AiM 37 Pin Connector and Pins MXS, MXP, MXG, MXL2 Female Deutsch Connector
SKU: P-37P-5CN837F00-MC
- Prix habituel
- £125.00
- Prix habituel
- Prix de vente
- £125.00
- Prix unitaire
- par
The AiM 37 pin plug and pins are ideal if you need a replacement or to keep them as spares.
Suitable for MX Series, MXL2 | 37 pins, One plug |
Ideal for replacement or spares | |
The AiM Female Deutsch electrical connector is suitable with the AiM MX Series (MXL2, MXS, MXG, MXP) dashes.
Use as a replacement part or as part of building a wiring loom.
- 37 Pins Female Deutsch Connector
- 37 Pins
- Plastic Pin Installation Tool
- AiM 37 pins connector kit
The AiM 37 pin plug and pins are ideal if you need a replacement or to keep them as spares.Key Features :
The AiM Female Deutsch electrical connector is suitable with the AiM MX Series (MXL2, MXS, MXG, MXP) dashes.Use as a replacement part or as part of building a wiring loom.
- 37 Pins
