{"product_id":"aim-sw4-gt320-gt350-formula-steering-wheel","title":"\u003ctc\u003eAim\u003c\/tc\u003e SW4 Volante de Fórmula GT320\/GT350","description":"\u003cdiv id=\"shopify-section-template--17952294928486__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eVolante con registro de datos\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eEl \u003ctc\u003eAim\u003c\/tc\u003e El volante Formula Steering Wheel 4 GT320\/GT350 es nuestro volante más avanzado hasta la fecha. Incorpora un registrador de datos interno con configuración completa, empuñaduras extraíbles, interruptores giratorios y una amplia gama de opciones de conectividad CAN y ECU totalmente compatibles.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17952294928486__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003e¿Por qué elegir el volante GT320\/350?\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eEl \u003ctc\u003eAim\u003c\/tc\u003e El volante Formula Steering Wheel GT320\/GT350 se utiliza en coches GT y de cabina cerrada, donde el espacio es limitado. El registrador de datos interno es totalmente configurable y apto para diversas disciplinas del automovilismo. Ha sido diseñado para adquirir y mostrar datos procedentes de la ECU, con más de 1000 protocolos de ECU totalmente compatibles.\u003c\/p\u003e  \u003cp\u003eNuestras ruedas Formula vienen en una variedad de tamaños (\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-sw4-270-280-formula-steering-wheel\" title=\"Aim SW4 270\/280 Formula Steering Wheel\"\u003e270\u003c\/a\u003e,\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-sw4-270-280-formula-steering-wheel\" title=\"Aim SW4 270\/280 Formula Steering Wheel\"\u003e280\u003c\/a\u003e,  GT320 \u0026amp; GT350). La diferencia entre el volante Formula 4 GT320 y el GT350 radica en el tamaño general del volante; el volante Formula GT350 es 30 mm más grande para satisfacer las necesidades de cada conductor.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17952294928486__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eConexión sencilla\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eConectando el \u003ctc\u003eAim\u003c\/tc\u003e Conectar el volante Formula GT320\/GT350 a la ECU es muy sencillo. Puedes muestrear docenas de canales directamente desde la ECU del vehículo. Esta suele ser la configuración más rápida y fácil, ya que solo requiere una conexión por cable a la ECU en lugar de múltiples conexiones y sensores analógicos.\u003c\/p\u003e  \u003cp\u003eLos datos muestreados dependerán de su ECU específica, pero generalmente incluyen RPM, carga del motor, posición del acelerador (TPS), temperatura del aceite, del aire y del agua, presión del aceite, voltaje de la batería, velocidad, marcha y valor lambda (relación aire\/combustible). La lista de controladores de ECU disponibles se actualiza constantemente e incluye más de 1000 ECU diferentes.\u003c\/p\u003e  \u003cp\u003eCon la salida CAN, también puede enviar mensajes directamente a una red CAN existente para ampliar el abanico de posibilidades de control del vehículo.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17952294928486__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eMostrar \u0026amp; Botones pulsadores\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eEl volante Formula Steering Wheel 4 GT320\/GT350 tiene un alto contraste. 5\" Pantalla TFT totalmente configurable y resistente a los reflejos de la luz solar. Gracias al sensor de luz ambiental, la pantalla es fácil de leer tanto de día como de noche.\u003c\/p\u003e  \u003cp\u003eEl volante Formula 4 GT320\/GT350 cuenta con 10 botones pulsadores y 3 interruptores giratorios, todos ellos retroiluminados con LED RGB para una mayor facilidad de uso.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17952294928486__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eAlarmas flexibles\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eEl \u003ctc\u003eAim\u003c\/tc\u003e SW4 El volante GT320\/GT350 Formula cuenta con 8 LED RGB configurables para la luz de cambio de marchas y 4 LED RGB configurables para la alarma. Puedes elegir las condiciones y los colores: selecciona una alarma fija o intermitente, y la frecuencia de parpadeo. También puedes añadir un mensaje de texto y establecer las prioridades de la alarma.\u003c\/p\u003e  \u003cp\u003eGracias a las luces de cambio integradas, puedes elegir entre una gran variedad de patrones de luces RGB multicolores avanzados que puedes personalizar para adaptarlos a tus necesidades y a cada marcha cuando sea necesario.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17952294928486__rich_text_9enpXA\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eExtras opcionales\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eExiste una amplia selección de accesorios disponibles para sacar el máximo partido a tu volante:\u003c\/p\u003e  \u003cul\u003e  \u003cli\u003e  \u003cstrong\u003ePalancas de embrague\u003c\/strong\u003e:  Añade levas de embrague izquierda y\/o derecha directamente desde las opciones que aparecen en la parte superior de la página para adaptarlas a tu estilo de conducción.\u003c\/li\u003e  \u003cli\u003e  \u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-gps09-gps-module\" title=\"Aim GPS09 Module\"\u003e\u003cstrong\u003eMódulo GPS\u003c\/strong\u003e\u003c\/a\u003e:  Conectado mediante CAN, el módulo GPS facilita el cálculo del tiempo por vuelta y el análisis de la posición en pista.\u003c\/li\u003e  \u003cli\u003e  \u003ca href=\"https:\/\/www.aimshop.com\/pages\/car-hd-cameras\" title=\"Car Camera Systems\"\u003e\u003cstrong\u003eCámara inteligente\u003c\/strong\u003e\u003c\/a\u003e:  Una cámara integrada en el vehículo de competición que graba vídeo y superpone datos de rendimiento cruciales para proporcionar información al piloto en tiempo real y realizar análisis posteriores a la sesión.\u003c\/li\u003e  \u003c\/ul\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cp\u003eNúmero de pieza de 320 mm: X07SW43200\u003c\/p\u003e  \u003cp\u003eNúmero de pieza de 350 mm: X07SW43500\u003c\/p\u003e","brand":"AiM Car","offers":[{"title":"Default Title","offer_id":42990841430118,"sku":"FSW4","price":2745.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_sw4320-350_01_1.5x.webp?v=1761050314","url":"https:\/\/www.aimshop.com\/es\/products\/objetivosw4volante-de-direccion-de-la-formula-gt320-gt350","provider":"AimShop.com","version":"1.0","type":"link"}
