1 de 1
Aim 14 Pin Strada 1.2 CAN Harness For MX Strada Series
SKU: MX-S-L-...
Prix ​​habituel
£160.00
£192.00
INC VAT - UK only
Prix ​​habituel
Prix ​​de vente
£160.00
Prix ​​habituel
£160.00
£192.00
INC VAT - UK only
Prix ​​habituel
Prix ​​de vente
£160.00
Aim 14 Pin Strada 1.2 CAN Harness For MXS, MXP, MXG
The Aim 14 pin CAN connector harness is a standard replacement for the Strada MXS, MXP, MXG (MX series) dash displays.
Fits MXS, MXG, MXG dashes Replacement for original wiring
14 pin AMP female connector 4 pin binder 719 female
5 pin binder 712 female Compatible with cars & motocycles
14 Pin AMP CAN Harness
The Aim 14 pin Strada 1.2 AMP connector with CAN connector is a standard replacement for the MXS, MXG, MXP (MX Series) dash displays.
With pre-wired connectors for easy connectivity, a 14 pin AMP female connector, 4 pins Binder with 719 female connectors, 5 pins Binder 712 female connector and 5 cables.
MXS expansion example
These are some of the items that can be added to your vehicle for incrementing performance and data.
Aim 14 Pin Strada 1.2 CAN Harness for MXS, MXP, MXG
  • 14 pin AMP connector flying connector
  • 4 pins Binder 719 female connector
  • 5 pins Binder 712 female connector
  • X5 1 x 0.5 cables
Aim 14 Pin Strada 1.2 CAN Harness Diagram
  • 14 pin Strada 1.2 CAN Harness
The Aim 14 pin Strada 1.2 AMP connector with CAN connector is a standard replacement for the MXS, MXG, MXP (MX Series) dash displays. It is ideal if you want to transfer your dash to a different vehicle or if your original harness has been damaged. With pre-wired connectors for easy connectivity, a 14 pin AMP female connector, 4 pins Binder with 719 female connectors, 5 pins Binder 712 female connector and 5 cables.
  • X5 1 x 0.5 cables
