{"product_id":"aim-cylinder-head-thermocouple-cht-14mm-type-k","title":"\u003ctc\u003eAim\u003c\/tc\u003e Termopar de culata de 14 mm tipo K","description":"\u003cstyle\u003e\n    .LandingPage-CatTitle {\n        font-size: 24px;\n        text-align: center;\n      font-weight:600;\n    }\n    .LandingPage-CatSubTitle {\n        font-size: 22px;\n        text-align: center;\n      margin:0;\n      font-weight:600;\n    }\n    .TextBoxes {\n        font-size: 20px;\n        line-height: 32px;\n        text-align: center;\n    }\n  .features_container {\n  max-width: 1200px;\n      margin: 0 auto;\n padding-top: 20px !important;\n      padding-bottom: 20px !important;\n}\n\n.features_title {\n  font-size: 32px;\n  font-weight: 700;\n  text-align: center;\n  margin-bottom: 40px;\n  color: #333;\n  text-transform: uppercase;\n  letter-spacing: 1px;\n}\n\n.features_grid {\n  display: grid;\n  grid-template-columns: repeat(2, 1fr);\n  gap: 20px;\n  background-color: #f9f9f9;\n  padding: 30px;\n  border-radius: 8px;\n  box-shadow: 0 2px 10px rgba(0, 0, 0, 0.05);\n}\n\n.features_item {\n  font-size: 16px;\n  color: #555;\n  text-align: center;\n  padding: 15px;\n  background-color: #fff;\n  border: 1px solid #eee;\n  border-radius: 4px;\n  transition: transform 0.2s ease, box-shadow 0.2s ease;\n}\n    @media (max-width: 768px) {\n        .LandingPage-CatTitle {\n            font-size: 22px;\n        }\n        .LandingPage-CatSubTitle {\n            font-size: 20px;\n        }\n        .TextBoxes {\n            font-size: 18px;\n            line-height: 32px;\n        }\n    }\n\n\/* Mobile adjustments *\/\n@media (max-width: 600px) {\n  .features_grid {\n    grid-template-columns: 1fr; \/* Single column on mobile *\/\n    padding: 20px;\n  }\n\n  .features_title {\n    font-size: 24px;\n    margin-bottom: 30px;\n  }\n\n  .features_item {\n    font-size: 14px;\n    padding: 12px;\n  }\n}\n    \u003c\/style\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003eSensor de temperatura de termopar tipo K de alta calidad para deportes de motor\u003c\/h2\u003e  \u003cp class=\"TextBoxes\"\u003eEl \u003ctc\u003eAim\u003c\/tc\u003e El sensor termopar de culata (CHT) para deportes de motor permite medir la temperatura de la culata cuando el sensor se coloca entre la bujía y la culata.\u003c\/p\u003e  \u003cdiv class=\"features_container\"\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003eCaracterísticas principales del sensor CHT\u003c\/h2\u003e  \u003cdiv class=\"features_grid\"\u003e  \u003cdiv class=\"features_item\"\u003eMedir la temperatura de la culata\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eConector macho para termopar\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eAmplio rango de temperatura\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eConector de 2 pines, tipo K\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eRango de temperatura: 0-300 °C\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eLongitud del cable del sensor: 400 mm\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eDiseñado para entornos de automovilismo\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eCalidad profesional para lecturas precisas.\u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c!-- DIVISOR --\u003e\u003chr class=\"ProductDescription\"\u003e  \u003cstyle\u003e\n  .custom_thermocouple_img {\n    max-width: 100%;\n    width: 100%;\n    height: auto;\n  }\n  @media (min-width: 768px) {\n    .custom_thermocouple_img {\n      max-width: 1140px;\n      margin: 0 auto;\n      display: block;\n    }\n  }\n\u003c\/style\u003e  \u003cdiv\u003e\u003cimg class=\"custom_thermocouple_img\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Cylinder_Head_Thermocouple_14mm_K_Type_Motorcycle_Main_Image.png?v=1624873228\" style=\"width: 100%;\"\u003e\u003c\/div\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003eConexiones\u003c\/h2\u003e  \u003cp class=\"TextBoxes\"\u003ePara utilizar los sensores con los registradores de datos EVO4 y EVO4S, necesitará un cable de conexión TC amarillo 712 de 4 pines (conector metálico). Para utilizarlos con un \u003ctc\u003eAim\u003c\/tc\u003e Para el concentrador TC, necesitará un cable de conexión TC amarillo 712 de 3 pines (conector metálico).\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003eLos modelos MXS, MXG, MXP y EVO5 requerirán un cable de conexión amarillo TC - TC. Para conectar los termopares a estos \u003ctc\u003eAim\u003c\/tc\u003e Para los registradores de datos\/paneles de control, debe utilizar el arnés específico que se suministra con su dispositivo.\u003c\/p\u003e  \u003chr class=\"ProductDescription\"\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003eInstalación\u003c\/h2\u003e  \u003cp class=\"TextBoxes\"\u003eEl \u003ctc\u003eAim\u003c\/tc\u003e El termopar de 14 mm para la culata presenta una curva en su parte inferior para facilitar su instalación\/desinstalación; debe encajar entre la bujía y la culata.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003ePara mantener el sensor en contacto con la culata, retire la arandela del tapón al instalar el termopar.\u003c\/p\u003e  \u003cp\u003eAl tender el cable del termopar junto al chasis, manténgalo lo más alejado posible de otros cables (como los del tacómetro o el receptor de vueltas) para minimizar las interferencias.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003e\u003cstrong\u003eTenga en cuenta:\u003c\/strong\u003e Antes de volver a enroscar el cable de la bujía, asegúrese de que el sensor esté firmemente sujeto a la culata. Al enroscarlo, minimice los movimientos del termopar para evitar dañar el sensor.\u003c\/p\u003e  \u003chr\u003e  \u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e  \u003ctbody\u003e  \u003ctr\u003e  \u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\" alt=\"Visit Aim Academy\"\u003e  \u003c\/a\u003e\u003c\/td\u003e  \u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\" alt=\"Visit Aim Tech Support\"\u003e  \u003c\/a\u003e\u003c\/td\u003e  \u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e  \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\" alt=\"Download Race Studio Software\"\u003e  \u003c\/a\u003e\u003c\/td\u003e  \u003c\/tr\u003e  \u003c\/tbody\u003e  \u003c\/table\u003e  \u003ch5\u003eTécnico \u003c\/h5\u003e  \u003ch3\u003e\u003ctc\u003eAim\u003c\/tc\u003e Termopar de culata de 14 mm tipo K\u003c\/h3\u003e  \u003cul class=\"AimProductDescriptionList\"\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eRango de temperatura de funcionamiento: 0-300 °C\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eLongitud del sensor de cable: 400 mm\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eTipo de cable: Compensado\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eConexión de termopar macho de dos pines\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eTermopar tipo K\u003c\/li\u003e  \u003c\/ul\u003e  \u003cp\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Cylinder_Head_Thermocouple_14mm_K_Type_Motorcycle_1.png?v=1624872525\"\u003e\u003c\/p\u003e  \u003ch5\u003e¿Qué hay en la caja?\u003c\/h5\u003e  \u003ch3\u003e\u003ctc\u003eAim\u003c\/tc\u003e Termopar de culata de 14 mm tipo K\u003c\/h3\u003e  \u003cul class=\"AimProductDescriptionList\"\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e\u003ctc\u003eAim\u003c\/tc\u003e Sensor de temperatura de termopar de 14 mm para la culata\u003c\/li\u003e  \u003c\/ul\u003e  \u003ch5\u003eDescargas\u003c\/h5\u003e  \u003cp\u003e\u003cbr\u003e\u003c\/p\u003e  \u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e  \u003ctbody\u003e  \u003ctr\u003e  \u003ctd style=\"text-align: center;\"\u003e  \u003ca rel=\"noopener\" title=\"Aim Cylinder Head Thermocouple Data Sheet\" href=\"https:\/\/support.aimshop.com\/downloads\/sensors\/Datasheet_TCCHT_104_eng.pdf\" target=\"_blank\"\u003e  \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e  \u003c\/td\u003e  \u003ctd style=\"text-align: center;\"\u003e  \u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e  \u003c\/td\u003e  \u003c\/tr\u003e  \u003ctr\u003e  \u003ctd style=\"text-align: center;\"\u003e\u003ca rel=\"noopener\" href=\"https:\/\/support.aimshop.com\/downloads\/sensors\/Datasheet_TCCHT_104_eng.pdf\" title=\"AiM Cylinder Head Thermocouple Data Sheet\" target=\"_blank\"\u003eFicha técnica\u003c\/a\u003e\u003c\/td\u003e  \u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003eEstudio de carreras 3\u003c\/a\u003e\u003c\/td\u003e  \u003c\/tr\u003e  \u003c\/tbody\u003e  \u003c\/table\u003e","brand":"Aim Sensors","offers":[{"title":"Default Title","offer_id":29240263082086,"sku":"S-T-CH-X05SOT14A4516MS","price":70.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_underSparkPlugTemperatureSensor_04_1.5x.webp?v=1762254711","url":"https:\/\/www.aimshop.com\/es\/products\/termopar-de-culata-de-apunta-cht-14mm-tipo-k","provider":"AimShop.com","version":"1.0","type":"link"}
