1 de 1
AiM Lotus MX2E SmartyCam Bullet HD GP Track Day Camera
SKU:
Prix ​​habituel
£920.00
Prix ​​habituel
Prix ​​de vente
£920.00
The AIM SmartyCam GP HD (Rev 2.2) has been designed for motorsport and is incredibly compact and robust. The professional on-board camera records your video and can include all the technical information that will help you improve your performance.
Key Features:
  • TFT wide display
  • No wave effect
  • Auto power ON / OFF
  • Auto Start / Stop
Real Time Data Overlay
SmartyCam GP HD (Rev 2.2) automatically overlays on your video all of the data you need: speed, RPM, lap number, gear shifts and much more. Simply choose the data and graphical layout you prefer from the many different overlays available. Data can be read from all the possible sources. From GPS: track map and vehicle position as well as speed, lap and split times. From AIM logger / dash logger connected to your ECU: RPM, throttle, engaged gear, acceleration, temperatures, pressures etc. From sensors connected to your AIM logger / dash logger.
Direct CAN ECU Connection
The new Rev 2.2 SmartyCam GP HD has been designed integrating the direct connection to the CAN-bus line of the ECU. It allows the use of can-bus communication protocols included in the official AIM database. This new feature has been designed particularly for those vehicles like Formula cars or race bikes, where the available space to fit things in is minimal.
Coaxial Connection
The new connection cable for the bullet camera is now more protected from electromagnetic noise, and has stronger filtering on the power connection of the SmartyCam GP HD.
Integrated Aim CAN-bus Hub
SmartyCam GP HD has now 4 connectors, one completely dedicated to the bullet cam, one for the ECU-MIC, one for the GPS08 Module connection and an extra one you can use to add an expansion you might have need.
Designed for extreme conditions
An on-board camera designed for motorsports must continue to work in the most extreme working conditions typical of track racing and against the most adverse weather, such as: strong and prolonged vibrations, continuous rain and extreme high and low temperatures. That is why the SmartyCam GP HD is made in machinery moulded aluminium, just like many competition car parts.
The Global Shutter CMOS Sensor
The camera is available in three lens versions and each with a choice of 2 or 4 metre length cable:
A 67° lens is preferred for closed-roof cars, as it "sees" the track just within the wind-screen pillars, reducing that unpleasant black frame typical of generic camera on-board videos.
A 84º lens is available for open-roof and formula cars, where it is possible to have a more ample view of the track and there is no risk of black frames.
A 120º lens gives an even wider view of the track and the surroundings.
Higher Storage Capacity
Using a compression system which has been optimised to provide the perfect balance between video quality and file size. Video is stored on an SD card and you can select 3 different recording quality options: High quality, 1 hour = 4GB, Standard quality - 1 hour = 2GB, Low quality - 1 hour = 1.5GB. This means that with a 128GB SD card you can store over 32 hours of footage.
Make it even better and add Multiple cameras
SmartyCam connections to your AiM Lotus Dash
SmartyCam GP HD Rev 2.2
  • Video Format: H.264 1280 X 720 pixels @ 30 fps
  • Display Resolution: 2.4" 240 X 320 pixels
  • Lens: Telecentric with 6 elements
  • Field of View: 67°, 84°, 120°
  • Internal Battery: Rechargeable Lithium Battery - 1,500mAh
  • Battery Charge: 700 mAh 12V
  • Internal Battery Duration: 60- 70 min of recording
  • External Power: 9 - 15 V
  • Supported SD Card: Up to 128 GB
  • Memory Capability: 1.5 GB ( 1 hour low quality recording)
  •                                   2 GB    ( 1 hour medium quality recording)
  •                                   4 GB.   ( 1 hour high quality recording)
  • Accelerometer: Three-axial + 5G
  • Usage Temperatures: _10°C / +60°C
  • Auto Power ON: Yes if connected to the AiM logger
  • Auto Power OFF: Yes
  • Body: Anodized Aluminium
  • Main unit Dimensions: 104.6 x 79.6 x 26.6 mm
  • Bullet camera Dimensions: 24 diam x 48.2mm
  • Connectors: 3 Binder 712 female connectors + 1SMA female connector
  • Bullet Cable Length: 2.0m
  • Main unit Weight: 320g
  • Bullet camera Weight: 45g
  • Waterproof: IP67
AiM Lotus MX2E SmartyCam HD Track Day Camera 360° Product View
  • AiM Lotus SmartyCam GP HD 2.2 Bullet Camera
  • Dash or Logger Connection Cable
  • Software Installation CD
Key Features:
  • TFT wide display
  • No wave effect
  • Auto Start / Stop
Coaxial Connection
Technical Specifications
  • Waterproof: IP67
360° View
Whats in The Box
