{"product_id":"yamaha-aim-taipan-y-v2-motocross-ecu-plug-play","title":"Yamaha \u003ctc\u003eAim\u003c\/tc\u003e Conector de la ECU de motocross Taipan Y V2 \u0026  Jugar","description":"\u003cdiv id=\"shopify-section-template--18082605957222__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003e\u003ctc\u003eAim\u003c\/tc\u003e ECU Taipan Y V2\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eLa ECU Taipan Y V2 es un enchufe de posventa. \u0026amp; unidad de control del motor de juego creada por \u003ctc\u003eAim\u003c\/tc\u003e, diseñado exclusivamente para enchufe \u0026amp; instalación de juego con\u003cspan\u003e  \u003c\/span\u003e\u003cstrong\u003eYamaha YZ250F\u003cspan\u003e  \u003c\/span\u003e\u003c\/strong\u003ey\u003cspan\u003e  \u003c\/span\u003e\u003cstrong\u003eYZ450F\u003c\/strong\u003e\u003cspan\u003e  \u003c\/span\u003eMotos de motocross (2024-2025).\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18082605957222__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e  \u003cstrong\u003e¿Por qué elegir la ECU Taipan Y V2?\u003c\/strong\u003e  \u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eGracias a su núcleo de 32 bits de alta tecnología, la ECU Taipan Y V2 representa un importante paso adelante para mejorar el rendimiento de tu moto de motocross, sin sacrificar la fiabilidad ni la suavidad.\u003c\/p\u003e  \u003cp\u003eEl control del motor requiere precisión. A 20.000 RPM, la ECU Taipan Y V2 garantiza una precisión de 1\/10 de grado: esto significa una exactitud de 0,8 microsegundos (µs) para encender la chispa.\u003c\/p\u003e  \u003cp\u003eEsta precisión es la clave para garantizar:\u003c\/p\u003e  \u003cul\u003e  \u003cli\u003eUna rotación del motor muy constante.\u003c\/li\u003e  \u003cli\u003eLa posibilidad de repetir decenas de pruebas en el laboratorio, obteniendo siempre el mismo resultado.\u003c\/li\u003e  \u003cli\u003eUna reactividad perfecta ante el mínimo cambio en cualquier punto del mapa, lo que se traduce en una mayor potencia en el volante.\u003c\/li\u003e  \u003c\/ul\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18082605957222__rich_text_k8zDBJ\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eCaracterísticas principales de la ECU Taipan Y V2 \u0026amp; Estrategias\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eLa ECU Taipan puede gestionar hasta 5 mapas que se pueden seleccionar tanto mediante interruptores OEM como, incluso más fácilmente, mediante el \u003ctc\u003eAim\u003c\/tc\u003e Interruptor del manillar 2.\u003c\/p\u003e  \u003cp\u003eLa posibilidad de configurar y ajustar tu moto de motocross, gracias a las numerosas estrategias y correcciones implementadas por la ECU Taipan Y V2, es infinita. Aquí tienes una lista de las más importantes:\u003c\/p\u003e  \u003cul\u003e  \u003cli\u003eInyección principal alfa-n\u003c\/li\u003e  \u003cli\u003eInyección principal velocidad-densidad\u003c\/li\u003e  \u003cli\u003eCorrección del cigüeñal de inyección\u003c\/li\u003e  \u003cli\u003ePreinyección\u003c\/li\u003e  \u003cli\u003eCorrección de BAP por inyección\u003c\/li\u003e  \u003cli\u003eCorrección de EWT por inyección\u003c\/li\u003e  \u003cli\u003eCorrección de la IAT mediante inyección\u003c\/li\u003e  \u003cli\u003eCorrección de la batería del inyector\u003c\/li\u003e  \u003cli\u003eInyector 2\u003c\/li\u003e  \u003cli\u003eCorrección del BAP de encendido\u003c\/li\u003e  \u003cli\u003eCorrección de EWT de ignición\u003c\/li\u003e  \u003cli\u003eCorrección del IAT de encendido\u003c\/li\u003e  \u003cli\u003eCorrección transitoria de apertura de encendido\u003c\/li\u003e  \u003cli\u003eCorrección transitoria del cierre de encendido\u003c\/li\u003e  \u003cli\u003eControl de lanzamiento\u003c\/li\u003e  \u003cli\u003eTabla principal de control de lanzamiento de inyección\u003c\/li\u003e  \u003cli\u003eTabla principal del control de lanzamiento de ignición\u003c\/li\u003e  \u003cli\u003eCambio rápido\u003c\/li\u003e  \u003cli\u003eControl de tracción\u003c\/li\u003e  \u003c\/ul\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18082605957222__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEstrategia de control de tracción\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003ePara cada mapa, la ECU dispone de una tabla principal de control de tracción específica.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18082605957222__rich_text_MwwyCV\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eControl de lanzamiento\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003ePara cada mapa, la ECU dispone de una tabla principal de control de lanzamiento específica.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18082605957222__rich_text_VYCRcR\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003ePuente de la UC \u0026amp; Afinador de puente UC\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eEl puente UC es la conexión entre el bus CAN de la ECU y el puerto USB de su PC.\u003c\/p\u003e  \u003cp\u003eUna vez que la ECU Taipan Y V2 no programada se ha configurado con una marca o modelo específico,\u003cspan\u003e  \u003c\/span\u003e\u003cstrong\u003eno se puede cambiar\u003c\/strong\u003e.  Podrá modificar los mapas escritos en la ECU, pero la marca o el modelo que se haya configurado\u003cspan\u003e  \u003c\/span\u003e\u003cstrong\u003eno se puede cambiar\u003c\/strong\u003e.\u003c\/p\u003e  \u003cp\u003eNuestro líder\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-motocross-taipan-ecu\" title=\"Aim Motocross Taipan ECU\"\u003eECU de motocross\u003c\/a\u003e\u003cspan\u003e  \u003c\/span\u003eProporciona el máximo control en el encendido, la fase de encendido, los mapas de arranque, el control de lanzamiento, el control de tracción con corrección de altitud y de temperatura del motor.\u003c\/p\u003e  \u003cp\u003eEl\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-taipan-uc-bridge\" title=\"Aim Taipan UC Bridge\"\u003ePuente de la UC\u003c\/a\u003e\u003cspan\u003e  \u003c\/span\u003eEs la solución perfecta para los motociclistas que buscan una gestión de la ECU sencilla y fiable. Con ella, puedes flashear mapas fácilmente desde tu sintonizador, monitorizar el estado de la ECU y realizar ajustes básicos como correcciones en la inyección de combustible, todo ello sin la complejidad de una puesta a punto avanzada.\u003c\/p\u003e  \u003cp\u003ePara los afinadores, el\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-taipan-uc-bridge-tuner\" title=\"Aim Taipan UC Bridge Tuner\"\u003eAfinador de puente UC\u003c\/a\u003e\u003cspan\u003e  \u003c\/span\u003eLleva las cosas al siguiente nivel. Permite un control total sobre la creación, modificación y configuración de mapas, así como sobre la ECU, brindando a los preparadores la flexibilidad necesaria para ofrecer configuraciones de rendimiento totalmente personalizadas.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18082605957222__rich_text_nNNnCi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eTaipán Conexiones de la ECU Y V2\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eLa ECU Taipan Y V2 tiene 4 conectores:\u003c\/p\u003e  \u003cul\u003e  \u003cli\u003e  \u003cstrong\u003eConector principal\u003c\/strong\u003e:  Compatible con la mayoría de las bicicletas todoterreno.\u003c\/li\u003e  \u003cli\u003e  \u003cstrong\u003eConector CAN\u003c\/strong\u003e:  Se conecta al interruptor del manillar 2 y al registrador de datos.\u003c\/li\u003e  \u003cli\u003e  \u003cstrong\u003eSegundo conector CAN\u003c\/strong\u003e:  Se conecta al puente UC para comunicarse con el PC.\u003c\/li\u003e  \u003cli\u003e  \u003cstrong\u003eTercer conector\u003c\/strong\u003e:  Se conecta a entradas analógicas libres y a un posible segundo inyector.\u003c\/li\u003e  \u003c\/ul\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18082605957222__rich_text_ki4am9\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eInterruptor del manillar 2\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eEl\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-taipan-handlebar-switch\" title=\"Aim Taipan Handlebar Switch 2\"\u003e\u003ctc\u003eAim\u003c\/tc\u003e Interruptor del manillar 2\u003c\/a\u003e\u003cspan\u003e  \u003c\/span\u003eEs la mejor manera de cambiar el comportamiento de tu moto de motocross. Cuenta con 4 botones pulsadores, 11 LED integrados y gestiona los siguientes ajustes:\u003c\/p\u003e  \u003cul\u003e  \u003cli\u003eHasta 5 mapas seleccionables\u003c\/li\u003e  \u003cli\u003eAplicar correcciones de combustible\u003c\/li\u003e  \u003cli\u003eActivar el control de tracción\u003c\/li\u003e  \u003cli\u003eActivar el control de lanzamiento\u003c\/li\u003e  \u003c\/ul\u003e  \u003cp\u003eEl interruptor de manillar 2 también se puede utilizar como módulo de luz de cambio de marchas.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e","brand":"AiM ECUs","offers":[{"title":"Default Title","offer_id":40372377944166,"sku":"C-ECU-KIT-YAM","price":480.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_taipany2ecu_00_1.25x.webp?v=1765299310","url":"https:\/\/www.aimshop.com\/es\/products\/yamaha-aim-taipan-y-v2-motocross-ecu-plug-play-es","provider":"AimShop.com","version":"1.0","type":"link"}
