Aim Câble EXP 5 broches pour PDM
Expansion Cable for PDMs
The Aim expansion (EXP) cable is a pre-assigned cable, engineered to link a power distribution module (PDM08 or PDM32) to control modules without the need for custom wiring. The cable comes in a fixed length of 1.5 metres and features a 5-pin 712 Binder connector, providing 6 pre-wired connections ready for use.
Why Choose the Aim PDM Expansion Cable
The PDM expansion cable eliminates the need for configuring a custom harness by delivering a plug & play solution with standard pin assignments. With its secure 712 connector and fixed length of 1.5m, it keeps your wiring neat and efficient, helping you expand your setup reliably.
5-Pin PDM EXP Cable
