{"product_id":"second-life-ex-demo-aim-mxs-1-3-strada-light-5-tft-car-dash-display-with-race-icons","title":"Demo anterior de Second Life \u003ctc\u003eAim\u003c\/tc\u003e MXS 1.3 Strada Light 5\" Pantalla TFT para salpicadero de coche con iconos de carreras","description":"\u003cdiv id=\"shopify-section-template--17924219994214__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eCompact Motorsport Display\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe MXS Strada with race icons is one of the most widely used dash displays on tracks around the world. The Strada ‘Light’ version has been created as a more accessible product for people who will use fewer analogue inputs and just need a CAN connection for their ECU.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17924219994214__image_with_text_BQwqAd\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"image-with-text lg:flex  lg:flex-row overflow-hidden\"\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 relative\"\u003e\n\u003cdiv class=\"image-with-text__media h-full\"\u003e\u003cpicture class=\"media block w-full relative overflow-hidden\n                  media--adapt\n                  mobile:media--auto\"\u003e\u003cimg src=\"https:\/\/www.aimshop.com\/cdn\/shop\/files\/mini_magick20260210-44082-8eey3c.jpg?v=1770713850\u0026amp;width=1080\" alt='The MXS Strada Light 5\" Display integrated into a car dashboard on a racetrack' srcset=\"\/\/www.aimshop.com\/cdn\/shop\/files\/mini_magick20260210-44082-8eey3c.jpg?v=1770713850\u0026amp;width=300 300w, \/\/www.aimshop.com\/cdn\/shop\/files\/mini_magick20260210-44082-8eey3c.jpg?v=1770713850\u0026amp;width=400 400w, \/\/www.aimshop.com\/cdn\/shop\/files\/mini_magick20260210-44082-8eey3c.jpg?v=1770713850\u0026amp;width=500 500w, \/\/www.aimshop.com\/cdn\/shop\/files\/mini_magick20260210-44082-8eey3c.jpg?v=1770713850\u0026amp;width=600 600w, \/\/www.aimshop.com\/cdn\/shop\/files\/mini_magick20260210-44082-8eey3c.jpg?v=1770713850\u0026amp;width=700 700w, \/\/www.aimshop.com\/cdn\/shop\/files\/mini_magick20260210-44082-8eey3c.jpg?v=1770713850\u0026amp;width=800 800w, \/\/www.aimshop.com\/cdn\/shop\/files\/mini_magick20260210-44082-8eey3c.jpg?v=1770713850\u0026amp;width=900 900w, \/\/www.aimshop.com\/cdn\/shop\/files\/mini_magick20260210-44082-8eey3c.jpg?v=1770713850\u0026amp;width=1000 1000w\" width=\"1080\" height=\"1350\" loading=\"lazy\" sizes=\"(max-width: 767px) 100vw, 50vw\" is=\"\"\u003e\u003c\/picture\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 align-self-center\"\u003e\n\u003cdiv class=\"rich-text lg:text-left text-center relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-sm\"\u003e\u003cstrong\u003eWhy Choose the MXS 1.3 Strada Light Display\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte body subtext-md leading-normal\"\u003e\n\u003cp\u003eWhilst being very similar to the MXS Strada, the MXS Strada Light gives 4 fully configurable analogue inputs (max of 500Hz each) instead of the 8 that are found on the standard MXS Strada. It also doesn’t have a digital output or an RPM connection, which is found within the standard MXS Strada.\u003c\/p\u003e\n\u003cp\u003eChoose either the OBDII or K-Line CAN, depending on whether you want to connect to the vehicle's ECU or OBDII port or directly to the ECU through the CAN channel.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17924219994214__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEasy Connection\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eConnecting the MXS 1.3 Strada Light dash to your ECU is simple. You can sample and display dozens of channels straight from the vehicle's ECU. This is usually the quickest and easiest setup, needing only 2 wire connections to the ECU instead of multiple connections to analogue sensors.\u003c\/p\u003e\n\u003cp\u003eWith the CAN output, you can send messages directly to an existing CAN network to improve the range of vehicle control possibilities. Two analogue camera inputs are also available to switch your display into a\u003cspan\u003e \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-mirror-reversing-camera-for-mx-series-pdm\" title=\"Aim Mirror \u0026amp; Reversing Camera for MX Series \u0026amp; PDM\"\u003emirror camera\u003c\/a\u003e, through a push button command or event management. The camera is sold separately.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17924219994214__video_with_text_PF7Bgk\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"image-with-text lg:flex lg:gap-8 lg:flex-row-reverse overflow-hidden\"\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 relative\"\u003e\n\u003cdiv class=\"image-with-text__media h-full\"\u003e\n\u003cdiv class=\"media media--height block w-full h-full relative overflow-hidden\"\u003e\n\u003cimg src=\"https:\/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=3840\" alt=\"Load video: The MX Strada Light data and RPM on-screen as car revs.\" srcset=\"\/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=300 300w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=400 400w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=500 500w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=600 600w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=700 700w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=800 800w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=900 900w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=1000 1000w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=1200 1200w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=1400 1400w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=1600 1600w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=1800 1800w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=2000 2000w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=2200 2200w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=2400 2400w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=2600 2600w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=2800 2800w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=3000 3000w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000.jpg?v=1770713925\u0026amp;width=3200 3200w\" width=\"3840\" height=\"2160\" loading=\"lazy\" sizes=\"(max-width: 767px) 100vw, 50vw\" is=\"\" class=\"loaded\"\u003e\u003cvideo playsinline=\"true\" autoplay=\"autoplay\" loop=\"loop\" preload=\"metadata\" muted=\"muted\" poster=\"https:\/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/a41130f8907544d8ae1b8098dc744141.thumbnail.0000000000_800x.jpg?v=1770713925\"\u003e\u003c\/video\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 align-self-center\"\u003e\n\u003cdiv class=\"rich-text lg:text-left text-center relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-sm\"\u003e\u003cstrong\u003eSample \u0026amp; Display Your Data\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte body subtext-md leading-normal\"\u003e\n\u003cp\u003eSampled data depends on the actual ECU, but will typically include RPM, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air\/fuel ratio). The list of available ECU drivers is over 1,000 and is constantly being updated and upgraded.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17924219994214__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDisplay with Race Icons\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe MXS 1.3 Strada Light has a compact 5\" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels while on the track. Race icons allow you to apply conditions to the LED icons.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17924219994214__video_with_text_UCzbXc\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"image-with-text lg:flex lg:gap-8 lg:flex-row overflow-hidden\"\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 lg:grow-0 relative\"\u003e\n\u003cdiv class=\"image-with-text__media h-full\"\u003e\n\u003cdiv class=\"media media--height block w-full h-full relative overflow-hidden\"\u003e\n\u003cimg src=\"https:\/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/6f01b010d0eb467c9f38c7522896fc40.thumbnail.0000000000.jpg?v=1770721601\u0026amp;width=1736\" alt=\"Load video: Delta times LED display feedback on the MXS 5 inch Strada Light Display\" srcset=\"\/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/6f01b010d0eb467c9f38c7522896fc40.thumbnail.0000000000.jpg?v=1770721601\u0026amp;width=300 300w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/6f01b010d0eb467c9f38c7522896fc40.thumbnail.0000000000.jpg?v=1770721601\u0026amp;width=400 400w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/6f01b010d0eb467c9f38c7522896fc40.thumbnail.0000000000.jpg?v=1770721601\u0026amp;width=500 500w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/6f01b010d0eb467c9f38c7522896fc40.thumbnail.0000000000.jpg?v=1770721601\u0026amp;width=600 600w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/6f01b010d0eb467c9f38c7522896fc40.thumbnail.0000000000.jpg?v=1770721601\u0026amp;width=700 700w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/6f01b010d0eb467c9f38c7522896fc40.thumbnail.0000000000.jpg?v=1770721601\u0026amp;width=800 800w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/6f01b010d0eb467c9f38c7522896fc40.thumbnail.0000000000.jpg?v=1770721601\u0026amp;width=900 900w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/6f01b010d0eb467c9f38c7522896fc40.thumbnail.0000000000.jpg?v=1770721601\u0026amp;width=1000 1000w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/6f01b010d0eb467c9f38c7522896fc40.thumbnail.0000000000.jpg?v=1770721601\u0026amp;width=1200 1200w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/6f01b010d0eb467c9f38c7522896fc40.thumbnail.0000000000.jpg?v=1770721601\u0026amp;width=1400 1400w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/6f01b010d0eb467c9f38c7522896fc40.thumbnail.0000000000.jpg?v=1770721601\u0026amp;width=1600 1600w\" width=\"1736\" height=\"688\" loading=\"lazy\" sizes=\"(max-width: 767px) 100vw, 50vw\" is=\"\" class=\"loaded\"\u003e\u003cvideo playsinline=\"true\" autoplay=\"autoplay\" loop=\"loop\" preload=\"metadata\" muted=\"muted\" poster=\"https:\/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/6f01b010d0eb467c9f38c7522896fc40.thumbnail.0000000000_800x.jpg?v=1770721601\"\u003e\u003c\/video\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 align-self-center\"\u003e\n\u003cdiv class=\"rich-text lg:text-left text-center relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-sm\"\u003e\u003cstrong\u003eDelta Times\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe Delta Times feature provides instant feedback on your performance, showing how your current timing compares to your best.\u003c\/p\u003e\n\u003cp\u003eSet a reference lap and visualise where you are gaining and losing time. The integrated lights will display green or red accordingly.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17924219994214__video_with_text_7hQhLT\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"image-with-text lg:flex lg:gap-8 lg:flex-row-reverse overflow-hidden\"\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 lg:grow-0 relative\"\u003e\n\u003cdiv class=\"image-with-text__media h-full\"\u003e\n\u003cdiv class=\"media media--height block w-full h-full relative overflow-hidden\"\u003e\n\u003cimg src=\"https:\/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/fc463e1c667a49589972b7b91ae33183.thumbnail.0000000000.jpg?v=1770721609\u0026amp;width=1740\" alt=\"Load video: Integrated shift light array interface and customisable alarms for the MX Strada Light Series\" srcset=\"\/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/fc463e1c667a49589972b7b91ae33183.thumbnail.0000000000.jpg?v=1770721609\u0026amp;width=300 300w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/fc463e1c667a49589972b7b91ae33183.thumbnail.0000000000.jpg?v=1770721609\u0026amp;width=400 400w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/fc463e1c667a49589972b7b91ae33183.thumbnail.0000000000.jpg?v=1770721609\u0026amp;width=500 500w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/fc463e1c667a49589972b7b91ae33183.thumbnail.0000000000.jpg?v=1770721609\u0026amp;width=600 600w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/fc463e1c667a49589972b7b91ae33183.thumbnail.0000000000.jpg?v=1770721609\u0026amp;width=700 700w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/fc463e1c667a49589972b7b91ae33183.thumbnail.0000000000.jpg?v=1770721609\u0026amp;width=800 800w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/fc463e1c667a49589972b7b91ae33183.thumbnail.0000000000.jpg?v=1770721609\u0026amp;width=900 900w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/fc463e1c667a49589972b7b91ae33183.thumbnail.0000000000.jpg?v=1770721609\u0026amp;width=1000 1000w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/fc463e1c667a49589972b7b91ae33183.thumbnail.0000000000.jpg?v=1770721609\u0026amp;width=1200 1200w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/fc463e1c667a49589972b7b91ae33183.thumbnail.0000000000.jpg?v=1770721609\u0026amp;width=1400 1400w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/fc463e1c667a49589972b7b91ae33183.thumbnail.0000000000.jpg?v=1770721609\u0026amp;width=1600 1600w\" width=\"1740\" height=\"1280\" loading=\"lazy\" sizes=\"(max-width: 767px) 100vw, 50vw\" is=\"\" class=\"loaded\"\u003e\u003cvideo playsinline=\"true\" autoplay=\"autoplay\" loop=\"loop\" preload=\"metadata\" muted=\"muted\" poster=\"https:\/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/fc463e1c667a49589972b7b91ae33183.thumbnail.0000000000_800x.jpg?v=1770721609\"\u003e\u003c\/video\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 align-self-center\"\u003e\n\u003cdiv class=\"rich-text lg:text-left text-center relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-sm\"\u003e\u003cstrong\u003eIntegrated Shift Lights \u0026amp; Customisable Alarms\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe 10 multi-coloured RGB shift lights can be customised to your liking, defining the RPM threshold on analogue or digital inputs, ECU values, expansion values, math channels or optional GPS option. You can choose the conditions and colours, select a solid arm or a flashing one and the flashing frequency. You can also configure an accompanying text message and set the alarm priorities.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17924219994214__video_with_text_Nz3zQh\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"image-with-text lg:flex lg:gap-8 lg:flex-row overflow-hidden\"\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 relative\"\u003e\n\u003cdiv class=\"image-with-text__media h-full\"\u003e\n\u003cdiv class=\"media media--height block w-full h-full relative overflow-hidden\"\u003e\n\u003cimg src=\"https:\/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/428186dfdaad48fc9a1d62ec44c03d09.thumbnail.0000000000.jpg?v=1770641540\u0026amp;width=1666\" alt=\"Load video: Pre-configured dash display screens for the MX Strada Light Series.\" srcset=\"\/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/428186dfdaad48fc9a1d62ec44c03d09.thumbnail.0000000000.jpg?v=1770641540\u0026amp;width=300 300w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/428186dfdaad48fc9a1d62ec44c03d09.thumbnail.0000000000.jpg?v=1770641540\u0026amp;width=400 400w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/428186dfdaad48fc9a1d62ec44c03d09.thumbnail.0000000000.jpg?v=1770641540\u0026amp;width=500 500w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/428186dfdaad48fc9a1d62ec44c03d09.thumbnail.0000000000.jpg?v=1770641540\u0026amp;width=600 600w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/428186dfdaad48fc9a1d62ec44c03d09.thumbnail.0000000000.jpg?v=1770641540\u0026amp;width=700 700w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/428186dfdaad48fc9a1d62ec44c03d09.thumbnail.0000000000.jpg?v=1770641540\u0026amp;width=800 800w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/428186dfdaad48fc9a1d62ec44c03d09.thumbnail.0000000000.jpg?v=1770641540\u0026amp;width=900 900w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/428186dfdaad48fc9a1d62ec44c03d09.thumbnail.0000000000.jpg?v=1770641540\u0026amp;width=1000 1000w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/428186dfdaad48fc9a1d62ec44c03d09.thumbnail.0000000000.jpg?v=1770641540\u0026amp;width=1200 1200w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/428186dfdaad48fc9a1d62ec44c03d09.thumbnail.0000000000.jpg?v=1770641540\u0026amp;width=1400 1400w, \/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/428186dfdaad48fc9a1d62ec44c03d09.thumbnail.0000000000.jpg?v=1770641540\u0026amp;width=1600 1600w\" width=\"1666\" height=\"1000\" loading=\"lazy\" sizes=\"(max-width: 767px) 100vw, 50vw\" is=\"\" class=\"loaded\"\u003e\u003cvideo playsinline=\"true\" autoplay=\"autoplay\" loop=\"loop\" preload=\"metadata\" muted=\"muted\" poster=\"https:\/\/www.aimshop.com\/cdn\/shop\/files\/preview_images\/428186dfdaad48fc9a1d62ec44c03d09.thumbnail.0000000000_800x.jpg?v=1770641540\"\u003e\u003c\/video\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 align-self-center\"\u003e\n\u003cdiv class=\"rich-text lg:text-left text-center relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-sm\"\u003e\u003cstrong\u003ePre-Configured Pages\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe MXS 1.3 Strada Light shows the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can customise pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy; just use the push buttons.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17924219994214__image_with_text_QeEqdW\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"image-with-text lg:flex  lg:flex-row-reverse overflow-hidden\"\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 relative\"\u003e\n\u003cdiv class=\"image-with-text__media h-full\"\u003e\u003cpicture class=\"media block w-full relative overflow-hidden media--adapt mobile:media--auto\"\u003e\u003cimg src=\"https:\/\/www.aimshop.com\/cdn\/shop\/files\/back_visual_12_1.png?v=1770642049\u0026amp;width=615\" alt=\"Data from Race Studio 3 showing the configurable dash displays.\" srcset=\"\/\/www.aimshop.com\/cdn\/shop\/files\/back_visual_12_1.png?v=1770642049\u0026amp;width=300 300w, \/\/www.aimshop.com\/cdn\/shop\/files\/back_visual_12_1.png?v=1770642049\u0026amp;width=400 400w, \/\/www.aimshop.com\/cdn\/shop\/files\/back_visual_12_1.png?v=1770642049\u0026amp;width=500 500w, \/\/www.aimshop.com\/cdn\/shop\/files\/back_visual_12_1.png?v=1770642049\u0026amp;width=600 600w\" width=\"615\" height=\"686\" loading=\"lazy\" sizes=\"(max-width: 767px) 100vw, 50vw\" is=\"\" class=\"loaded\"\u003e\u003c\/picture\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 align-self-center\"\u003e\n\u003cdiv class=\"rich-text lg:text-left text-left relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-sm\"\u003e\u003cstrong\u003eFree Analysis Software\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte body subtext-md leading-normal\"\u003e\n\u003cp\u003eBy connecting an MX Strada Logger to your display - giving it the power to log your data - you can download your data and, with Race Studio 3; create, modify, delete, import and export configurations of:\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\u003cstrong\u003eAll channels\u003c\/strong\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cstrong\u003eECU drivers\u003c\/strong\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cstrong\u003eMath channels\u003c\/strong\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cstrong\u003eDisplay pages\u003c\/strong\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cstrong\u003eDigital outputs\u003c\/strong\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cstrong\u003eAlarms\u003c\/strong\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cstrong\u003eShift lights\u003c\/strong\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cstrong\u003eExpansions\u003c\/strong\u003e\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17924219994214__image_with_text_UzCfCz\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"image-with-text lg:flex  lg:flex-row overflow-hidden\"\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 relative\"\u003e\n\u003cdiv class=\"image-with-text__media h-full\"\u003e\u003cpicture class=\"media block w-full relative overflow-hidden media--adapt mobile:media--auto\"\u003e\u003cimg src=\"https:\/\/www.aimshop.com\/cdn\/shop\/files\/MXS_Strada_Light_Race.png?v=1770715392\u0026amp;width=1920\" alt=\"MX Strada Light Series Expansions list; SmartyCam 3 Sport, ACC3, Data Hub, GPS and more.\" srcset=\"\/\/www.aimshop.com\/cdn\/shop\/files\/MXS_Strada_Light_Race.png?v=1770715392\u0026amp;width=300 300w, \/\/www.aimshop.com\/cdn\/shop\/files\/MXS_Strada_Light_Race.png?v=1770715392\u0026amp;width=400 400w, \/\/www.aimshop.com\/cdn\/shop\/files\/MXS_Strada_Light_Race.png?v=1770715392\u0026amp;width=500 500w, \/\/www.aimshop.com\/cdn\/shop\/files\/MXS_Strada_Light_Race.png?v=1770715392\u0026amp;width=600 600w, \/\/www.aimshop.com\/cdn\/shop\/files\/MXS_Strada_Light_Race.png?v=1770715392\u0026amp;width=700 700w, \/\/www.aimshop.com\/cdn\/shop\/files\/MXS_Strada_Light_Race.png?v=1770715392\u0026amp;width=800 800w, \/\/www.aimshop.com\/cdn\/shop\/files\/MXS_Strada_Light_Race.png?v=1770715392\u0026amp;width=900 900w, \/\/www.aimshop.com\/cdn\/shop\/files\/MXS_Strada_Light_Race.png?v=1770715392\u0026amp;width=1000 1000w, \/\/www.aimshop.com\/cdn\/shop\/files\/MXS_Strada_Light_Race.png?v=1770715392\u0026amp;width=1200 1200w, \/\/www.aimshop.com\/cdn\/shop\/files\/MXS_Strada_Light_Race.png?v=1770715392\u0026amp;width=1400 1400w, \/\/www.aimshop.com\/cdn\/shop\/files\/MXS_Strada_Light_Race.png?v=1770715392\u0026amp;width=1600 1600w\" width=\"1920\" height=\"1080\" loading=\"lazy\" sizes=\"(max-width: 767px) 100vw, 50vw\" is=\"\" class=\"loaded\"\u003e\u003c\/picture\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"image-with-text__item grow shrink-0 align-self-center\"\u003e\n\u003cdiv class=\"rich-text lg:text-left text-center relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-sm\"\u003e\u003cstrong\u003eExpand Your System\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte body subtext-md leading-normal\"\u003e\n\u003cp\u003eTurn your MX Strada Light Dash into a complete data logging system with the\u003cspan\u003e \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-mx-strada-logger\" title=\"Aim MX Strada Logger\"\u003eMX Strada Logger\u003c\/a\u003e,\u003cspan\u003e \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-four-way-data-hub-can-connection-multiplier\" title=\"Aim Four-Way Data Hub CAN Connection Multiplier\"\u003eData Hub\u003c\/a\u003e\u003cspan\u003e \u003c\/span\u003e\u0026amp;\u003cspan\u003e \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-gps09-gps-module\" title=\"Aim GPS09 Module\"\u003eGPS09 Module\u003c\/a\u003e. You can also integrate an\u003cspan\u003e \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/acc-3-analogue-can-converter\" title=\"Aim ACC3 Analogue CAN Converter\"\u003eACC3\u003c\/a\u003e\u003cspan\u003e \u003c\/span\u003eand convert your analogue to CAN, integrating a camera and various sensors into your setup.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e","brand":"Second-Life","offers":[{"title":"Default Title","offer_id":45010822856806,"sku":"SN: 1300261","price":875.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/MXSStradaRace.png?v=1773157880","url":"https:\/\/www.aimshop.com\/es\/products\/second-life-ex-demo-aim-mxs-1-3-strada-light-5-tft-car-dash-display-con-iconos-de-carrera","provider":"AimShop.com","version":"1.0","type":"link"}
