AiM Exhaust Gas Power Valve Position Sensor
SKU: S-PV - X08PWVV00R
- Prix habituel
- £160.00
- Prix habituel
- Prix de vente
- £160.00
- Prix unitaire
- par
The AiM steering angle sensor and bracket are suitable for use with all AIM MyChron kart dash/data loggers (this includes MyChron 5 S, MyChron 5 and MyChron 4, both single and two temp versions).
Measures exhaust gas power valve | Compatible with MyChron 4 & MyChron 5 S |
4 pin 719 male binder connector | 20cm 4 pin Binder 719 male connector |
The AiM uses all AIM MyChron kart dash/data loggers (MyChron 5 S, MyChron 5 and MyChron 4, both single and two temp versions).
The sensor comes complete with the patch lead required to connect the sensor to the MyChron expansion box, the standard method of connecting additional sensors to your system.
Main Functions
Measures the exhaust gas power valve
20cm long cable
4 Pin plastic binder connection
It can measure up to 20mm travel and monitor at which RPM value the valve opens/closes, showing all intermediate values. The close valve position is auto-calibrated by the sensor.
- The sensor comes with a 20cm patch lead with a 4 pins Binder 719 male connector
- Binder Connection Pin:
- 1 - Analogue signal 0-5V
- 2 - GND
- 3 - Not Connected
- 4 - V reference (4.5V)
- 1 x Exhaust Gas Power Valve Position Sensor with 20cm cable
- 1 x Cover
- 1 x 150cm patch lead for MyChron Expansion
The AiM steering angle sensor and bracket are suitable for use with all AIM MyChron kart dash/data loggers (this includes MyChron 5 S, MyChron 5 and MyChron 4, both single and two temp versions).Key Features :
The AiM uses all AIM MyChron kart dash/data loggers (MyChron 5 S, MyChron 5 and MyChron 4, both single and two temp versions).The sensor comes complete with the patch lead required to connect the sensor to the MyChron expansion box, the standard method of connecting additional sensors to your system.
Main Functions
Measures the exhaust gas power valve20cm long cable
- 2 - GND
- 3 - Not Connected
- 1 x Cover
