003cp style=\"display: none;\"\u003eUn cronómetro GPS de alta precisión con conectividad ECU para motos de motocross todoterreno. Proporciona datos precisos de velocidad, tiempos de vuelta y métricas del motor, con transferencia de datos Wi-Fi y RS3 para análisis de rendimiento.\u003c\/p\u003e  \u003cstyle\u003e\n    .LandingPage-CatTitle {\n        font-size: 24px;\n        text-align: center;\n      font-weight:600;\n    }\n    .LandingPage-CatSubTitle {\n        font-size: 22px;\n        text-align: center;\n      margin:0;\n      font-weight:600;\n    }\n    .TextBoxes {\n        font-size: 20px;\n        line-height: 32px;\n        text-align: center;\n    }\n  .features_container {\n  max-width: 1200px;\n      margin: 0 auto;\n padding-top: 20px !important;\n      padding-bottom: 20px !important;\n}\n\n.features_title {\n  font-size: 32px;\n  font-weight: 700;\n  text-align: center;\n  margin-bottom: 40px;\n  color: #333;\n  text-transform: uppercase;\n  letter-spacing: 1px;\n}\n\n.features_grid {\n  display: grid;\n  grid-template-columns: repeat(2, 1fr);\n  gap: 20px;\n  background-color: #f9f9f9;\n  padding: 30px;\n  border-radius: 8px;\n  box-shadow: 0 2px 10px rgba(0, 0, 0, 0.05);\n}\n\n.features_item {\n  font-size: 16px;\n  color: #555;\n  text-align: center;\n  padding: 15px;\n  background-color: #fff;\n  border: 1px solid #eee;\n  border-radius: 4px;\n  transition: transform 0.2s ease, box-shadow 0.2s ease;\n}\n    @media (max-width: 768px) {\n        .LandingPage-CatTitle {\n            font-size: 22px;\n        }\n        .LandingPage-CatSubTitle {\n            font-size: 20px;\n        }\n        .TextBoxes {\n            font-size: 18px;\n            line-height: 32px;\n        }\n    }\n\n\/* Mobile adjustments *\/\n@media (max-width: 600px) {\n  .features_grid {\n    grid-template-columns: 1fr; \/* Single column on mobile *\/\n    padding: 20px;\n  }\n\n  .features_title {\n    font-size: 24px;\n    margin-bottom: 30px;\n  }\n\n  .features_item {\n    font-size: 14px;\n    padding: 12px;\n  }\n}\n    \u003c\/style\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003eEl más preciso \u0026amp; Manera fácil de obtener tiempos de vuelta\u003c\/h2\u003e  \u003cp class=\"TextBoxes\"\u003eMejora tu configuración de motocross todoterreno con uno de los mejores cronómetros de vueltas para deportes de motor del sector: el Solo 2 DL GPS. Equipado con GPS de 25 Hz, conexión a la ECU, giroscopio integrado, interfaz intuitiva y compatibilidad con software de análisis de rendimiento, el Solo 2 DL proporciona tiempos de vuelta precisos y telemetría detallada para que pilotos aficionados y profesionales optimicen su rendimiento y alcancen sus objetivos en pista.\u003c\/p\u003e  \u003cdiv class=\"features_container\"\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003eCaracterísticas principales de Solo 2 DL\u003c\/h2\u003e  \u003cdiv class=\"features_grid\"\u003e  \u003cdiv class=\"features_item\"\u003eRegistro directo de datos de la ECU\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eCronometraje de vueltas predictivo\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eBase de datos de pistas extensa\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003e8 colores de retroiluminación diferentes\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003e10 LED RGB configurables\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eElección de conexión\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eMúltiples modos de carrera: Velocidad, Tiempos \u0026amp; Actuación\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eGPS integrado \u0026amp; Receptor GLONASS\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003e8 páginas de visualización configurables\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eReconocimiento automático de pistas\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eMemoria interna de 4 GB\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eConexión Wi-Fi\u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003chr\u003e  \u003cdiv style=\"text-align: center;\"\u003e\u003cimg alt=\"Solo 2 DL Offroad Motocross Track Day Lap Timer\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Solo-2-DL-Display-Colours_240x240.gif?v=1613590480\"\u003e\u003c\/div\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eSolo 2 DL con conexión a la ECU\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003e\u003ctc\u003eAim\u003c\/tc\u003e Solo 2 DL es el cronómetro GPS más preciso, capaz de mostrar los tiempos de vuelta en directo mientras conduces gracias a los datos de dos constelaciones de satélites desde cualquier lugar del mundo mediante el uso de GPS y Glonass, lo que en definitiva proporciona una mejora significativa en la velocidad de los datos y la precisión del posicionamiento.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003eEl tiempo de arranque se reduce a segundos y los tiempos por vuelta tienen una precisión de dos centésimas de segundo.\u003c\/p\u003e  \u003chr\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eConexión sencilla\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eEl Solo 2 DL se puede conectar a la ECU de la moto de motocross para obtener diversos datos de los sensores instalados. El Solo 2 DL gestiona todas las conexiones de hardware de la ECU y todas las líneas de comunicación, ya sea mediante el puerto OBDII o directamente a través del canal CAN\/RS232. Si el protocolo de la ECU no es compatible, la conexión del Solo 2 DL a un sensor de RPM proporcionará una entrada digital mediante señales de onda cuadrada o de pulso.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003eLos datos muestreados que se registran dependen de la ECU específica y suelen incluir RPM, carga del motor, posición del acelerador (TPS), temperatura del aceite, del aire y del agua, presión del aceite, voltaje de la batería, velocidad, marcha y valor lambda (relación aire\/combustible). La lista de ECU se actualiza constantemente.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003eAñade una cámara SmartyCam HD\/GP HD para crear un sistema aún más potente que te ayude a obtener vídeos increíbles con toda la información técnica necesaria para mejorar tu rendimiento.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003eSolo 2 DL ofrece velocidad instantánea; la sincronización divide los datos en tiempo real y la predicción de vueltas. times.The El Solo 2 DL cuenta con una pantalla nítida y de alto contraste que facilita a los conductores la identificación de los datos mostrados. Además, ofrece siete colores de retroiluminación diferentes para que elijas el que mejor se adapte a tus necesidades.\u003c\/p\u003e  \u003cdiv style=\"text-align: center;\"\u003e  \u003c!-- DIVISOR --\u003e\u003chr class=\"ProductDescription\"\u003e  \u003c\/div\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eCronómetro predictivo de vueltas\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eLa tecnología GPS ofrece mayor fiabilidad en la función de cronometraje predictivo de vueltas, permitiéndote ver en tiempo real cómo se compara tu vuelta actual con tu mejor tiempo. Los LED también son configurables para indicar visualmente si vas más rápido o más lento. Además, puedes personalizar la visualización de la pantalla para mostrar los datos que desees.\u003c\/p\u003e  \u003cdiv style=\"text-align: center;\"\u003e\u003chr class=\"ProductDescription\"\u003e\u003c\/div\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eRecuperación de datos en pantalla\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eEl Solo 2 DL se puede usar para carreras en circuito, eventos de regularidad y pruebas de rendimiento, como la aceleración de 0 a 96 km\/h (0 a 60 mph). Al igual que en el modo de carreras en circuito, todos los datos se registran y se pueden revisar inmediatamente después de cada carrera o sesión de prueba.\u003c\/p\u003e  \u003cdiv style=\"text-align: center;\"\u003e\u003chr class=\"ProductDescription\"\u003e\u003c\/div\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eSolo 2 DL Creación de nuevas pistas y nuestra base de datos de pistas\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eSolo 2 DL te permite crear un trazado de circuito nuevo, temporal o permanente. Ya sea un recorrido punto a punto para rally o un circuito cerrado.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003eCon más de 4000 pistas precargadas de todo el mundo, el Solo 2 DL, al encenderlo, identifica su posición. Si la pista no está entre las precargadas, el Solo 2 creará una nueva. Al comenzar a conducir, reconoce automáticamente las coordenadas de la línea de salida y empieza a registrar los tiempos de vuelta cada vez que pasas por ella.\u003c\/p\u003e  \u003cdiv style=\"text-align: center;\"\u003e\u003chr class=\"ProductDescription\"\u003e\u003c\/div\u003e  \u003cdiv\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Solo_2_DL_Wifi_Communication_With_PC.png?v=1614779557\"\u003e\u003c\/div\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eComunicación Wi-Fi con el PC\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eEl Solo 2 DL incorpora Wi-Fi. Si deseas analizar tus datos con mayor detalle, transfiérelos de forma segura y rápida a un portátil o ordenador situado a una distancia de hasta 50 metros, sin necesidad de conectores ni cables. A continuación, podrás importar los datos al software Race Studio 3.\u003c\/p\u003e  \u003chr class=\"ProductDescription\"\u003e  \u003cdiv\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/BikeSetSC3TrackDay-04.webp?v=1746694402\"\u003e\u003c\/div\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eExpansiones compatibles\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eAñade SmartyCams y una unidad de control Lambda para mejorar el rendimiento de tus datos.\u003c\/p\u003e  \u003chr class=\"ProductDescription\"\u003e  \u003cdiv\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\"\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Free_Download.png?v=1629297377\"\u003e\u003c\/a\u003e\u003c\/div\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003eConfigurar \u0026amp; Analizar con Race Studio 3\u003c\/h2\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eConfiguración\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eCon Race Studio 3, puedes crear, modificar, eliminar, importar y exportar configuraciones con todos los canales, controladores de ECU, canales matemáticos, páginas de visualización, salidas digitales, alarmas, luces de cambio y todas las expansiones que necesites. También puedes gestionar el mapa de todos tus circuitos y comparar dos vueltas viendo el vídeo grabado por las cámaras SmartyCam HD.\u003c\/p\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eAnálisis\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eCon Race Studio 3, también puedes analizar todos los datos registrados por Solo 2 DL y descargarlos a tu PC: gráficos, histogramas y tablas te ayudarán a estudiar tu rendimiento, proporcionándote información objetiva para evitar errores y mejorar tus tiempos de carrera.\u003c\/p\u003e  \u003chr class=\"ProductDescription\"\u003e  \u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e  \u003ctbody\u003e  \u003ctr\u003e  \u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e  \u003cimg alt=\"Visit Aim Academy\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\"\u003e  \u003c\/a\u003e\u003c\/td\u003e  \u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e  \u003cimg alt=\"Visit Aim Tech Support\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\"\u003e  \u003c\/a\u003e\u003c\/td\u003e  \u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e  \u003cimg alt=\"Download Race Studio Software\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\"\u003e  \u003c\/a\u003e\u003c\/td\u003e  \u003c\/tr\u003e  \u003c\/tbody\u003e  \u003c\/table\u003e  \u003ch5\u003eTécnico\u003c\/h5\u003e  \u003ch3\u003e\u003ctc\u003eAim\u003c\/tc\u003e Solo 2 DL Cronómetro de vueltas GPS + ECU Registrador de datos para carreras todoterreno\u003c\/h3\u003e  \u003cul class=\"AimProductDescriptionList\"\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eMostrar:\u003c\/strong\u003e Gráfico\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eResolución de pantalla:\u003c\/strong\u003e 238 x 99 píxeles\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eMostrar páginas:\u003c\/strong\u003e Hasta 8 configurables libremente\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eIluminar desde el fondo:\u003c\/strong\u003e 8 colores RGB configurables\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eLuces de cambio\/LEDs de alarma:\u003c\/strong\u003e 10 LED RGB configurables\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eBase de datos de pistas integrada:\u003c\/strong\u003e Sí\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003ePlataforma inercial:\u003c\/strong\u003e Acelerómetro interno de 3 ejes +5G + giroscopio de 3 ejes \u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eConexión Wi-Fi:\u003c\/strong\u003e Sí\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eGPS:\u003c\/strong\u003e 25 Hz\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eConexión de la ECU:\u003c\/strong\u003e CAN, RS232 o K-Line para miles de ECU líderes en la industria.\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eAlimentación externa:\u003c\/strong\u003e 12 V\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cb\u003eConectores: \u003c\/b\u003e1 conector (enrollador) 712, 5 pines, 1 conector (enrollador) 712, 8 pines\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eMemoria:\u003c\/strong\u003e 4 GB\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eTipo de batería:\u003c\/strong\u003e Litio recargable\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eBotones pulsadores:\u003c\/strong\u003e Metálico\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eDimensiones:\u003c\/strong\u003e 98,0 x 73,7 x 30.2 mm\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003ePeso:\u003c\/strong\u003e 240 g, batería incluida\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eImpermeable:\u003c\/strong\u003e IP67\u003c\/li\u003e  \u003c\/ul\u003e  \u003cp\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Solo_2_DL_Lap_Timer_GPS_ECU_Racing_Dash_Logger_Technical_sheet.png?v=1614778468\"\u003e\u003c\/p\u003e  \u003cp\u003e\u003cimg alt=\"Solo 2 DL Pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/solo2dl_pinout_1024x1024.png?v=1706607038\"\u003e\u003c\/p\u003e  \u003ch2\u003eDiagrama de pines de TM Racing\u003c\/h2\u003e  \u003cp\u003e\u003cimg alt=\"TM Racing Pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/TM_Racing_Pinout.webp?v=1754295408\"\u003e\u003c\/p\u003e  \u003ch2\u003eOBTENER GP1 \u0026amp; Diagrama de pines de alimentación\u003c\/h2\u003e  \u003cp\u003e\u003cimg alt=\"TM Racing Pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/GET_GP1_GET_Power.webp?v=1754295407\"\u003e\u003c\/p\u003e  \u003ch2\u003eDiagrama de pines de Suzuki\u003c\/h2\u003e  \u003cp\u003e\u003cimg alt=\"Suzuki pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Suzuki_pinout.webp?v=1754295407\"\u003e\u003c\/p\u003e  \u003ch2\u003eDiagrama de pines del Microtec M222\u003c\/h2\u003e  \u003cp\u003e\u003cimg alt=\"Microtec M222 pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/microtec_M222_pinout.webp?v=1754295407\"\u003e\u003c\/p\u003e  \u003ch2\u003eDiagrama de pines del Microtec M206\u003c\/h2\u003e  \u003cp\u003e\u003cimg alt=\"Microtec M206 pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/microtec_M206_pinout.webp?v=1754295407\"\u003e\u003c\/p\u003e  \u003ch2\u003eDiagrama de pines de Honda\u003c\/h2\u003e  \u003cp\u003e\u003cimg alt=\"Honda pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/honda_pinout.webp?v=1754295407\"\u003e\u003c\/p\u003e  \u003ch5\u003e¿Qué hay en la caja?\u003c\/h5\u003e  \u003ch3\u003e\u003ctc\u003eAim\u003c\/tc\u003e Solo 2 DL Cronómetro de vueltas GPS + ECU Registrador de datos para carreras todoterreno\u003c\/h3\u003e  \u003cul class=\"AimProductDescriptionList\"\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eSolo 2 DL\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eCable de alimentación con adaptador de CA\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eSoporte de montaje con tornillos\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eManual de usuario \u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e\u003ctc\u003eAim\u003c\/tc\u003e Etiqueta engomada\u003c\/li\u003e  \u003cli\u003e\u003cstrong\u003e\u003cspan data-preserver-spaces=\"true\"\u003ePuede elegir el cable de alimentación que prefiera al finalizar la compra. Solo se suministra uno.\u003c\/span\u003e\u003c\/strong\u003e\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eCable de alimentación externa CAN\/K-Line con conector OBDII\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eCable de alimentación externo CAN\/RS232\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eCable de alimentación externo para el tacómetro (si su vehículo no tiene ECU) \u003c\/li\u003e  \u003c\/ul\u003e  \u003cp\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/SOLO_2DL_Whats_in_the_box.png?v=1617802603\"\u003e\u003c\/p\u003e  \u003ch5\u003eDescargas\u003c\/h5\u003e  \u003cp\u003e\u003cbr\u003e\u003c\/p\u003e  \u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e  \u003ctbody\u003e  \u003ctr\u003e  \u003ctd style=\"text-align: center;\"\u003e  \u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/solo2-solo2-dl\/Solo2DL_user_guide.pdf\"\u003e  \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"Solo 2 DL User Guide\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/User_Guide_AiM_iCON_2289456f-97fa-4d13-84ea-3ede554821e9_100x100.png?v=1590766826\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e  \u003c\/td\u003e  \u003ctd style=\"text-align: center;\"\u003e  \u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/solo2-solo2-dl\/aim_solo2-solo2dl.pdf\"\u003e  \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"Solo 2 DL Tech Sheet\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e  \u003c\/td\u003e  \u003ctd style=\"text-align: center;\"\u003e  \u003ca title=\"Aim Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimshop.com\/pages\/software-downloads\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"Aim Technologies Race Studio 3 Software Download\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e  \u003c\/td\u003e  \u003c\/tr\u003e  \u003ctr\u003e  \u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/solo2-solo2-dl\/Solo2DL_user_guide.pdf\" target=\"_blank\"\u003eGuía del usuario\u003c\/a\u003e\u003c\/td\u003e  \u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/solo2-solo2-dl\/aim_solo2-solo2dl.pdf\" target=\"_blank\"\u003eFicha técnica\u003c\/a\u003e\u003c\/td\u003e  \u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"Aim Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimshop.com\/pages\/software-downloads\" target=\"_blank\"\u003eEstudio de carreras 3\u003c\/a\u003e\u003c\/td\u003e  \u003c\/tr\u003e  \u003c\/tbody\u003e  \u003c\/table\u003e","brand":"AiM Motocross","offers":[{"title":"Default Title","offer_id":31894194192486,"sku":"SOLO2","price":640.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_solo2dl_00_877ee8bd-7ce9-4160-b647-c0810ff8a00a.webp?v=1755770063","url":"https:\/\/www.aimshop.com\/es\/products\/kit-cronometro-de-vueltas-dia-de-pista-de-motocross-aim-solo-2-dl","provider":"AimShop.com","version":"1.0","type":"link"}
